A tad precipitate in view of the present uncertainty?
No, those occur at various points in the peaks/off-peaks at the moment, I believe...This gives us the only direct services between High Barnet and the West End, and between the West End and south of Kennington.
What services leave/depart Victoria outside "normal" tube hours?
The Thameslink interchanges maybe should be shown- with an asterisk for St Pancras to point out that it is only TL- no Kings Cross services, no SE, no EMT, no Eurostar- but Victoria? What services leave/depart Victoria outside "normal" tube hours?
Yes. It's pretty much every other train from the High Barnet branch that goes via the West End. In the morning peak all Northbound West End trains go to the Barnet branch.
This was released last year. The actual one released yesterday I found a bit strange as it omits NR interchanges at St Pancras, Kentish Town, West Hampstead and Victoria.
I think the poster was specifically referring to High Barnet, rather than the Barnet branch i.e. not Mill Hill East or any 'shorts' so maybe he has a point?
It could be said to be misleading to imply that you can get off a tube at 3 a.m. at Victoria and catch a NR service! In fact, I'd call it downright misleading
Perhaps with the Thameslink works the NR service will be on and off from weekend to weekend, so it's better to leave it out altogether rather than confusing passengers. NR services will still show up in the journey planner.
AIUI the overnights from Victoria to Three Bridges are already well used.
I don't follow. Pretty much every other train on the West End branch goes to High Barnet, it's only a very small number as a percentage that go to Mill Hill East or terminate short.
At that point, would the junction at Camden Town be removed, and if it is, what impact will that have on the night services?Sorry, I didn't have the timetable to hand - maybe the poster was referring wryly to the proposal that all Barnet branch trains in future will go onto the Bank branch post-Battersea and is getting his protest in early.
The last service from Moorgate is 2303. There is no service at all (yet) on weekends.Are there not any overnight services on the Great Northern, then? Do they all run to Moorgate?
Not any more.Are there not any overnight services on the Great Northern, then?
Although don't forget there's also the connection at Kennington.I don't think the points would be 'locked out of use' though as stock might have to transfer from Golders Green depot on one line to Morden on the other and vice versa and emergency provision is also important.
It's strange that, despite all the outer stations being served, there aren't that many routes through the main centre of London.
Stratford does quite well, still has two different links to Bond Street.
