- Joined
- 14 Jul 2011
- Messages
- 18,584
Priority replacement will soak up wiring teams that could be used to make that fully electrified railway a reality.
59CosG95:1808037 said:I think that replacing the existing network of 3rd rail (bar Merseyrail deep-level, as the tunnels will be nigh on impossible to electrify for any forseeable benefit) should be a priority, as further wiring of the network is due to take place in the near future. If we have a theoretically fully electrified network (with Southern Region on DC), the costs will be astronomical. All OHLE-slightly less astronomical. Besides, what's the point of all this expensive dual-voltage stock (375s, 376s, 450s, 458s, 444s) if we don't allow them to make use of their capabilities?
Speaking from regular SWT travel, I'm very sure that 110mph running could be achieved with the 450s and 444s if the network was wired around the mainline. There are plenty of straight sections, so should be relatively easy to reach 110. And Southeastern's 375/6 fleet has pantographs they never even USE. We should definitely give them somewhere to run under the wires.
Also, if line restriction is 100 or below and it's electric trains running what's the point of paying for expensive overhead wires?
Another thing, where's the money?
Could you explain your statement that a fully electrified network with south eastern DC would be 'astronomically' expensive?! Why would it cost any more than it would do with everything wired? The infrastructure is already there and does a generally good job. The cost of ripping it all up and replacing it with OLE, and then spending millions on converting hundreds of DC only trains, is where "astronomical" would come in.
I think it is Switzerland that has 100% OHLE and I also think most people would say Switzerland is one of the most beautiful countries on earth. IIRC
The point is that AC overhead wires are CHEAPER. Read this thread from the start and you will learn why.
We could always train up some more (instead of teaching them third rail renewal). This is going to be a long job!
It is cheaper if the third rail equipment it replaces is about to be junked anyway.
People are suggesting ripping all the third rail up right now, which would obviously be astronomical compared to a rolling replacement.
And it would be fun to see how they plan on rigging eight track gantries in the Waterloo approach.
I propose this occasionally but everyone seems to think we should instead plan the job to obtain Xeno's paradox as the result. Stretching the task out for as long as possible.
The big mistake (IMHO) was using 3rd rail when they (and later BR) extended electrification out into the 'country' areas (Brighton, Portsmouth, Kent coast etc.) - 1500V DC overhead would have been more sensible, and would have allowed fairly simple dual-system EMU's (e.g. traction motor pairs connected in parallel for 750V or in series for 1500V). Sure, you need to raise bridges etc. to get more vertical clearance, but there are fewer of those outside urban areas anyway in relation to route miles.
I wasn't saying start today with the SR re-electrification; more as a CP6/7 project after the Electric spine is finished. On the Waterloo note: they've done it with Gare du Nord, Munich Hauptbahnhof, Roma Termini, Madrid Atocha, and loads of European stations; no reason for us not to be able to wire Waterloo up.
So what are you going to do with the entire Tube network then? Go back to 19th century coal-fired locomotives? xD
The big mistake (IMHO) was using 3rd rail when they (and later BR) extended electrification out into the 'country' areas (Brighton, Portsmouth, Kent coast etc.).
http://www.railjournal.com/index.ph...ion-choices-overhead-ac-vs-third-rail-dc.html
Seems like that article explains the pros and cons of each
As others have said previously, I don't understand the need to replace 3rd rail that otherwise works fine. At least the lines are electrified - there are many other lines that deserve to gain electrification. It's similar to a vicious cycle, where the SE will constantly get all the money thrown at it, at the expense of everywhere else.
A strategic rolling replacement would be far more beneficial, as and when the 3rd rail becomes life-expired, allowing electrification/improvements to still be carried out across the country. The phrase "If it ain't broke, don't fix it" comes to mind.
Strategic rolling replacement is what's being considered, except perhaps by the more excitable members of this forum. I wouldn't totally rule out replacement of third rail before it's life expired in all cases, but it would need very good justification.
I think there's been a few times recently where there's been trouble with the 3rd rail on the Waterloo-Weymouth line south of Southampton, so is the 3rd rail south of Southampton reaching the point of being life expired?
I think they're saying that it should be done in a prudent and economic manner, rather than a boom-and-bust manner.
There was actually an issue between Bournemouth and Weymouth yesterdaywhere a single 444 or 450 unit would get gapped, so all services had to run in multiple with delays/alterations waiting for trains to arrive and attach.
What location on that section of line was the problem at?
hi, would the rail network in the south of England (southern and southeastern's lines) be converted to overhead from 3rd in the near future?
I think I remember reading somewhere that the 3rd rail electrification south of Bournemouth was done on the cheap so that section of 3rd rail might have a shorter working life. Hopefully the overhead when installed on the spine will at least go as far south as Poole, would be nice if it went all the way to Weymouth.
Once the routes between Kent and London get converted to overhead it would also give Eurostar a few diversionary routes for emergencies
