Guard 'ignored red light and refused to let passengers off'
Dolive22
20 Dec 2009
I think if they did that and the correspondence came out it would make it very easy to get a corporate manslaughter conviction. Doing the sort of assessment required would mean quite a lot of people knowing about it and lots of bits of paper. They would never get away with it.
royaloak
11 Oct 2009
today I will mostly be at home decorating
Unfortunately I have to agree with you Failed Unit, money is king.
Metro-land I was using the maidenhead HST to argue the opposite side of the argument to yourself :lol:, if the guard hadn't made announcements telling people to stay on the train it could have been a lot worse than the 1 fatality, just shows how the same thing can be used for both sides of a debate :lol:
Dolive21, unfortunately everything has a price, when a road scheme is being developed one of the first things they look at is the cost of the scheme against the number of lives saved, the cost I believe (not sure) is about £200,000 per life saved, on the railways I believe it is £1million per life, yes your life is worth more on the railways than the roads.
Failed Unit
26 Jan 2009
Central Belt
It does happen, I used to work in a transport planning department looking at road improvements. The figures never showed the blood as bluntly as my example. But it was always down to cost -v- lives saved. If you were not going to save enough lives then the scheme was shelved. I don't know if the people the died following the descision would be able to sue the council, but no-one has tried to my knowledge.
Dolive22
20 Dec 2009
It's not how H&S has worked with anything I have been involved in, but I suppose huge infrastructure systems work differently.
£10 million is much more than it would cost if they got sued.
Oswyntail
23 May 2009
... It's quite true there are good rules and there are bad rules, but the rule books (of which there are many) are written with nearly 200 years of operating experience behind them. Very often when rule book amendments are proposed (and there are frequent amendments) there is a cry of foul play or downright objection.
.... Signallers argued that it was down the the signalling engineers to propose sensible interlocking if the junctions were deemed as unsafe, and it was a driver training issue, and why should they carry more responsibility?
So you can see the conflicting problems you can get into, just by minor changes, even if they are for the best of reasons.....
Exactly! Unfortunately, 200 years of operating experience tends to result in rules that have grown by having tweaks and small additions, rather than ones that actually reflect all the factors I listed earlier. And I appreciate the signallers point of view, but it is really just one more factor that should have been taken into consideration.
Ferret
22 Jan 2009
So, I'm sorry to say, I don't think the argument that guards prevent passengers getting out and getting hit by other trains holds any water.
Odd then that you should go on to use Ladbroke Grove as an example to make a point. Who was it who put the track circuit clips down that day? To save you the trouble of looking it up, I'll tell you - it was a Virgin XC guard travelling passenger on the HST into Paddington. Perhaps you'd like to revise your opinion that guards can prevent passengers getting out and being hit?:roll:
Failed Unit
26 Jan 2009
Central Belt
Although I doubt there was much need to put any clips down in this case as the signaller would be pretty aware something had gone badly wrong here.
Metroland
20 Jul 2005
Midlands
As it turned out it destroyed so much signalling equipment AND the signaller sat and watched the train speed by the signal - indeed he was criticised for using signals/points to stop the train first rather than DOO, that by that time track circuit clips were irrelevant.
Ferret
22 Jan 2009
I'm sure that guard was thinking the very same at the time it all happened..................:roll:
I don't need to look it up, I went to the public inquiry. As it turned out it destroyed so much signalling equipment AND the signaller sat and watched the train speed by the signal - indeed he was criticised for using signals/points to stop the train first rather than DOO, that by that time track circuit clips were irrelevant. During the previous, most serious, run up to the accident DOO was used to prevent the collision as well as signals. Thanks to the actions of a quick thinking signaller.
Driver Only Operation was used to prevent the collision?! What are you talking about?
Failed Unit
26 Jan 2009
Central Belt
My point is that in this case and many other recent accidents putting down the clips is like letting off a fire extinguser after a fire has burnt itself out.
Metroland
20 Jul 2005
Midlands
Interestingly, the reason the signaller didn't hit the 'all signals to danger' interlocking disconnect buttons on that occasion, apart from complete loss of screen display, is that by just throwing signals back (or indeed just flinging track circuit clips down) you can cause the train to brake to a stand in the direct path of trains that have SPADed and set them up on a collision course.
Of course this was taken as dithering by the inquiry and the unions decided it was profit before safety, it was nothing of the kind.
But the particular actions you describe had no bearing on the accident, as its been pointed out the signalling staff were aware in seconds what as going on, and signals were replaced, DOO emergency stops were sent out.
The previous, most serious near miss (between an HST and HEX train) was prevented using DOO and replacement of SN120. Please see the inquiry transcripts.
Ferret
22 Jan 2009
And indeed this is true - in some accidents, the signalling equipment is destroyed anyway! But Ladbroke Grove is an example of how a Guard can protect several running lines and prevent a train from ploughing into wreckage and/or people. Metroland's contention that Guards are helpless to stop this from happening on the basis of one example (namely one in which a passenger panicked) is at best misleading and should be highlighted as such.
As an aside, the increased use of axle counters is rendering track circuit clips useless and it's not something I am comfortable with. In track circuit areas, they are a reliable way of protecting your train by showing a section is occupied. In axle counter areas, said clips do the square root of nothing. I genuinely fear that there will be a serious incident in the near future in an axle counter area which could be prevented in a track circuit area just by the use of a bit of metal across the opposite line.
Metroland
20 Jul 2005
Midlands
Ladbroke Grove is not an example, there might be others, but that isn't one.
You mention axle counters but what about Absolute block lines?
Ferret
22 Jan 2009
Probably because it was a DOO train in a DOO area? Though yes, it was CSR equipment.
Ah, now it makes a little bit of sense!!!! Say what you mean and mean what you say!:lol:
Somebody has a bit of walking to do! A mile and a quarter to be precise! Who does that if the driver is dead?
Failed Unit
26 Jan 2009
Central Belt
Unfortunetly you are right it is a matter of if rather than when.
Accident have happened on absolute block sections when a train has hit a landslide and fouled the other direction, but there way of stopping the train coming in the opposite direction in time.
If you get a accident like Great Heck where the 91 was derailed into the wrong line, if the 66 had been say 5 miles further away in a TC area it may have been possible to stop it. I a Axle counter area it would have been like waiting for a bomb to go off. I remember a Eurostar suffered a simular derailment to Great Heck years ago, the main difference there was anything coming the other direction had time to stop.
Which will take over 15 minutes, as I have said early not much good when a train can do it in 1!
GB
16 Nov 2008
Somewhere
Even on AB lines there are (and can be) pockets of track circuited lines.
Well then, DOO in its self did not prevent anything.
Ferret
22 Jan 2009
No, it's an illustration of what could've been. That VXC guard did not know that the signalling equipment had been destroyed and for all he knew, there could've been further trains on course to plough into the wreckage. What if a carriage had been foul of a running line which wasn't protected by signals, an oncoming train had ploughed into it killing yet more people and it then came out that the VXC Guard and the FGW Guard made an assumption that the signalling equipment had been destroyed. I hear Wandsworth prison does excellent board, free of charge to the user....
Metroland
20 Jul 2005
Midlands
Yes, there are pockets of TCs on AB lines, but there are miles and miles of lines outside station limits with no track circuits (unless its an IBH approach the box and you need one for tail lamp).
Well yes guards are a requirement on Absolute block lines, nobody has argued any different. With Axle counters, there has to be frequent lineside phones and on the WCML GSM-R
Ferret
22 Jan 2009
Odd you should mention Great Heck - I was thinking the very same as an example of a preventable incident using clips if only that 66 had been even 5 minutes later. It was a cruel twist of fate.
As for absolute block areas, you're absolutely right. That's why there aren't that many left thank God!
Metroland
20 Jul 2005
Midlands
Even so, it had no bearing on that accident, the guard in that instance did not prevent anything. If the signalling kit is destroyed, it reverts to red or lights out - which is treated the same as a red.
Preventable accident with clips? Nonsense, it put all the track circuits down in that area and knocked out the comms to the interlocking at Temple Hirst. As you say, it was just a shame the 66 was so close.
Ferret
22 Jan 2009
Sorry, that's not correct. Whereas SN120 was replaced first, it was supplemented by ATP/DOO. In the particular case of Ladbroke Grove the signaller was criticism for not sending to DOO stop and being too reliant on signals.
Mate, you've missed GB's point!
It takes time to make a phone call, much longer than it takes to put a clip down on the next running line and remember, seconds count. It may also interest you to learn that many Guards (me included) are not trained on GSM-R so in the event of a dead driver, the GSM-R phone would not be a fat lot of use! You can draw your own conclusions as to my opinion on this........
GB
16 Nov 2008
Somewhere
Sorry, that's not correct. Whereas SN120 was replaced first, it was supplemented by ATP/DOO. In the particular case of Ladbroke Grover the signaller was criticism for not sending to DOO stop and being too reliant on signals.
You need to stop interchanging DOO with CSR!:roll: DOO is a type of train operation and is not a method in dealing with emergencies or even a method of communication as far as the signaller is concerned,
Ferret
22 Jan 2009
What did? The original derailment or the carnage that was created when 665** hit the GNER train?
Metroland
20 Jul 2005
Midlands
No I don't, it was a DOO (P) train. You are the one that keeps talking about CSR. I'm aware of the differences.
The original derailment knocked out the interlocking.
Ferret
22 Jan 2009
Could anyone pass Metroland a shovel? :lol:
If you go back a few posts and replace all of the 'DOO's with 'CSR's, it will actually make sense! For the avoidance of doubt, DOO stands for Driver Only Operation - it is not a means by which the signaller can communicate with a driver. CSR is Cab Secure Radio and is a means by which the signaller can talk with the driver, and CSR does not only apply to DOO trains....
GB
16 Nov 2008
Somewhere
Selective memory by any chance?
If it was CSR (as YOU orginally said) then being as CSR would have been available both on a DOO service or a service with a guard, DOO in its self did not prevent anything.
Edit: A thank you Ferret, who seems to know what hes talking about!
Metroland
20 Jul 2005
Midlands
No, but despite all the bluster nor did any guards in any of those instances?
Yes non-DOO trains have CSR, but in this particular case it was a DOO train with CSR fitted as a consequence of DOO. If the train was not DOO, it wouldn't have had CSR - such as the HSTs operating with guards on the same line. A point which you and Ferret have not quite grasped. In the case of the HSTs the signaller has no luxury of sending a stop command via CSR.
