Here endeth the speculation: May promises to deliver HS2 to Yorkshire
not Manchester!
I have done a quick calculation and the tunnel under south Manchester will generate millions of tons of spoil,
the tunnel is 9km long with two bores 7.10m (Crossrail) diameter. which is about 11,400,000 cubic metres.
where is it all going to go?
It is probably cheaper that all those CPOs, road diversions, compensation payments and the litigation involved if overground..
not Manchester!
At the very least it would be uninhabitable during construction due to the number of large goods vehicles and noise. Around half of the estate would be cut off from the rest of the world, and the other half would see traffic that the roads had never been designed for. At best, I thought they would use some of the houses as workforce accommodation and then knock them down when done, as they would be unsellable so close to the completed viaduct.
Makes sheffield councils ridiculous stance even worse, the original route was better and this is just one of the reasons.
Are there no plans to put in more roads to make up for the viaduct or the increase in traffic?
Most probably it will be banned from them.there will be little need for construction traffic to use estate roads.
They could keep the road open that's nearest the river, possibly with a small diversion, as most construction traffic wouldn't need to go between the last pier and the river bank (unless they have to do something radical to the bank itself). But I agree it's questionable whether that would be worthwhile.For reference:
They're not going to build a bridge over the river nearby, meaning that houses not requiring demolition will be left marooned by the construction works. ...
The alignment isn't final, they could shift it left or right when they finalise the design but theres possibilities, they could do an underpass of the viaduct or they could build an access road for the line that doubles as public highway.
I doubt it. If you look at the route map, you'll see that the Shimmer estate was unfortunate enough to be in the only place that the line can practically run through without tunnelling under Mexborough.
Again, it's very important to remember that this estate is only a few years old now. There is no long-standing community character that would be destroyed by simply levelling the site and moving all of the residents to equivalent or superior accommodation nearby. The cost of coming up with novel civil engineering ideas will well exceed the cost of replacing all of these homes with something better. Construction will take a significant length of time and it will make the estate essentially uninhabitable for its original purpose of family homes. CPO the lot, keep some of them as workforce accommodation and site offices and then work out what, if anything, can be done with the site once there is a viaduct cutting it in half.
HS2 trains are expected to carry up to 300,000 passengers a day, freeing up thousands of seats on local services. It could help double the number of seats on rush-hour services leaving Manchester and Leeds and potentially double the number of seats available from London to Peterborough.
Local services are starting to get a mention:
Seems a clear indication plans are pretty developed for an East Anglian ECML terminus, to free up paths south of Peterborough.
Edit: that or stopping all intercity services there, on the other hand.
There are no plans to run HS2 sets north of Edinburgh so if through London-Aberdeen/Inverness trains continue they might still be limited-stop services on the ECML.
Good point. I would still imagine those would be the only ones, and probably still stop at Peterborough too as otherwise pathing may be difficult.
That does raise a question about how the Aberdeen/Invernes flows will work post-HS2 Phase 2B. They'll potentially have a far, far quicker journey by changing at Edinburgh onto a HS2 service via the WCML (well over an hour faster than a classic ECML service, potentially). This would need to be balanced against the political acceptability of losing direct London trains, as well as intermediate flows (e.g. Aberdeen-Newcastle). Passengers would probably do a mix of both in reality.
My money would be on through trains continuing, but picking up Peterborough/Doncaster as well.
Should the wires ever go up to Aberdeen/Inverness, I could also see some 'marginal time' type peak extensions of HS2 services north of Edinburgh too. This might then allow some Aberdeen-ECML-Kings X services to become Aberdeen-ECML-Somewhere Else instead, with London links covered by HS2 services.
A further benefit of HS2 for northern Scotland is also not the rail connectivity but the potential of freeing up some Heathrow slots currently used for Manchester etc, to be used for Aberdeen/Inverness etc. instead.
THE new HS2 route will pass directly through a Doncaster mans living room, between the TV and the sofa, every 30 minutes.
The high-speed rail link will go through 66-year-old Bill McKays home up to 24 times a day at speeds approaching 250 miles per hour, about which he is not happy.
He said: They tell me itll be so fast I wont notice it. Ill bloody notice it.
Im not an excitable man, Im well past that, my bloods cooled, but a high-speed train packed with passengers racing past while Im watching Pointless in my undercrackers is going too far.
Im not moving Ive got pigeons but if its repeatedly spilling my brew Ill have to have words.
A spokesman for HS2 said: We have tried wherever possible to limit disruption to residential areas, and have largely succeeded apart from in the particular case of the living room of Mr McKay.
He will be well compensated with a larger television.
The are some fairly angry people out there, this news story is one of them:
