Class 170101
- Joined
- 1 Mar 2014
- Messages
- 8,454
How are the 180s coping? I wonder if there are being worked harder betwen London and Oxford / Worcester to release 165s.
Do we know how many 333s are diagrammed per day? There are only 3 of 321s and 5 322s, and it usually needs 3 to operate the Wakefield line at some point during the day, so any withdrawal of the 333s would leave just 5 EMUs for the Aire & Wharfe unless they switched the Wakefield to DMU only operation. Either way, that would see DMU operation on these which can never cope at peak times. Fingers crossed the 332 issue isn't replicated in the 333s.....
When things have gone amiss in the past, the Leeds-Bradford FS service tends to be the first to be abandoned- you'd have to have the Leeds-Skipton trains calling additionally at Apperley Bridge now, but otherwise there aren't any stations which aren't served by other routes. Next is usually Bradford-Skipton (where the 662 bus more or less parallels the railway as far as Keighley). A 144 can't keep to 333 timings on the Ilkley line (the climb from Apperley Junction can be entertaining though!) so 158s tend to be preferred- in the past some of the morning services have been covered by units which then form mid-morning S&C departures.
Still no services this morning and no one has bothered to load the shuttles in to the journey planner so no idea whether they are running or not. :roll:
I hope the service is still suspended on Thursday because I want to film the HC 360s on the Express duties and film Turbos stopping at Hanwell something they haven't done for nearly 2 years.
When was the last time an entire class/fleet was withdrawn on safety grounds?
The one that springs to mind was the 158s when they were initially introduced being subject to an emergency withdrawal - which resulted in anything that could be pressed into service being put in service. Famously resulting in an HST substituting for a sprinter on a local service out of Edinburgh.
2 turbos a day stop at Hanwell Monday to Friday.
Currently seems to be a total lottery whether there are trains stopping or not. Degraded to an horly service each way today and FGW still not bothering to stop any extras.
They've completely messed this one up. You'd think they have some sort of contingency plan ahead and prepared for a problem like this.
Bustitution is the only alternative, without the GW ATP (how quickly could it be installed on a given unit in an emergency?) no other classes of unit are allowed on at least the Heathrow branch, don't know if the same also applies to the GWML
GW ATP is needed for the Heathrow branch because the branch has no TPWS, it's the only safety system installed on the route. Paddington to the tunnel portal has TPWS, and can be operated (subject to paperwork) by any unit with TPWS (so almost all stock).
How many trains (apart from the terminal shuttle) are there ever on the branch at any time?
No Heathrow Connect services until end of service Wednesday 2 March (from National Rail).
Depending on how long the 332s are likely to be out of action for, if AGA could spare any of their 360s (probably no chance though), could the GW ATP be fitted to a few to enable a few of the HC services to run?
Whose choice was it to only install GW ATP on the branch and not TPWS as well?
the 221/220 fleet was entirely grounded on one of the May Bank holidays in 2005 owing to an explosion in part of the door mechanism which injured a fitter at Bristol in the early hours of the morning.
Is there not any class 387/1's that could be used at all as these are due at some point soon to be heading on the GWML?
It's a bit more serious than just an anti-roll bar. The first issue was the anti-roll bar mounting brackets. The bigger problem apparently is cracks underneath on supports near the centre pins where the bogies connect on a couple of vehicles. One apparently looks like a poor job all those years ago from CAF and now it's been found out.
You say GWR should be comended ,they are the muppets who contracted a company to provide a service without any financial penalty In failing to provide said service. That really is the height of stupidity.As a point of order, GWR have no say in whether HX deploy the 360s on Connect services or Express services (they're owned by Heathrow Express not GWR) - that is their call and there were representations to Heathrow Express at Executive level to try and persuade some form of compromise, to no avail.
GWRs "contribution" to the connect service "joint operation" is purely administrative. They provide HX the paths and station safety case for the intermediate stations between Heathrow and Hayes. Connect services also count towards GWR PPM. The stock, drivers, money etc all come from HX and Heathrow Airport Ltd.
There's no obligation for GWR to do sod all to help HX out. That they've done their utmost to try and run a covering service, despite ongoing fleet problems of their own and a driver dispute should be commended.
