Robinson
And the Class 90-hauled Highland Sleeper (not sure about the Lowland Edinburgh portion).
How could I forget...
At Leeds, I would suspect that 7 and 14, the two eastbound bay platforms will see even less electric traffic, as the only place to go from there is Neville Hill!
How about the side of the Whitehall triangle where they had the temporary platform, that was wired up specially for that job - does that get used by anything electric now?
There are some electrified sidings north of Wakefield Westgate, do they get any use?
That is true about rugby,but how about the Coventry to Bedworth line and Coventry to Leamington lines-both have a bit of ohle for a few hundred yards on their various sections out of the station. Also the section between stechford and Aston over in Birmingham as far as I know no passenger services use that bit of line.
Manchester Piccadilly-Crewe via Manchester Airport service.
Platforms 1 and 8 at York don't see any electric trains, although wired.
I think he probably means the line between Heald Green North Jcn and Heald Green South Jcn, which it's correct to say doesn't see a regular electric passenger service. You occasionally see it used if Virgin divert via Styal rather than the normal route through Stockport though.
when was P0 at Haymarket last used by an electric set as I believe it was wired during A to B?
The depot can't be driven through, it's a dead end. It isn't connected to the GWML either (according to Quail), although alongside it...
Speaking of Airport junction, a very short stretch of the GWML fast tracks directly West of Airport junction has wires but no electric services use it. I would guess that it was placed there when the line to Heathrow was built/electrified so that when the GWML is electrified less modification to the junction would be required.
Farrington Junction south of Preston to just short of Lostock Hall Junction on the Preston Blackburn line cant see many electric trains these days if any at all.
I'm not 100% why they ever ran the wires up that way anyway, though I guess could of reversed the old Leyland plant trains in there when it was open...
Nope, there's now the hourly Euston-Crewe 350s running that way
Ahhh, always learning! Is there still a single track section between Alsager and Crewe?
I imagine the electrified lines down the fast line side of West Hampstead Thameslink don't get used too often, nor 'Goods 1' and 'Goods 2' in Cricklewood yard.
The service has been running for at least a couple of years now. Yep, still got that single track section...can be a bit of a pain if things get delayed
North Pole is indeed not connected to the GWML, although there is a project in place to change this. It's set to become the new depot for the IEP fleet for the GWML, so will have connections installed in the next few years. There's work recently started on site for this.
This is over-run protection. It's provided in case an electric train is mis-routed and gives it enough wire to be able to go along and stop. It can then reverse (subject to the usual permissions from the signaller!) and go the right way. This avoids any need to bring in a rescue loco if it were to fall off the ends of the wires.
You'll find these provided at most junctions off electrified routes. The extent of the overrun protection is governed by a range of factors, such as the speeds of trains approaching, the likelihood of a mis-routed train actually following the wrong route (if it's got PRI's it's very unlikely to take the route. If the driver only knows about it when they get to the signal and see the feather it's a lot more likely that they will take the route before stopping), physical constraints, the extent of disruption that rescuing a misrouted train would entail etc etc.
Is platform 0 at Haymarket wired? In fact does anything electric use Platform 1 or 2 on a regular basis?
When was the last time platform 0 was used by anything? I remember seeing a Class 185 being internally cleaned there a few years ago.
This was discussed earlier in the thread i believe it is wired and that a 380 stables in there all day.
