Paddington is in a poor location - the Great Western Railway wanted Euston so built their line to meet the curve of the WCML so as to make the switch, when allowed to do so, rather easily. Also not much extra dispersal compared to OOC or Heathrow - it's the same main route taking you through the middle of the city. One that is being built at great expense with the initial justification of the poor onwards connections at Paddington!Personally I've never been happy with the idea of Euston serving a line that heads due west of London and wondered why HS2 doesn't head due north/northwest from there. But using Stratford instead is just silly.
An extended Padd if you have to go west, or even Marylebone would make more sense.
Marylebone would be better than Paddington, but would ruin that station. And even if you linked in Baker Street, is there the capacity for dispersal?
Euston is in the right place, gives different routes to OOC (which you need for dispersal, though I guess you could have had West Hampstead mega-interchange with no prospect of massive and widespread redevelopment and an easy-build station), needs rebuilding anyway, the line comes out and points the right way for using the disused railbed to the edge of town (why did they make the WCML so kinky S of Wembley - were they aiming for the GWML?) and the Wendover gap: meaning that (even if tunneled) construction is easier inside Greater London and you take the flattest route that is in anyway direct (Wendover). You save a good 30+ miles of tunnel that would be mandatory if coming out on a 'due north' tragectory. Of course, the New north mainline only leads to a tiny diversion to get south of Harrow from a due northwest trajectory (ie one via the Wendover/Tring area) and from Ruislip to Birmingham the route takes a pretty much straight line, other than some kinks to avoid settlements.
Actually looking at the document, it's simply a junction in the West Ruislip area allowing Euston - Heathrow trains use a spur (they could reverse, but that would be perverse - there's not room unless they leave the spur as a train enters it). In other words a waste of time even looking at the site!AgreedTwo Heathrow junctions? I guess there is actually some benefit in having the branch if it still serves London afterwards
