Cloud Strife
- Joined
- 25 Feb 2014
- Messages
- 2,400
There are no circumstances in which a Schengen stamp can be waived. Even in countries allowing UK citizens to use e-gates the passport must be stamped as well.
The requirement to stamp is not absolute. It should be done, but it is not an absolute requirement, and this is borne out by the fact that some Schengen countries still do not systematically stamp all third country nationals on entry into Schengen. Frankfurt Airport was/is one of the worst for this, but there are other places too where they simply don't bother stamping people from Western countries.
UK took a pragmatic approach and designed the controls around the art of the possible e.g. no stamping. Schengen did not, hence the problems.
No, all the controls related to the Channel Tunnel were designed for a past in which systematic stamping wasn't really required. St Pancras was designed in the atmosphere where most travellers needed a simple visual check, and scanning of passports on exit (from Schengen) wasn't a thing. By the time it opened, things had started to change, but even in 2019, France still wasn't systematically checking travellers on entry/exit from Schengen to the UK.
The problem is really that the Channel Tunnel was conceived in an era where passport controls were thought to be likely to end. In 1986, the Schengen Agreement had been signed, and the Single European Act was being negotiated. Passport controls among EEC members were becoming increasingly light, and if you look back at historical news articles on the topic, it was clear that at least the 1973 EEC members would have full freedom of movement by the mid 1990s.
So, I think we can forgive the Channel Tunnel infrastructure designers for not really anticipating a future in which there would be a hard border between the UK and France. The shuttles between Folkestone and Calais were meant to be 'hop on, hop off', and the original check-in booths were even called 'toll booths'. If you look at the design of the booths here: https://www.google.com/maps/@51.093...e0!5s20090101T000000!7i13312!8i6656?entry=ttu you can observe two rows of red displays. These were originally used to calculate the fare for travel, in line with the original philosophy. You can see this also here, on the French side: https://www.google.com/maps/@50.939...e0!5s20160601T000000!7i13312!8i6656?entry=ttu where the word "Toll" is used.
So if you look at the problems that Eurostar has with frontier controls, it should've been a non-issue. Eurostar wasn't designed for juxtaposed controls at the beginning, hence the lack of 'escape routes' because they simply didn't need it. It's also why Gare du Nord and others have a lack of space, because it wasn't intended for the station to feature two sets of controls.
You would also have the issue of only being able to access the terminal loops from the tunnel itself. A train trapped at Frethun would need to run to Cheriton to return.
I've always wondered why the loops weren't constructed in such a way that it would allow for trains to return without passing through the tunnel.
