Is your train less crowded?
louis97
14 May 2008
Derby
I don't count the passengers who board and alight - not even the TOCs do that!
TOCs are required to submit to the DfT passenger numbers for all of their services at least twice a year. This is typically done by external companies, either through manual counts or using the equipment on board.
deltic
8 Feb 2010
I'd be I interested to know too, the OP refers to average loadings but this would only be a useful measure where capacity is static. If operators increase capacity then average loadings may reduce even though actual use increases.
The numbers come from ORR statistics and are just passenger kilometres/train kilometres to give average loading per train.
The Ham
6 Jul 2012
Wouldn't that mean that TOC's that have more services would show a drop in loadings even if the number of passengers have gone up?
squizzler
4 Jan 2017
Jersey, Channel Islands
I hope the statistics show sensible optimisation of train capacity with demand. It stands to reason that TOCs will increase their train km over time by adding services to busier routes allowing those services to be less crowded. The routes that were carrying fresh air in the bad old days have likely seen no changes to service provision, but overall passenger growth might have given them better occupancy even though overall occupancy for the TOC might have reduced.
Chew Chew
29 Aug 2010
My local station seen passenger number reduce by almost 20% in the last 2 years from 2014/15, the preceding station approx 6% and the one before that almost 15%.
I've definitely seen a reduction but still struggle to get a seat.
Master29
19 Feb 2015
A conflicting title really. If there are more services on given lines then it`s possible you will see less crowded trains.
Justin Smith
14 Nov 2009
Sheffield
The figures prove there are fewer people travelling by train, there are two main reasons, the economy isn`t doing se well and the fares are far too high. Example : every year I go down to London for the day, last year the tickets (1st class advanced purchase non flexible) cost me £78, this year, for the same approx time of train, I was quoted £110. Nah, I thought, that`s just too much, I won`t bother.
On the economy this explains it all :
ChilternTurbo
15 Jun 2016
Commuting on HS1 from the Kent Coast my experience is that trains are definitely getting fuller, reflecting more people moving down, I guess. And for leisure travellers I was on the 10.37 from St Pancras to Folkestone this morning and it was full and standing at least to Folkestone West, where I got off. I was in the second carriage of six, too, so it wasn't a case of people cramming into the rear coaches.
I work in Central London and several colleagues have moved out to the Medway area and use HS1 to commute in. They've either capitalised on burgeoning London house prices and sold up or found that you can get a lot more for your money in Kent.
I commute into Marylebone with Chiltern on the Aylesbury line and with new houses and entire estates popping up in the Aylesbury area I've noticed an increase in passenger numbers on my route.
deltic
8 Feb 2010
On the economy side - growth is still positive but passenger numbers are declining while in the last recession passenger numbers were actually rising. Commuting numbers are driven by employment numbers which are at record highs. However, we are seeing changing work patterns and as you say the move to increase the proportion of costs borne by users rather than taxpayers is having an impact.
Corncob
26 May 2018
I commute from Market Harborough. The 05.57 is quite, but it’s now 9 or 10 carriages (from 5) and no longer stops at Bedford. The 06.19 is the same as it ever was, about 2/3rds full by the time it stops at Kettering and Wellingborough.
But.. coming home the 15.34, which used to be the 15.15 I guess and the 16.34 (16.15) are so much quieter. I’m not sure where the people going home have gone.
