Thanks for that. It seems to me that route knowledge is certainly _treated_ as a primary system: if the driver doesn't sign the route the train ain't going anywhere.
Oh I agree with what you say but your intent continues to be the same. It is to allow a unit to go somewhere the Driver doesn't sign. For as long as that point remains then we are stuck in a loop.
Could there be a complimentary tech to enable a Driver to work a route - YES 100%
Should there be onboard systems to allow better degraded working situations - YES 100%
The issue I have with both of those is that when you integrate anything into the train you start to have new rules for when it fails. The railway will treat is as either safety critical or totally pointless.
If it's treated as a critical system then you end up with a situation where a unit will be out of service and your in another situation where you can drive the unit but tech has limited you. TPWS is great but its critical. Isolate and your out of service.Can you drive without it. Of course. Same with the PA and the Mitrac if either fail your out of service. I don't need either to drive a route.
If it is a non critical system then you need to be able to drive without it. That means you would still require route knowledge. Ergo why add such a cost ?
Should you allow a Driver to drive somewhere without any route knowledge ? I still say no. Not outright but it would require so many caveats I believe it would be totally prohibitive.
How do you feed the information to the Driver at 70-100mph ? Remember we need to be looking out the front window.
Can a system really be reliable enough to navigate and drive by ? I agree that various tech is about and what some people have described actually exists in units and is in passenger service (see 700's) but it doesn't navigate. It is about positional data and I have no issues with that whatsoever but it still needs to translate to the Driver in some way.
How far would this allow a Driver to drive ? I posted earlier upthread about some of the things I need for a single diversionary we use. It's quite far and there are is a lot to consider for us to drive. When you remove the requirement for route knowledge you could therefore go anywhere on the network.
You are very much in a situation of 'What if...' So much of what I do is on the fly, reacting to the unit and track and every trip (even on the same route) differs slightly. When those 'What if's' happen; someone needs to be liable too. For the railway and the Driver that liability it important. Someone needs to take the risk. With route knowledge I am expected to be proactive and I know what's round the corner. I agree you can program a lot into the computer but they still aren't proactive enough. The second the weather changes I drive differently, drop a running brake test and drop my speed into low adhesion areas. I also react to what is happening on track. The other day there were passengers dangling their legs over the platform. Which I needed to react to. I was asked to examine the line too a few days ago. Because I have route knowledge it allows the conversation between the Sig and I to go smoothly and with complete understanding.
These kind of questions still hang in the air. I'm generally open minded but they can't just be answered by accusations of being a luddite and afraid of tech or that 'it will exist in the future' or just blind acceptance it is possible. I can agree all that. I need to know how it will present to the Driver and how we deal with the 'what if' situations.
The way we do route knowledge is a little outdate. It's much better than it use to be and could certainly be updated; which is happening.
