Going into the track to get it is never an option-no matter how well you think you know the timetable if that is what you are fishing for...
Tragically on New Year's Eve at a Hertfordshire station on the ECML a man dropped his wallet on the track and knelt down to quickly pick it up before his train arrived. Sadly a fast train came round the corner and killed him infront of his family. That was at an unstaffed station.
No matter how desperate someone is to get something back the only way to retrieve an item is to contact the TOC or NR and arrange it to be officially collected. And if course as the above poster says, keep back from the edge in the first place and then you won't actually drop anything!
If an item such as a phone or wallet (or shoe) were to fall onto the line at an unstaffed station, what would the proper course of action be?
I wonder what actually would happen if you used the help point? I'm not sure it's enough to use the emergency button, but if you pressed the Information button then the call centre in Mumbai isn't likely to have a clue what to do.
In fact, there's a good chance the person might just try giving you the time of the next train on that platform and apologising a lot.
At staffed stations, I've seen staff use a litter picker to pick up objects (I've seen a shoe and also a pair of glasses collected like this) just after a train leaves the platform, so never actually stepping down on to the track.
Also I once witnessed a maintenance staff jump down onto the track between trains to fetch an item that a passenger had dropped just moments before the staff happened to walk past. It struck me as a foolish thing to do without at least contacting the signal box first (but maybe he did and I missed that while a train went past on a different line)
I know what my response would be, and it wouldn't take long to say it either!!Interesting, not sure how I would react if someone from a call center in India/control rang up to ask for a line blockage for a platform! Intact, IIRC the rules only say you can grant a line blockage to platform staff (could possibly use train crew if there is a train to hand!)
Might be OK if the person concerned has IWA certification, is familiar with the area, has relevant PPE and knows they have enough visibility to get a decent warning time at that platform. All of these may be true if the person concerned is working nearby.
The worker who jumped down almost certainly couldn't have seen far enough, but there was a gang of them and the ones remaining on the platform could probably see a fair distance. I had observed the gang down on the track outside the station some minutes earlier.
He was only down there for about 5 seconds.
But qualifications and risk assessments aside, jumping down on a whim* without first at least checking with control that no trains are coming seems to me like it simply increases the opinion that the public doing so is acceptable.
From my position I couldn't hear the conversation with the member of the public so it's possible he told him "don't do this at home" or whatever, but that doesn't help the people watching it from the opposite platform.
Maybe I underestimate the average member of the public's common sense but somehow I doubt it!
*by whim I don't mean without thinking I just mean unplanned.
I've also seen the litter picker method
A track worker even with IWA cannot work between platforms unless they are staggered without a Line Blockage as all lines between platform faces are RED Zone Prohibited.
I had to attend a recent incident as staff at Biggleswade on the ECML where a lad discovered he was on the wrong platform and had that exact dangerous thought "I'll only be on the line for seconds, quicker than any other way" and off he went! Those platform edges are higher than they look and he was right, he was only on the line for a few seconds but that's all it took for an East Coast HST on it's way back from Edinburgh to be unable to stop as he panic climbed the platform. Next thing he knew he was bing stabilised by paramedics who then had to search for his legs after losing them to the train.
Is an iPhone/wallet/keys/whatever you loose down there, a SHOE, really worth that?
All it takes. The same seconds that can make you think you're safe can change everything.
Just a genuine thought -- is it permissible on Network Rail for a train driver to secure his train and jump down in front to recover an item off the track? The reason I ask is because on LUL it's standard procedure, having first got the go ahead from control, for station staff to ask for the Train Operator to surrender their key in order to prove the train is secured, and then access the track using the train as their means of protection. I'm not sufficiently familiar with national rail rules & procedures to know if this is a viable option. Obviously I know it would be a non-starter if there was any possibility of the member of staff coming close to an adjacent line.
I've seen, more than once on low-frequency parts of the underground, members of staff on the platform just waiting for a train to pass and then getting down to retrieve an item (between two platform faces) without calling anybody first.
Once, this was to retrieve a child's 5p coin
I've seen this done on platforms at compromise height and SSL height (although never at tube height).Providing the member of staff is confident with the location and there is adequate sighting time, there's nothing inherently unsafe in this, at least where the platforms are at tube height -- a completely different matter for surface height platforms however. However the official method is for a train to be held to provide protection, by doing it this way you're removing virtually every element of risk.
One also has to be slightly mindful of what the passenger audience sees - there's a difference between a competent member of staff doing something, and a passenger whose perception and management of the risks may be very different.
I have no idea, but it's my impression, as someone who doesn't work in the industry, that staff on LU are trusted a bit more than staff on the big railway not to kill themselvesShouldn't they get the juice turned off?
