Yet another question on the minefield that is LONDON...
I have a hypothetical ticket whose mapped routes include something like
AB+LONDON+CD
(AB and CD are example names)
The Routeing Guide instructions say:
AB includes mapped routes to several London terminals from the origin Routeing Group - lets say to London Bridge, Cannon St, Blackfriars , Waterloo East and Charing Cross
CD includes mapped routes to the destination Routeing Group - lets say from Waterloo and Victoria.
Am I obliged to use the same London terminal that they have in common (in this case Waterloo) or can I decide to enter LONDON at one terminal and depart from another? I'm assuming I can, as the NRG doesn't say otherwise, and many journeys such as Reading to Southend do this, however there a complication in that the 2 maps in my example share a London terminal in common.
Choosing different London terminals would still be along the correct line of route given by 'permitted route' map combinations, so does this mean I can take the tube between my chosen London terminals even though the ticket doesn't have a maltese cross? Obvously LU gateline staff would give a lot of grief if it appears to be off-route.
AB+LONDON+CD
How to use the National Routeing Guide said:STEP 6
If the routeing code is "LONDON", for all journeys via London you will need to
cross reference routeing codes applicable "to London" with the code for the
"from London" leg of the journey.
If the routeing code is "LONDON", journeys include the cost of cross-London
transfer either by London Underground or Thameslink services. In all cases
the transfer points should be along the correct line of route given by the
‘permitted route’ map combinations.
The via London, Maltese Cross symbol on a ticket signifies that the ticket
may be used via London Underground or Thameslink services. Unless a ticket
specifies that the journey must be made via London, passengers are free to
use an alternative ‘permitted route’ for their journey as provided by the
Routeing Guide.
In some instances (particularly long distance cross country journeys) the
Manual will show an "any permitted" fare but without the via London, Maltese
cross symbol. Reference to Section C (the “yellow pages”) may show via
London to be a permitted route for this journey and in such instances travel
via London to include cross-London transfer would be permitted.
