Once again, a load of nonsense in afraid. I don't no of any cases of near misses or people bring hit because they thought a train was stopping but it didn't.
As for all the last not, the disclaimer is the yellow line. Stand the wrong side of it and the railway has no responsibility of you are injured or worse.
I can't believe the vivid imaginations of people on here-never have I herd anyone within the industry suggest a FTC is a safety issue yet we have people trying to argue otherwise with little clue what they Are on about!
I have seen signs in several National Parks in the USA stating that "Your Safety is Your Responsibility" and I find that notion personally quite attractive. However I think you will find that the "yellow line" does not create a situation of "no responsibility". Consider what happened at Elsenham: the instructions were clear, had they been followed the two young ladies would not have entered onto the crossing but Network Rail was clearly held to be at fault. The Railway Industry takes Platform Train Interface Safety very seriously; there is no suggestion that painting a yellow line is the sole and total end to responsibility/liability.
My view is that the occurrence of trains passing, at speed, through platforms when they are scheduled to stop, introduces extra safety risks - it could hardly not. There is no suggestion that this is done for the fun of it, nor that, in most cases, any serious repercussion for the driver would be appropriate.
Yellow lines were painted to define the envelope of opening slam doors. More recently they may relate to turbulence caused by passing trains. They may be a point of reference that, with suitable signage, adjusts the point at which a passenger might be considered to be acting recklessly, but they do not absolve the railway from a duty of care to its passengers (including the young and the visually and aurally impaired).
My understanding was that very early in the Rule Book are the words "Safety is the First Concern" and then goes on to list those whose safety they must do everything possible to ensure. The word "disclaimer" isn't there (of course my copy may be out of date).
You will be aware that the management of risk does not depend upon whether a combination of circumstance has historically led to particular outcomes. If you keep rolling a handful of die you will eventually get a full set of sixes. The secret in safety is not only to address events which do commonly occur but also to reduce the probability (or impact) of events which could occur.
We may disagree about the extent to which the circumstances of the original event, which opened this discussion, present an increase risk. I am, however, sure that no professional safety manager in, say the RSSB, would dismiss this in your words: "there is absolutely no danger arising from it..."
But surely if they found them partially at fault in that case then the TOC would be (equally) partially at fault if the passenger was hit by a train that wasn't meant to stop? I don't see how the fact that the train failed to call makes any difference in that situation, hence my previous post.
I think devinier was making the same point.
I think you are asking a different question. I've tried to concentrate on the circumstance which was reported at Manea and am merely arguing that the assertion that absolutely no danger attaches to it doesn't convince me. This has led to some rather damning comments that, as some of us are not train drivers (I spent 30-odd years elsewhere in the railway industry), we should keep our views to ourselves! I really haven't the time to go into the fast train issue. But, for what it is worth - I really don't want to be locked in a waiting room until it is safe to come out, but I fear that is the direction we are going in (fenced off fast line platforms, platform edge doors, HS1 built so no trains pass a platform edge). Clearly there is a risk in heavy lumps of metal hurtling past our tender human flesh, but there are particular features introduced when a train which should stop doesn't. I'll leave it there.
