National Power lines have come into contact with OLE - Berwick (13/10)
Not quite! For a fixed resistance, as V gets larger, I gets larger too.
I think what you meant is that for a fixed power, the current is less and so the losses are less. Power= V*I so, if V is greater then, for the same power, I is less. The (resistive) losses are I^2 * R, so increase with the square of the current. (With alternating current the impedance is not just the resistance, but that's another matter!)
Yes, sorry. :oops: I lost that when I edited the post. For a given value of R, as V increases I decreases to transmit the same power.
Posted above that it was just 11kV - I think 132kV would be on pylons not wooden poles.
132kV wooden pole lines do exist, indeed you get a great view of one going towards Cornwall outside of Exeter station.
They look a bit strange but have a huge set of splayed insulators on the top of the pole, often referred to as "Tridents".
D365
29 Jun 2012
Daft question time what does DNO stand for?
Not a daft question, in fairness, that abbreviation is used all too often in railway-land without being fully explained!
ABB125
23 Jul 2016
University of Birmingham
OpenInfraMap is my new favourite map! I love maps like this, I could spend hours looking at this.
It's fascinating looking at my local area - plenty of wooden poles are 66kV - I'd always assumed all wooden poles were 240V! My only criticism is that it only has high-voltage stuff on it, but I suppose including every power line in the country would be rather too much work.
Interestingly, the University of Birmingham has its own 132kV supply from Selly Oak substation - I wonder why they need this?
Apologies for perpetuating this fascinating but off-topic topic.
Any chance of some pictures for those of us that missed the LNER tweet?
_toommm_
8 Jul 2017
I've not found much, but here's one or two links:
And incase these tweets/articles get deleted, I'll post the photos below (DESCRIPTION: The photos are of the damage to the Overhead Line Equipment at Berwick-upon-Tweed, 13/10/20):
Is the conductor/catenary wire on that section copper or steel reinforced aluminium?
This type of incident can’t be that common, I would have thought?
It’s just the sort of random snag that would usually result in the sort of discussion we‘re having, but I don’t recall a previous similar fault.
oldman
26 Nov 2013
A similar thing happened in Northumberland on a very windy day in the mid-1990s. Went down to York for a meeting but going home the message at York for Edinburgh passengers was don't bother; in fact they had one line open for diesel traction by mid-evening. I ended up on the Eurostar-connecting HST coming up from Waterloo - I don't suppose it often carried so many passengers.
1978NWUK
13 Dec 2011
I’m wondering what brought the DNO cables down in the first place
I can recall a few happening over the last few years. The distance between the DNO OLE and railway OLE is specified in ENA (Energy Networks Association) documents although I imagine its not a simple affair to manage when you throw in wayleave agreements......
There are some locations with ample clearance between DNO and railway which allow for nets to be installed to help reduce the potential for de-wirements.
