I didn't think so either, which is why I was surprised that the ceiling had been designed to look that way...
I think it was designed to appear like a warm beige, but without realising it just makes them look stained by cigarettes..
Actually, the two B17s had complete bodyside streamlining panels. It is only the P2s that had the A4 style wedge front but the boiler barrel exposed.Yes they were two of the Gresley B17s.
Well I can assure you that in my neck of the woods when the 180s were withdrawn by FGW first time round and were initially replaced by HSTs, then a matter of months later by Turbos - because filling 500-seat trains off-peak was never going to happen - that there most certainly was a great deal of muttering on platforms whenever Turbos hove into view. And there still is whenever a Turbo turns up instead of a 180, or, even worse, though it does happen, instead of an HST - sometimes even a two-car 165 instead of a 125. People out here most certainly do notice things like that, whatever you may think. But maybe we're just odd? And I am not talking peak periods - my 'commute' is off-peak, so it is not the same crowd every day.
It's like the Van Halen contract which had an obscure line requiring a bowl of M&Ms with no brown ones buried in the middle of the contract - if a train is grotty or hasn't been replaced for 30 years, people make the quite rational deduction that the same low level of attention has been paid to important things such as the trains' performance/reliability/safety, the quality of the staff or the state of the track. Even shuffling around different trains of roughly the same age would be a PR win, because a change really is as good as a holiday.
An update to the appearance can be achieved simply with a new livery though! The brightly coloured liveries of the HST fleet under the current private operators look smart and modern, light years ahead of the BR Intercity sector liveries which made the rookie error of using brown paint - bad because brown is usually assumed to be white paint coated with grime which in turn says that corners are being cut on important stuff. The casual observer's perception of even the most boxiest of brick-shaped multiple units can be almost completely turned around with a good livery that deflects attention from the boxy edges and has a livery with swooping curves mixing up the appearance of the slab sides.
You may be thinking about the LMS' Coronation streamliners, where the streamlining was purely cosmetic, and Stanier ensured that a number were built without streamlining (and the remainer were subsequently converted) as he was adamant that it gave no saving in power exerted.
Railway Gazette just posted this.
http://www.railwaygazette.com/news/passenger/single-view/view/first-class-800-trainset-unveiled.html
Well that's not really showing anything more than photo's that are already on the internet, the fact it looks like a 395 isn't exactly surprising since it uses the same cab, and the doors on the driving trailers are further away from the end of the train to allow for the large toilet.
I saw the BBC South news report this lunchtime. They look very sleek.
Saw this video on the BBC and can't remember seeing it mentioned on here. Nice to see the progress made on the new unit
http://www.bbc.co.uk/news/uk-england-bristol-30067282
The body is tapered, when apparently they wouldn't be. Considering its not a tilting train...
Obviously the nose/cab are based on the 395. Is the rest of the body also based on the 395?
Speaking of which will the electric models be capable of 225kph like the 395s (assuming signalling is upgraded or they're on HS1 or HS2)?
Limited to 125mph. My understanding is that 140 would just require software upgrades and certification paperwork.
And stripes put on the side. Won't go faster without them, if my youth taught me anything about making cars faster.Limited to 125mph. My understanding is that 140 would just require software upgrades and certification paperwork.
What about the Spoiler? That's essential for any fast car, no?
What do you think the pantograph is for?
So is the body of a Mk4 and it doesn't appear to be a problem there...
On at least one record breaking TGV set the engineers preparing the train, knowing it would be set one way, genuinely put a spoiler on the rear to help with aerodynamics. As well as putting on bigger driving wheels and lowering the suspension.
How did lowering the suspension help?
It returned the height to what it was with the standard wheels. That maintained the aerodynamics including keeping the ground effect.
