Make Your Own PAs For BVE
jonnorail
14 Dec 2005
Hi there does anyone have the program where you can make your Own PAs for BVE. I tried on Damons Site and the link worked but u cannot download the programme does anyhave it . Please send it to me. Iwould be really grateful.
[email protected]
Cheers
T
Tom
Guest
That program was in fact for MSTS, traininthebrain... just was on a BVE site!
T
Tom
Guest
First of all, do not use 'txt spk'.
Second of all, I downloaded it from the site when it was there.
Tom B
27 Jul 2005
It's a program, not a programme.
Anyway you can add PAs with .announce
The Snap
10 Jun 2005
I think he wants to make his own Tom. ;)
Jordy
9 Jun 2005
WCML South
If such a program existed, i'm sure it would be useful, although i've never heard of it.
Jordy
Sturdjos
27 Jan 2006
Is there anyway you could do one in say, sound recorder using a microphone, convert it, and put it straight into the line?
Tom B
27 Jul 2005
Yep, use the command
.announce file,
where file is the path of your (.wav format) sound relative to BVE/Railway/Sound
Sturdjos
27 Jan 2006
And then you can place it anywhere?? :D
(Ie - in between stations, at a station etc.)
Well - I'm happy now!
Cheers Tom
Edit: This is what I've got in the W&C route for the Annoucement of the train terminating at Waterloo
3100,.rail 1;-3,.announce wc\deadent.wav,,,,
Would I need the numbers etc, or would I just put .annouce (etc) ?
Tom B
27 Jul 2005
You need to have a displacement number starting the line, look through the route file and you will see station commands to get your bearings. s is in metres.
The Snap
10 Jun 2005
It is easy. I use dopplers (.doppler) for sounds, as it allows you to position sounds. For example, you can position a sound five metres left of the track, and five metres higher, if you like. You are best using this for passing train sounds or sounds in the area (such as car alarms, birds, cars etc etc).
For station or train announcements, use the .announce command, as Tom says.
Sturdjos
27 Jan 2006
The displacement lines are the numbers that are at the start of a line? Would you have to create a new row if you wanted to put a new announcement in (with a new displacement number?)
Tom B
27 Jul 2005
You can tack it on to the end of an existing one but make sure you have a comma between all the commands.
