HST emergency couplers
alexl92
12 Oct 2014
Please could someone explain to me how HST emergency coupling rods work and what they're made of, how they connect etc?
I've just seen a (probably old) video of 59103 propelling a FGW HST out of Bath Spa Station whilst hauling 15 stone wagons. I know the 59s are really powerful and have excellent traction control but what I don't get is how the emergency coupling rod can be so strong and robust as to take all that strain being sent through it - the force applied by the 59 on the HST, and the weight of the HST pushing back on it (in effect).
Close pics or diagrams would be amazing too, especially of how they attach to each engine. I just don't get it!
Cheers all.
BestWestern
6 Feb 2011
It's just a very strong metal bar, essentially. Consider the amount of strain being placed on the coupling between that Class 59 and the first wagon behind it; taking the full load of a train probably weighing a couple of thousand tons. It's amazing how much force can be safely transferred through a relatively small chunk of metal!
The bars (each power car carries two; a long bar is required for coupling to another Class 43 due to the sloping noses, with the 'short' bar used for coupling to anything else) have an eye at one end which fits over a standard locomotive coupling hook, and a similar arrangement at the other which fits over a bracket inside the nose door on the HST. Retaining pins slot in and are secured in place to hold the bar in position and stop it bouncing free, and away you go. Pretty simple kit really.
alexl92
12 Oct 2014
Thanks all. That video's fascinating; the bar's a lot thicker than it looks from a distance. And I didn't realise that the coupling cover was manually operated. Fascinating!
Phil.
10 Oct 2015
Penzance
I'd like to see some of the female guards manage a coupling bar. I'm not a wimp at 6'3" and fourteen stone but it takes (took) some humping!
455driver
10 May 2010
I would like to see them swing a buckeye into position and pin it into position! :lol:
There is a definite technique involved, unfortunately I don't have it so just use brute force! ;)
whoosh
3 Sep 2008
The HST to Loco bar is heavier than the HST to HST bar.
The HST to loco bar has a hinge which secured out of use by a pin. Take the pin out and the hinge is operable for use with Class 08s which, because they are such a short loco, have more of a swing on the coupling.
33056
12 Nov 2007
On a train somewhere in Europe
Discarded lengths of point rodding were always useful!
ISTR a specific tool for lifting buckeyes about 20-odd years ago, basically a metal bar just over a foot long with a bend at one end. Also seem to recollect that, as usual with such portable things, there was often not one around when needed so most people just did it the hard way.
bolli
26 Sep 2011
We use them still (on a preserved railway).
Photo pinched from the GWSR blog:
rebmcr
15 Nov 2011
St Neots
Looks like it weighs as much as a 5-year-old child, and plenty of women manage just fine with those.
Phil.
10 Oct 2015
Penzance
Ah yes but when lifting and placing a five year old the child doesn't have to be lifted and placed somewhere with a degree of accuracy and when doing that you're not standing on ballast, possibly in the dark.
theageofthetra
27 May 2012
Beckenham
Remember seeing a volunteer, deep into his 80's, lifting a buck-eye on a preserved line in NZ. Conversely a young lady volunteer did the same on another line-tough bunch those Kiwis!
ralphchadkirk
20 Oct 2008
Essex
It sounds like your lifting technique may be incorrect then.
rebmcr
15 Nov 2011
St Neots
Borderline maybe. But the 'average' woman can't lift as much as the 'average' man - and that's biology, not sexism.
Actually, for the average example, gender is irrelevant. It's the top end (e.g. Olympics) where it starts to make a difference. Source: My housemate is a computational genetics PhD.
That's surprising (and counter-intuitive) given that the 'average' woman is smaller than her male counterpart = less muscle mass and shorter lever moment. You learn something new every day.
