Dai Corner
- Joined
- 20 Jul 2015
- Messages
- 6,781
Why are Openreach busy replacing copper with fibre then?Yes, without doubt. The bandwidth requirement is very, very low.
You know schoolteachers show videos to their classes and office workers have video conferences?For streaming movies and the likes, not for saving Word docs and reading emails which could be done on a 28K modem with bandwidth to spare.
It's like we didn't just have a pandemic where loads of people worked from home, isn't it?
Have you actually ever seen the size of files created by modern desktop productivity software? I just saved a completely blank Word document and it's 12KiB.For streaming movies and the likes, not for saving Word docs and reading emails which could be done on a 28K modem with bandwidth to spare.
Ha yeah i was sent 6 Words docs yesterday, all text and nothing else (well visible anyway). 1.2GBHave you actually ever seen the size of files created by modern desktop productivity software? I just saved a completely blank Word document and it's 12KiB.
They contained a lot of old data which Word keeps in the document unless you purge it, after i did this one document went from 720K to 86K![]()
Presumably you've got things set up so you can cut yourself off from the grid when required? Otherwise if the mains is off, so is your house.Oh I'll be loving life my friend, Vehicle 2 Home technology means while you're cuddled around candles, I'll be unaffected, and there'll be plenty of time for the car to charge when the mains comes back on.
I can also ensure my elderly neighbours have somewhere warm to be as well.
That's mandated by the DNO and it must isolate withjin 5 seconds. There's no alternative as connecting to the grid, even when the outage is very local will mean that everybody on the same circuit (including the substation secondary and any poor soul working in a manhole trying to restore power) would be fed from the one installation, - the local feed to the consumer unit and failing that the company fuse would blow almost immediatwely) anyway!Presumably you've got things set up so you can cut yourself off from the grid when required? Otherwise if the mains is off, so is your house.
And transformers work in both directions, so if you happen to be close to a distribution substation anyone on the other side might be on the receiving end of 11kV!There's no alternative as connecting to the grid, even when the outage is very local will mean that everybody on the same circuit (including the substation secondary and any poor soul working in a manhole trying to restore power) would be fed from the one installation, - the local feed to the consumer unit and failing that the company fuse would blow almost immediatwely) anyway!
Exactly. Hence having a separate power source such as Vehicle 2 Home, a solar panel, or even battery storage won't help you during an outage unless you can disconnect. This isn't a standard feature.That's mandated by the DNO and it must isolate withjin 5 seconds. There's no alternative as connecting to the grid, even when the outage is very local will mean that everybody on the same circuit (including the substation secondary and any poor soul working in a manhole trying to restore power) would be fed from the one installation, - the local feed to the consumer unit and failing that the company fuse would blow almost immediatwely) anyway!
I was considering the situation where a local feed was interrupted which would probably be via breakers on the 11kV side of the substation, however this measly 4kW wouldn't get very far anyway as a 1MW substation transformer could swallow that in iron losses.And transformers work in both directions, so if you happen to be close to a distribution substation anyone on the other side might be on the receiving end of 11kV!
I agree that not all solar systems include a transfer switch, but I'm yet to see a battery storage system that doesn't.Exactly. Hence having a separate power source such as Vehicle 2 Home, a solar panel, or even battery storage won't help you during an outage unless you can disconnect. This isn't a standard feature.
It requires separate certification above the basic MCS that is usually installer raised. We might see more non-grid tied installations if power cuts become more frequent though.Exactly. Hence having a separate power source such as Vehicle 2 Home, a solar panel, or even battery storage won't help you during an outage unless you can disconnect. This isn't a standard feature.
Modern gas hobs /ovens will not suffer from this as a problem as they have flame detection devicesI think the idea with the gas it’s because they can’t turn it back on safely in case someone’s left a hob turned on. After an emergency disconnection, eg a fire, they have to visit every nearby property to check they’re safe to go back on.
I would imagine that mains gas will be long gone before they can be confident that there are no appliances without flame failure protection.Modern gas hobs /ovens will not suffer from this as a problem as they have flame detection devices
There are still boilers around with pilot lights and some can be a real pain to relight
NoDo you think the mobile network (even if it's equipped with UPSs) could deliver the bandwidth required?
QuiteI would imagine that mains gas will be long gone before they can be confident that there are no appliances without flame failure protection.
I wonder why flame failure devices as standard on domestic hobs are relatively recent, seems they’ve been around for many years…Modern gas hobs /ovens will not suffer from this as a problem as they have flame detection devices
Yes.The proposal is such that it would affect about an hour and a half of the working day. Is planning to do those things in the morning beyond the wit of some people?
Is this the same type of arrangement as required for portable diesel (or petrol?) generators?That's mandated by the DNO and it must isolate withjin 5 seconds. There's no alternative as connecting to the grid, even when the outage is very local will mean that everybody on the same circuit (including the substation secondary and any poor soul working in a manhole trying to restore power) would be fed from the one installation, - the local feed to the consumer unit and failing that the company fuse would blow almost immediatwely) anyway!
No, what Robert Llewellyn is demonstrating is the ability of the Tesla battery to maintain power to the home (assuming it is sufficiently charged) in the event of a power cut. He triggered that response by turning off the house's connection to the grid. That meant that he manually performed the isolation function so there was no path for locally generated power to pass onto the grid.It is a standard feature with a Tesla powerwall (I mentioned earlier). You don’t even get a flicker in the lights if the mains go out.
Watch this video from about 3 min in:
Though, it's usually not necessary to perform site-specific verification as long as all the equipment used complies with a relevant standard, eg. VDE-AR-N 4105.That is separate to any battery that may be installed and subject to very specific verification.
However, it is a legal requirement on an installation to prevent any power passing back in the event of a power cut. In that case, Robert is very unlikely to be standing next to his main isolator ready to turn it off, so the function has to be automatic by means of a circuit breaker that is triggered by a loss of power on its grid side contacts. That is separate to any battery that may be installed and subject to very specific verification. In a normal solar-only installation, the inverter will perform this function by shutting down when its 50Hz sample is lost.
I also have an EV with Vehicle 2 grid tech set up to also allow Vehicle to home. It will be able to power my electric infrared heating, lights etc for much longer than 3 hours!Oh I'll be loving life my friend, Vehicle 2 Home technology means while you're cuddled around candles, I'll be unaffected, and there'll be plenty of time for the car to charge when the mains comes back on.
Although interestingly, Covid had the opposite effect with people needlessly hoarding six months' worth of toilet paper, etc!Basic thought process seems to be:
I normally leave my house at 0800 and get to work at 0830, there is snow falling before I go to bed so I will get up as normal, leave the house at exactly the same time, and expect to get to work at exactly the same time. Having been an hour late getting to work I will go onto twitfaceappsnappagewhatsbookchatter and blame everyone else. Then the local media will pick up my sorry tale and make it this day's front page whinge to trigger the keyboard warriors and score lots of lovely clicks to support advertising income.
The same applies to any kind of 'preparedness' - bad weather, power cuts, disruption to supplies...
Hobs did not need FFD before 2010 so plenty will still be in use ( We recently decommissioned a 30 year old Miele gas hob) and pass CP12 landlord certs under grandfather rights
How do you think that beer’s kept cool? Just out of interest how many cellars and cold rooms have you had to look after? Because it’s really not as simple as you make out.How many pubs now rely on electric pumps to get the beer? Real ale on handpull should be OK, it might even come at a decent temperature if the cellar coolers for the l*g*r are out.
