GWR operating short 'HSTGTi' sets (see diagrams section for workings)
6 Sep 2016
I can't see that the weekend diagrams have been posted yet so here goes:-
Saturdays:-
2Y02 0647 BRI to WSM
2U06 0737 WSM to CDF
2C71 1000 CDF to TAU
2U16 1207 TAU to CDF
2C81 1500 CDF to TAU
2U16 1706 TAU to CDF
2C91 2000 CDF to BRI
2C42 0524 BRI to PNZ
2P86 1036 PNZ to PLY
2C46 1245 PLY to PNZ
2P92 1452 PNZ to PLY
2C50 1752 PLY to PNZ
5C40 04+30 LA to PAR
2C40 0610 PAR to PNZ
2P83 0739 PNZ to PLY
2C44 0950 PLY to PNZ
2P90 1256 PNZ to PLY
2A99 1532 PLY to NTA
2P81 1623 NTA to PLY
2E47 1740 PLY to EXD
5M47 19+02 EXD to SPM
Sundays:-
1C04 0726 BRI to PNZ
2E68 1337 PNZ to EXD
5C51 18+24 EXD to PLY
2C51 1942 PLY to PNZ
2E66 1205 PNZ to EXD
2C49 1605 EXD to PNZ
2P96 2013 PNZ to PLY
2C43 0859 PLY to PNZ
2C56 1437 PNZ to BRI
Which ones are slam door / sliding door?
DJ737
15 Nov 2009
Melbourne, Australia
Hi there
Currently on 2C56, only going as far as Exeter due to a shortage of train crew. (This working is slam door stock)
Cheers
DJ737
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Of interest to the programme - 43097 "Environment Agency" and 43122 have now left Doncaster Works; they were planned to reach Laira on the 19th (when they left) but after a points failure at Abbotswood Jct, their light return (0V84) was curtailed at St. Phillip's Marsh.
Both are now green (with vinyled GWR logos), and presumably modified for GTi operations - only 43155 "The Red Arrows" & 43158 remain to be modified out of the powercars now.
irish_rail
30 Oct 2013
Plymouth
Hi there
Cheers
DJ737
Unfortunately with the descion not to allow Plymouth or Exeter HSS drivers to drive the short sets I can see this becoming a frequent occurrence.
RPI
6 Dec 2010
Not strictly true, I know of one Plymouth driver that signs them lol
nat67
23 Apr 2014
Warwickshire
That's correct 155/158 are now left.
Bringback309s
22 Aug 2013
So to come up to date - how many "GTIs" are now in service (fully refurbed, sliding door sets) and how many "GTs" (Classic sets)? How many main line services between Plymouth and Penzance are now not short set or 158 operated - are there still plenty of 150's around? Will much change come the May timetable change?
1e10
13 Jun 2013
Forgive me if this is already covered.
I’ve travelled on these short HST sets twice now and I’m wondering if they have any sort of unit number?
Melancholia
21 May 2016
Argleton
Might just be me being old fashioned, but I will never class them as DMUs, which is what seems to be slowly happening by using different TOPS numbers for them. They are a pair of Class 43 locos, with 4 Mk3 coaches inbetween them. I will always class them as loco hauled.
CC 72100
23 Jan 2012
They've not got unit numbers. In terms of how they are dealt with on systems, they are exactly the same as full sized HSTs. Just the sets of coaches are numbered GW01 for example (instead of say OC45), and they appear on crew diagrams as 255 or 257. Even full sized HSTs appeared on crew diagrams as 253.
Nothing has really changed.
Melancholia
21 May 2016
Argleton
I see, thanks for clearing that up. Completely forgot crew diagrams showed HST runs as 253.
InTheEastMids
31 Jan 2016
I took one of these from Bristol in the week, it was an all-shacks Cardiff-Taunton service including calls at Bedminster and Parson Street. Will these trains remain reliable, doing stop-start work of this kind?
It's not really what they were designed for.
On the plus side, they were a big step up from the usual DMUs.
nat67
23 Apr 2014
Warwickshire
Well when you say stop start it's the same as let's say doing London Kings Cross-Inverness/Aberdeen. The amount of stops on the run is the same the only difference being sort distances and slower speeds.
Dai Corner
20 Jul 2015
Yes, but a train would do, say, three Cardiff-Taunton round trips in the time it takes to do Kings Cross-Aberdeen which is about 90 stops.
nat67
23 Apr 2014
Warwickshire
It makes no difference to a HST as it would a 150 or 170. If your referring to the engines. The train would be travelling at a lower speed on Taunton-Cardiff so no maximum speed required between each stop.
Dai Corner
20 Jul 2015
That's the question. Does 125 miles at a continuous 125mph cause more or less wear to the power cars than 50 miles at an average of 50mph with six stops and a maximum of 90mph or so? I'm not a traction engineer but I'd say the stopper would need the most maintainance.
CC 72100
23 Jan 2012
So the set with slam doors is GWR01?
No GW numbered sets are for the completed sliding door sets only (255).
Any 2+4 slam door sets (257) have retained their former LA or OO prefix as they are only a temporary cover for not enough sliding door sets in traffic yet.
Although to be fair set numbers are of no relevance to even most enthusiasts.
hexagon789
2 Sep 2016
I would imagine you could get up to 100 in several places on Taunton-Cardiff, certainly the acceleration is there to permit that between even some of the closer spaced stations.
I had previously thought going idle-full power-idle in quick succession wore out an HST more than idle-full power-medium power over a longer period of time.
Apparently this is not the case, they can take it no issue.
BR of course classed them as DEMUs in the early days...
Railperf
30 Oct 2017
At a Eurostar depot open day..i was told by the depot manager that the 373s leased to GNER and used on the ECML on services to Leeds and York suffered more wear and tear than the sets used solely on Paris and Brussels high speed services. Part of that was due to the 'classic' lines track quality being far lower than the tracks on HS1 and TGV lines.
Railperf
30 Oct 2017
Apparently it takes around 2.5 mins and 2.5 miles to whisk a 2+4 HST set to 100mph. And then i guess a mile to a mile and a half to brake back to rest. So where the maximum speed allows it..you can reach 100mph on a station to station section of around 4 to 5 miles. Probably though running at 80 or 90mph on short 4 to 5 mile sections would use a fair bit less fuel without losing huge amounts of time.
