HST coach disposals
JKF
29 May 2019
Have to say I felt a bit anxious reading this part of the first post:
Scrapped:
CF Booth, Rotherham
40118
...glad it’s just a buffet coach and not a certain Tyseley-based loco!
Phil Scott
21 Aug 2017
According to HSTgen, the following were sent to Sims Metals at Beeston today:
40108
44044, 44074, 44076
46016, 46017
Can’t be many 401xx or 46xxx series left now, other than those owned by LSL
Phil Scott
21 Aug 2017
The four ScotRail coaches from Slateford moved to CF Booth today:
41140, 42287, 42289, 44037
Phil Scott
21 Aug 2017
According to my records the only ones left are:
40106 owned by LSL on the SVR
40115/117 and 46008/012 stored at Long Marston
46006/014 owned by LSL at Eastleigh Works
46010 stored at Dundee
cole_peter5@
12 Mar 2013
The batch of coaches that went Simm- Beeston one coaches was numbered 40108 this is was a GWR, the one that when into Simm was in EMR
cole_peter5@
12 Mar 2013
I was wondering if anyone could help me - I'm trying to make list of all the HST Coaches that were built - and all the withdrawals dates and disposal points.
If someone could help me - say give me your email address and I could send you my wanted list. Hoping someone can help .......... Peter
Could anyone help with disposal of the following 40402 40403 40416 40434 and are the following still at Holgate Works York -- 40402 44089.
cole_peter5@
12 Mar 2013
Is no one going to help me with the disposals of 40403 40416 40434 and are the following still Holgate Works 40402 44089
Can someone help I
Phil Scott
21 Aug 2017
40403 - converted to TS 42518
40416 - converted to TS 42516
40434 - converted to RS 42520
I have 40402 and 44089 as still at York
43096
23 Nov 2015
I have 40416 as converted to 42519.
And to add to that:
42518 ex-40403 - went to Sims, Newport 21/02/2020
42519 ex-40416 - went to Sims, Newport 25/02/2020
42520 ex-40434 - went to Sims, Newport 04/03/2020
40402 and 44089 are indeed still at York.
DB
Guest
18 Nov 2009
Any idea what their intended use is?
When they were reported as arriving I had a wander around the points from where the yard can be viewerd and couldn't see them, so I assume they are (or were then) in the main shed off Holgate Road.
Phil Scott
21 Aug 2017
So do I... the dangers of not proof-reading your own posts!
Maybe spares for the NMT... but that is just a guess. Are they both owned by Network Rail, or still owned by DB/Arriva?
Spirit555
8 Oct 2017
Reported by a friend today that 40402 is at Weardale Railway and 40732 is at NRM Shildon.
Mark
DB
Guest
18 Nov 2009
Mark
40732 is now part of the national collection. The NRM have that and a power car. With another power car to come. Fairly pathetic given the historical importance of the HST - a representative set should have been a given.
Razor1967
2 Feb 2009
York
There is a HST coach parked up at the top of the Klondyke sidings in York Yard.
You can see it head on if you walk up the path to the left as you enter Holgate Park Drive. When you get to the top of the embankment it is visible on the left, has been parked up there for a good few months now. Not sure what it is doing there but sadly it has been "tagged" by the graffiti "artists".
From memory it is painted black.
cjmillsnun
13 Feb 2011
Where would they put a full set? That’s a minimum of 7 23m Mk3s and two power cars at the best part of 18m each. That’s close to 200m
One could argue that the 4CIG/4VEP were just as important. They formed the backbone of commuter services from the south into London for 46 years. Yet no full set is in the national collection.
DB
Guest
18 Nov 2009
I didn't say full, I said repesentative - e.g. one of each main vehicle type, TGS/TS/TRFB/TF as a minimum. That would then have given the option of running it as a working train in future if they ever wanted to. Two power cars and a buffet are only ever of use as static exhibits.
4CIG/4VEP are not as important as they don't demonstrate a major technologicial achievement int he way the HST does, although I don't disagree that it would have been good to see a full set preserved.
Warehouse space isn't that expensive - they could easily have a larger reserve collection if they chose to, as many other museums do have.
cjmillsnun
13 Feb 2011
Warehouse space may not be expensive and the science museum (who own the NRM) do have warehouseing. However it is dead money in that there is no revenue from it and would be more expensive than most as it would require rails inside and point work outside for shunting along with either a railhead connection or a suitable road connection as road clearances can be tight at the end of the day this is a charity that offers free admission and funds aren’t unlimited and also unlike other museums whose exhibits tend to be smaller, the amount of warehousing required would be vast which would significantly add to the cost.
As far as a running exhibit for railtours, I believe that a charter company would be better placed to do this. LSL has a full rake along with power cars and the 125 group also has a pair of power cars and no doubt will acquire coaches.
43096
23 Nov 2015
The original intent of the NRM was to take a full set, and a complete set was designated many years ago (no specific numbers). When it came to it they’ve taken one buffet and two power cars which is somewhat at odds with the intent. Evidently they’d done little thought about how they might go about it.
