IEP Depots
IanXC
Emeritus Moderator
18 Dec 2009
Having found some of the approved planning applications, I thought some of you might be interested to see them. I keep reading reference to 5 depots, but have only found 4:
Doncaster, Ten Pound Walk
http://planning.doncaster.gov.uk/on...ils.do?activeTab=summary&keyVal=LZOWV5FX05H00
London, North Pole
http://www.apps.lbhf.gov.uk/PublicA...l=LRZ05LBI0IE00&searchtype=PROPERTY&module=P3
Bristol, Stoke Gifford
http://developments.southglos.gov.uk/online-applications/advancedSearchResults.do?action=firstPage
Swansea, Maliphant
http://www.swansea.gov.uk/index.cfm?articleid=4681 (search for application 2011/1305)
So does anyone know anything about the mooted fifth depot?
7 Nov 2009
Newcastle
The manufacturing plant is in Newton Aycliffe, and I'm sure it had planning permission a while back.
sprinterguy
4 Mar 2010
Macclesfield
So Swansea is going to look after these trains but won't be electrified?
There'll be plenty of Bi-mode units to look after. Presumably, the on-board computers will keep a record of any faults that occur with the electrical equipment that can then be downloaded at the depot, even though it's not under the wires: Although admittedly, there won't be any way to test if the repairs they have made actually work until the unit gets back to Cardiff ;)
MarkyT
20 May 2012
Torbay
Perhaps they could have a short length of 25kV catenary at Swansea for testing the HV subsystems. It could stretch as far as . . . let's see . . . Cardiff!!
RobShipway
20 Sep 2009
The daft thing is that you will probably find some catenary will be put up in the Swansea depot area, so that it can be tested which makes a mockery of not put the wires up to Swansea.
PhilipW
6 Feb 2008
Fareham, Hants
I hope it isn't the diesel engine that fails, then they will have trouble getting it to Swansea.
Hang on, I think I have the answer. What we need is a Tri-Mode train, we need a steam engine in it as well !!
Ooh, perhaps we better not joke about this. The DfT might actually think this is a good idea and go with it.
DownSouth
10 Dec 2011
Add some others as well; solar, wind, hydrogen, LPG, and bicycle
You forgot hamster wheels and rocket-assisted takeoff bottles borrowed from the nearest air base.
610px-Boeing_B-47B_rocket-assisted_take_off_on_April_15%2C_1954_061024-F-1234S-011.jpg
It would at least bring back a little bit of the steam era ambience!
