Lothian Group discussion (Lothian City, Lothian Country Bus and East Coast Buses)
29 Nov 2018
Cust cutting has starting, in this instance it IS A GOOD IDEA.. I think Omni is right we will see wider restructuring taking place soon, again this could be bad but not all of it, and I bet some good will come out of it.
I don't know if this saves a lot of money but merging several different sites into just one area is probably easier to manage and navigate so it makes sense. Perhaps you could say the same about depots. Will they be next to merge?
It's only Edinburgh Trams that are treated differently now from a website perspective. Most folk thought the tram and bus honeymoon was over prior to coronavirus but maybe we'll see a closer relationship in the future - perhaps it would be more efficient. Did the airport buses have their own site before?
FlybeDash8Q400
26 Jun 2018
Edinburgh
Airport routes have always just had the section on the LB website rather than a separate one altogether. The short lived Ford Transit shuttle (if anyone remembers that) used to have its own website I think.
Some costcutting can actually be beneficial, for example combining two shorter routes into one big route will usually save time on layovers and require 1 or 2 less buses. It saves the company money whilst offering more connections to the passengers. Just because the amount spent is less doesn’t necessarily mean it’s a bad thing. Interworking is another common example.
OmniCity999
30 Jan 2018
Skylink has always run from Longstone, except when it started, it ran from Central for a while, Skylink has never (to my knowledge) had its own website.
Airlink has largely spent its time at Central but has been at Marine and Longstone before, Airlink did for a while have its own website too.
Merging websites allows everything to be in one place, everything about each subsidiary was always on Lothians website anyway. They had their own websites set up as part of the subsidiaries setting up, going by my previous statement, these are now not needed. Everything is on Lothians website anyway. EastCoastBuses.co.uk / LothianCountry.co.uk will still be used in branding etc as customers specifically from those brands can navigate via these links directly to the space on Lothians website where everything on that particular brand is held, instead of searching.
East Coast buses wont be losing Musselburgh or North Berwick. Theres already a lot of dead mileage in the operation so moving services to Marine or Central would not be beneficial. There was talk of another depot in either Haddington or Macmerry, but it was dropped when Hall left.
Ideally, some services should start/end from Central (early am/late PM), but everything is based in Musselburgh and out stationed to NB. It would be a logistical nightmare for Drivers and shift patterns.
If the DriverHub at Shandwick Place goes ahead as planned, a lot would change, but ill not go into it at risk of going too far into detail.
Not going to bother mentioning LCB as its pretty similar in regards to ECB, although ECB will survive, at this point LCB is hit or miss.
overthewater
16 Apr 2012
im not sure whats not good about cost cutting?
Sometimes, some people go too far, we have seen this happen a few times across certain companies. Like one Certain over the top young manager at Stagecoach he has bounced around a lot of areas
ScotRail158725
27 Nov 2018
what i’m saying is though is if the right cuts are made in the right places then its only good. cutting the heritage fleet, selling those open top scanias/tridents that have sat doing nothing for ages are steps in the right direction for it to work properly
overthewater
16 Apr 2012
Yes we all want the right cuts to be made, however its not impossible bad cuts could happen.
oldman
26 Nov 2013
I saw a 35 today with Heriot-Watt on the front and all the timetables say Heriot-Watt. Is this new - Riccarton no more? The University will be happy.
ScotRail158725
27 Nov 2018
same with the 34s, never payed attention to any 25s i seen today but would assume they’re the same
Bus9120UK
5 Oct 2019
Edinburgh
Appears bus "5005" appears outside of Central on the Transport Visualizer, does anybody know what bus this could be?
computerSaysNo
14 Dec 2018
For the vehicles which have a roller on the front and an LED on the back, I wonder if the front would say Riccarton and the back would say Heriot Watt? :lol: :s
ScotRail158725
27 Nov 2018
tbh those are a rare sight, only about 25 of those left now
OmniCity999
30 Jan 2018
it's a test tracker, it isnt actually fitted to a vehicle. Where it is shown on the map is where the tracker workshop is. It's probably a few meters out, none of the trackers are bang on.
5005 is typically used for demonstrators.
CN04NRJ
28 Nov 2019
I don't think there's any at Longstone anyway.
scosutsut
1 Jan 2019
scosutsut
Apologies if this has been asked and I've missed it, but do we know if the former Motorcoach B9s with ECB are temporary or permanent replacements for the B7s that have left?
FlybeDash8Q400
26 Jun 2018
Edinburgh
I think it’s permanent. Although my feeling is that 844 may return to West Lothian if and when 942 does finally return.
scosutsut
1 Jan 2019
scosutsut
Cheers, will keep an eye out for one of them appearing in full ECB colours then, which will be a shame as they suit the Motorcoaches colours so much more!
31 Jul 2020
West Lothian
If it is true does anyone know when we might see 20942 (SN10 DKO) on the road again.
Also does the first 2 numbers in th East Coast Buses fleeting mean if the bus is a single deck or a double deck.
E.g.
10051 SF17 VLX, Wright Eclipse 3 VolvoB8RLE
A image from flickr by - Robin Dickson
20950 LB10 BUS, Wright Eclipse Gemini 2 VolvoB9TL
OmniCity999
30 Jan 2018
E.g.
20's are double decks
10's are single decks
Internally vehicles in the ECB fleet are referred to with their full number e.g 20950 and not by the shortened, wider fleet numbering system of 950 - as many enthusiasts would have you believe.
computerSaysNo
14 Dec 2018
What were these vehicles used for between 2018 and now? The Lothian Vehicle Finder has no records for any of them between May 2018 and August 2020, except for a single date in 2019.
