Trainguy34
No wonder Southeastern are worse now they're OLR...It's real. Was published on twitter to widespread derision. DfT deleted it after a couple of days.
The current Labour party are too on edge to make any promise to do with HS2 given how controversial it was. And if they get in to power, by the same principle I expect them to be wayyyyy too scared to reignite the project out of fear of angering people who just voted for them - my hopes are still at rock bottom
Thats a good point for sure, whilst rebranding it so the general public who were anti-HS2 don't start causing a fuss. I suppose there's certainly more hope for that specific extension.I think the most we can hope for at this stage is that an incoming Labour Government will reinstate the safeguarding of the route, and perhaps will be amenable to reinstating Phase 2a to Crewe - since that's relatively cheap, plus I imagine the rail industry will be telling the Government in no uncertain terms that if that bit isn't reinstated, they'll urgently have to do something else expensive to free up capacity on that bit of the WCML.
When you have the populist pressure group which is Reform UK peddling the idea that the part of HS2 currently being built could be stopped and the money saved, Labour can not commit to reinstating the bit that isn't being built.Yeah, I'm also not massively hopeful, although there is a lot of support within Labour for HS2, and reinstating it would likely be very popular around Liverpool and Manchester. I think the problem will be that some HS2 money has already been allocated to other possible transport projects. Labour will not want to be seen to remove that funding, but will probably be under too much financial pressure to pay for those AND HS2.
Piss poor, Greenwich line is still reeling from the loss of a direct Charing Cross service let alone now losing the remaining direct service past Dartford(By SE). It leaves Thameslink the only direct way into Kent on the Greenwich Line which often will see one of the two hourly trains cancelled.No wonder Southeastern are worse now they're OLR...
Former Siemens boss Jürgen Maier is carrying out a review of UK railway and transport infrastructure for the party and could touch on the issue.
The news comes with hopes growing over the viability of a privately backed alternative to the capacity issues created by the ditching of HS2. The government is currently examining a project, championed by the Tory West Midlands mayor Andy Street and Manchester’s Labour mayor Andy Burnham, to create a link between Birmingham and Manchester airport with private backing.
Hopefully! And if this happens, it will likely restore my faith in politics somewhat hahaBut once they get in, especially if it's with a sizeable majority, I don't think they will be too scared to act - they will have five years and a mandate to get stuff done, irrespective of how popular they become.
It's not real money. It doesn't exist until it's spent. It's not a fixed pot sitting there.I think the problem will be that some HS2 money has already been allocated to other possible transport projects.
Hasn't some ground work already happened on 2A?Labour can not commit to reinstating the bit that isn't being built.
Advance works, relatively limited, such as archaeology and I think some service diversions.Hasn't some ground work already happened on 2A?
This is a very good point and explains Labour's reticence to commit to anything further.When you have the populist pressure group which is Reform UK peddling the idea that the part of HS2 currently being built could be stopped and the money saved, Labour can not commit to reinstating the bit that isn't being built.
Cancelling HS2 and stopping work at the earliest opportunity remains an extremely popular policy a......mongst a misguided, but not insignificant, part of the population.
I’m somewhat expecting them to just rebrand the northern sections as NPR, which would be good electorally and just a massive self own for the conservatives who will have invested significant money to seen as a total failure and built the most unpopular section of the line and then received zero credit for the northern sections.This is a very good point and explains Labour's reticence to commit to anything further.
I would be amazed if a rebranded 2A wasn't signed off/built by the incoming Labour administration as part of NPR.......
Same here. I’m still surprised HS2 was so large in-scope to begin with. Granted, a full holistic network needed to be planned for, but from a PR side of things, did we need to call the whole thing HS2? Why can’t Brum to Crewe be HS3 and so on? More, smaller projects, with smaller individual budgets, may be easier to justify on their own merits from now on.I’m somewhat expecting them to just rebrand the northern sections as NPR, which would be good electorally and just a massive self own for the conservatives who will have invested significant money to seen as a total failure and built the most unpopular section of the line and then received zero credit for the northern sections.
Structuring delivery like that makes it even easier for the route to be cancelled, if it were to be split up, so the stations, depot, city approaches, and the high speed lines were all separate things, you would probably only get the London tunnel and a few station expansions, would be my guess.
Wasn't NPR originally branded as HS3?
you have still got the 2-track pinch point at Shugborough tunnel though. Cowich to Stone and on to Manchester doesn't seem to take enough traffic off the WCML proper to give a lot of relief.Even if HS2a wasn't built to Crewe, they could build some of it on the proposed line from around Keele as normal-speed lines to cut the curves and avoid Stone, Stafford and Rugeley; which would free up a little more capacity on the WCML and be there should, ever, the full HS2 reinstated? Or even HS2 from the north on normal lines and speed to the Stoke area then they speed up on the new line?
This sounds like a good idea tbf. Certainly adapting it into a more modular rolling construction project, perhaps more like how Europe would build such a line. I wonder if the reason why that approach wasn't taken was the people behind 'HS2' at the time thought that, by splitting up the project into completely different projects would make later projects such as HS3/4 etc. more likely to be cancelled though, of course, in hindsight pulling everything into HS2 made no difference in the endI’m still surprised HS2 was so large in-scope to begin with. Granted, a full holistic network needed to be planned for, but from a PR side of things, did we need to call the whole thing HS2? Why can’t Brum to Crewe be HS3 and so on?
That's if all the HS2 money hasn't been "redistributed" dahn sarf.
Years of consultants running up billable hours trying to "optimise" the design is a large part of the reason we are in this mess to start with!The railway (vague term as I’m not sure who*) needs to come up with a review showing what they need to do to deal with HS2 trains getting kicked off at Handsacre, and comparing the expense and disruption to that of just building HS2 to Crewe. Then do some really strict value engineering on 2a (maybe cheat and stick some bits under other names - Crewe regeneration for example), as much as possible within the existing parliamentary approval. Show that lessons have been learned from the current construction programme.
Then rebadge it and gift to politicians as a “I’ve made them do it cheaper” political win.
That has been happening ever since Rishi made his decision to bin it. Yes, that is how its pronounced.The railway (vague term as I’m not sure who*) needs to come up with a review showing what they need to do to deal with HS2 trains getting kicked off at Handsacre, and comparing the expense and disruption to that of just building HS2 to Crewe. Then do some really strict value engineering on 2a (maybe cheat and stick some bits under other names - Crewe regeneration for example), as much as possible within the existing parliamentary approval. Show that lessons have been learned from the current construction programme.
*Not sure who as I imagine the Treasury/DfT are going Taliban on making sure no money is being spent on such things.
PS How do you pronounce Handsacre - is it just hands - acre?
If we really have to nurse them to save (their) face just rename it the "WCML N Midlands Capacity Enhancement" and get it built.Stafford / Colwich clearly needs bypassing and there’s already a planned route with parliamentary approval ready to be built that does exactly this. Why would it be anything other than phase 2A?
Clearly the job here is to find a politically palatable way for the govt to do exactly what they’ve just said they won’t do.
Yes, that too. However HS2a is all ready to go, and there are a couple of (admittedly inefficient) diversionary routes north of Crewe which would help a bit, also some traffic will - or could - disperse towards Holyhead..Its all well and good getting HS2 to Crewe but there is a bottleneck for trains going north. The line drops from 4 lines to 2. The route north needs to be 4 lines. It goes from 4 to 2 then back to 4 then to 2. these gaps of 2 lines need to be made4 removing the bottleneck.
That does rather leave the two-track section through Shugborough feeling rather bottlenecky unless all the IC traffic uses the new alignment...25km of new route and 15km of double track rail electrification (30stkm) and you remove the Colwich bottleneck and indeed possibly render the Colwich-Stone line questionably necessary.
