kieron
Sorry; I thought you realised I was talking about buying a ticket which would allow you to make that journey, rather than a ticket with those specific stations written on it.According to NRE, Farnborough North to Streatham Common via Redhill requires 2 tickets. This route is also disallowed by FGW's Mixing Deck.
In any case, they added that bit back in for Streatham-Guildford (but not for Streatham-Dorking) on Friday.
Sorry, I really don't understand what you're asking. What would you like to do with Dorchester?I am looking into moving half way between Brockenhurst and Salisbury. Am I right in thinking that as a result of these changes, there is now no annual season ticket that I can get that would allow me to go from London and choose either destination without paying an excess?
What about Dorchester ? Have not got the fares to compare with Salisbury
There was another update on Friday.
New Dataset RJRG0365 published 03 July 2015
Following customer comment the following changes have been made to permitted routes.
Map sequence added
Ash Vale (AHV) and Hounslow (HOU) - added sequence 'BU'
There was already a mapped route via West Byfleet, Staines and Feltham.Following customer comment the following changes have been made to permitted routes.
Map sequence added
This adds one via West Byfleet, Staines, Feltham and Barnes.
Basingstoke (BSK) and Hounslow (HOU) - added sequence 'BU'
Basingstoke (BSK) and Hounslow (HOU) - added sequence 'BU+WX'
Basingstoke (BSK) and Hounslow (HOU) - added sequence 'WW+WX'
Map sequence removed
Basingstoke (BSK) and Hounslow (HOU) - removed sequence 'LE'
This removes mapped routes via London which also went via Feltham or Twickenham.Basingstoke (BSK) and Hounslow (HOU) - added sequence 'BU+WX'
It removes mapped routes avoiding London which go via Ash Vale and Weybridge.
It adds mapped routes avoiding London going via Ascot and Kingston.
DORKING GROUP (G10) and Hounslow (HOU) - added sequence 'DK+TW'
DORKING GROUP (G10) and Hounslow (HOU) - added sequence 'SD+VH+TW'
This adds a mapped route via Earlsfield, and a few extra ones via Redhill.DORKING GROUP (G10) and Hounslow (HOU) - added sequence 'SD+VH+TW'
Guildford (GLD) and Hounslow (HOU) - added sequence 'EF+TW'
Guildford (GLD) and Hounslow (HOU) - added sequence 'PU'
Guildford (GLD) and Hounslow (HOU) - removed sequence 'PD+TW'
This removes mapped routes via Feltham which also went via London or Effingham Junction. The only mapped routes via Feltham are now via Woking on maps WX or PU.Guildford (GLD) and Hounslow (HOU) - added sequence 'PU'
Hounslow (HOU) and Woking (WOK) - added sequence 'PU'
This adds mapped routes via Chertsey, including the shortest route between the routeing points. Following customer comment; to provide alternative permitted routes via Redhill. the following amendment has been published
STREATHAM GROUP (G29) and Guildford (GLD) - added sequence 'LP+CS'
This adds a mapped route via Redhill, one of the ones removed a fortnight ago.STREATHAM GROUP (G29) and Guildford (GLD) - added sequence 'LP+CS'
To ensure XC Train services that travel via the Tyseley Routeing Point to Gloucester have map permissions, a review has rsulted in the following amendments
Map sequence added
BANBURY GROUP (G58) and Gloucester (GCR) - added sequence 'BB+BL'
BANBURY GROUP (G58) and Gloucester (GCR) - added sequence 'LH'
BANBURY GROUP (G58) and Gloucester (GCR) - added sequence 'XB+CB+HP'
BANBURY GROUP (G58) and Gloucester (GCR) - removed sequence 'RB+PB'
This adds mapped routes via Evesham and via Stroud.Map sequence added
It removes mapped routes via Bristol, Nuneaton, Stratford upon Avon
It also removes mapped routes which go via Stourbridge, Droitwich and Bromsgrove.
BIRMINGHAM GROUP (G02) and Gloucester (GCR) - added sequence 'BL'
BIRMINGHAM GROUP (G02) and Gloucester (GCR) - added sequence 'CB+HP+BL'
BIRMINGHAM GROUP (G02) and Gloucester (GCR) - removed sequence 'PB'
This removes mapped routes which go via Stourbridge, Droitwich and Bromsgrove.BIRMINGHAM GROUP (G02) and Gloucester (GCR) - added sequence 'CB+HP+BL'
Gloucester (GCR) and Oxford (OXF) - removed sequence 'BL+SM'
They added BL+HP+CB+XB, HP+WR+BE+PG and WR+XB at the same time.Altogether, these changes add mapped routes via Tyseley, via Stourbridge, and via the line between Bromsgrove and Droitwich.
Gloucester (GCR) and Tyseley (TYS) - removed sequence 'PB+BI'
As this was the only map combination available in the previous version, they added BL+BI and BL+HP+CB+BI to replace it.This removes a route via Stourbridge, Droitwich and Bromsgrove.
Easements added for GWNML engineering works
700579: During Engineering Works in July and August, affecting the railway route through Box Tunnel, tickets routed 00618 is Via Salisbury, 00438 AP Salisbury and 00831 Via Bath Spa will be permitted to travel via Swindon and Westbury on First Great Western services.
700580: Due to engineering works in August 2015, affecting the route to the east of Bath Spa station, journeys from South Wales to Hampshire and Dorset will require to take alternative routes. For example Cardiff to Portsmouth direct trains will not operate. Journeys between S Wales and Hampshire/Dorset will be allowed to go via Swindon where interchange to connecting services will be permitted for the duration of this easement. this map easement will operate in both directions.
As neither easement lists any dates, should I assume that these are active until the end of August, and for the length of August, respectively? Or are you required to find out if train A is cancelled before you board train B?700579: During Engineering Works in July and August, affecting the railway route through Box Tunnel, tickets routed 00618 is Via Salisbury, 00438 AP Salisbury and 00831 Via Bath Spa will be permitted to travel via Swindon and Westbury on First Great Western services.
There were some updates which weren't included in the summary. Perhaps someone was looking at the effects of easement 700580, noticed that some journeys from stations in South Wales to ones in Hampshire or Dorset were already allowed on that sort of route, and made a half-hearted attempt to get rid of them.
Or maybe they just forgot to include the section which explained these changes.
Cardiff Central (CDF) to Brockenhurst (BCU) lose SB+LA+XR
Cardiff Central (CDF) to Eastleigh (ESL) lose SB+LA+XR
Cardiff Central (CDF) to Southampton Group (SDN etc.) lose SB+LA+XR
These each remove a mapped route via Swindon, Trowbridge and Reading.
