LU/Elizabeth Line 4G update
MrJeeves
28 Aug 2015
Burgess Hill
Comedy. So to avoid the wrong location being given; they can't allow any service (inc any 999 calls - surely allowing 999 calls with potentially wrong location information being tagged is much better than no calls whatsoever!?). Bizarre.
Yep... Crazy.
Gaelan
3 Apr 2023
Edinburgh
If I was in the depths of a large station, say Bank/Monument, and made a 999 call over the station WiFi via WiFi calling how would then the location information be sent to the emergency services?
Generally there's an "emergency address" configured when you set up WiFi calling, which is typically your home address, so presumably that.
Which yes, seems rather useless doesn't it!
mrmartin
17 Dec 2012
Lol yes didn't even think of wifi calling. 100x worse than the wrong tube station location being used!
JonnyM
4 Jun 2022
Morden, Surrey
Each cell site in the UK is entered into this database, along with its location. Right now the issue is what locations should be recorded. For example, should it be the location of the radio equipment? Should it be the physical location of the antennas? Should it be the location of an entrance to the nearest tube station to each of these?
Wouldn’t the best position be the the station control room? Each station has one and presumably the existing emergency points within the station and platforms connect here? The emergency services would probably call at the control room first anyway?
Mojo
7 Aug 2005
At present, each station has Rendezvous Points (you will see RVP signage outside stations, example here) where Fire Brigade / Ambulance service will first attend, unless otherwise advised in the call.
This works because, at present, the only people who (are supposed to) call Fire Brigade or Ambulance is the London Underground Control Centre. When calling Ambulance or Fire Brigade, the staff at the LU Control Centre give the emergency services operator at the other end what is called a “HLUL code” which is a three digit code (four digits for sections between stations), and this pinpoints the location of the applicable RVP on the LAS/LFB computer systems.
Gigabit
7 Dec 2022
United Kingdom
Surprised they can't get a location lock underground, I thought there were ways to do this using a combination of triangulation and the cells programmed to report their location
MrJeeves
28 Aug 2015
Burgess Hill
If you're the network or a government agency, you can use cell locations and coverage to work out a likely area a person is in.
CDMA used in the USA, China and various other countries for 3G did include broadcasting the phone site's exact GPS coordinates as part of the spec, but that didn't ever get adopted for 4G/5G, nor WCDMA as we used here.
Your phone will use its own database of cell sites and WiFi networks to help improve GPS location, though, but this is different and relies on other users with GPS having connected or seen these cell sites and WiFi networks in the past for the data to be accurate.
This is why Google Maps will show your location in deep level tube when on WiFi — people have gotten GPS fixes as they leave the station, and Google has recorded these and can infer your location as a result. Similarly, on the Copenhagen Metro, no matter where you are in the tunnels, Google Maps will think you're in the Metro maintenance facility since that's the only place you get underground-style 4G while also having GPS!
matt_world2004
5 Nov 2014
The tunnels at Heathrow central (HEx Elizabeth line) show their location as Hayes and Harlington station when on 4g .I always assumed that is where the signal was routed via
MrJeeves
28 Aug 2015
Burgess Hill
It'll just be that people stay on the tunnel 4G signal for a few seconds after they leave the tunnel, so Google sees the GPS location kick in, and the ID for the 4G coverage in the tunnel, so adds 2 and 2 to get 8.
MrJeeves
28 Aug 2015
Burgess Hill
How come some stations on the Underground don't have any GPS lock? At South Ken it always thinks I'm still at Earl's Court
Because it's rather difficult to get a satellite signal when you're 20 metres below the ground...
IndianPacific
23 Jan 2022
If you'll let me indulge in a bit of pedantry, the actual satellite signal maybe, but a GPS feed isn't that difficult any more.
GNSS repeaters have been around for a while, more often used in road tunnels to keep peoples sat navs working, e.g;
So, like a lot of things, the problem is solvable but needs a bit of money so probably wont happen.
MrJeeves
28 Aug 2015
Burgess Hill
But the issue then is installing the infra for that too... We've all seen how long it takes for just 4G and other mobile connectivity.
31 Dec 2019
uk
From the latest TfL Commissioner Report:
4G on the Underground
New 4G and 5G connectivity on the London Underground is being delivered in phases, with some significant additions to coverage coming over the summer. The next extension to coverage will include Euston, Oxford Circus, Tottenham Court Road, Mornington Crescent and Camden Town. Later in the summer these sections will be connected, joining the Northern line section to the Central line section.
Coverage is being delivered in ticket halls and on platforms, as well as in tunnels between stations, enabling customers to get the latest travel information, access social media, check emails, make calls and stream videos while on the move underground.
Testing is also starting on the Bakerloo, Piccadilly and Victoria lines, ahead of bringing mobile coverage to these lines in the future. With the success of the 5G coverage, future rollouts will provide both 4G and 5G coverage where possible, providing the best customer experience available. Posters have been used to inform customers of the service that is available in stations and further media campaigns are planned to coincide with the rollout.
In more good news for customers, we have moved the station public Wi-Fi service from Virgin Media to BAI Communications. This was a seamless transition for existing customers, and it was particularly pleasing to see Vodafone customers re-joining the service. This means that all UK mobile customers can access the service once more. Vodafone customers are already consuming 25 per cent of the data traffic on the Wi-Fi network, highlighting the importance of this service to Vodafone customers.
mrmartin
17 Dec 2012
Very interesting, thanks. They are basically the same stations promised for Dec '22, so looks like the rollout is about 9 months delayed. It may be they can launch loads of new stations quick(er/ly) after they turn stuff on.
Still no mention of the elizabeth line as well. My understanding is the equipment is installed but can't be turned on for another strange reason?
bcarmicle
11 May 2018
That last sentence isn't true, is it? Anyone on an MVNO won't have station WiFi access.
JonnyM
4 Jun 2022
Morden, Surrey
Thanks, good find. It’s interesting to see what it doesn’t say rather than what it does.
As MrMartin stated, what’s happened to the Elizabeth line? Not mentioned at all.
It looks like ”end of 2024” has been dropped.
Wasn‘t Bank one of the origin stations promised last year? Due to its size, maybe too ambitious at the moment?
MrJeeves
28 Aug 2015
Burgess Hill
Most will. giffgaff/Tesco/etc get WiFi Extra through O2. Voxi will get it through Vodafone fine. Can't remember about the rest, but most should be fine.
jumble
1 Jul 2011
Indeed how about people using a voip softphone or something like the 3CX app back to a hosted exchange on WiFi if they have no calling credit left?
How could that possibly be tracked by emergency services ?
MrJeeves
28 Aug 2015
Burgess Hill
Also worth mentioning 999 calls will also transmit GPS location to the emergency services when using WiFi Calling, too.
Adam Williams
2 Jan 2018
Warks
It was already really poor how little progress has been made here, and now they're dropping the "by the end of 2024" commitment?
JonnyM
4 Jun 2022
Morden, Surrey
The dropping of the 2024 deadline isn’t confirmed, however it is no longer mentioned in the TfL report.
On the TfL website they are still promising full 5G coverage of the whole by the end of 2024. Take with a pinch of salt though.
matt_world2004
5 Nov 2014
This is how tfl started pushing the idea the Elizabeth line was delayed drop all mention of date then announce a few months later of a delay
jon0844
1 Feb 2009
Voxi absolurly
I guess it will be pretty easy to add 5G support later, ready for the eventual activation/switch to Standalone 5G that will see a big drop in latency.
Initially it isn't essential as you want the biggest customer base to begin with, so that's still 4G right now.
Richardr
2 Jun 2009
Virgin Mobile is an example of one that uses the O2 network and hasn't got access to Wi-Fi - even though it is part of the same group as O2 and used to run the Wi-Fi on the underground. They say customers will get it in the next few months only once customers transfer over to an O2 contract (having initially said that customers had it, then that it was down to a technical issue, and finally admitted that customers could not use it).
jon0844
1 Feb 2009
Users are being migrated to O2 in batches this year so it isn't always true that Virgin uses O2. There are a lot of people to migrate to an entirely different system.
JonnyM
4 Jun 2022
Morden, Surrey
Brilliant. TFL should put up an official Tube map on their site which shows the sections with mobile coverage.
They did something very similar when the (then) Virgin Media WiFi was rolling out just before the Olympics. It was very useful.
