Bantamzen
There seem to be a lot more 321/322s working all day out of Leeds today - is this due to the new timetable or just covering for out of service 333s?
There have been more out and about for a couple of weeks now.
Like I've said multiple times already it seems Northern have based the entire Macclesfield/Stoke May 2018 timetable on TSR1, as is the case with other lines. Complain about one service being two minutes earlier than it should be all you want but that has to be one the smallest breaches mentioned on this forum, so few people are going to have sympathy for the last service not meeting TSR2 requirements. Yes under TSR2 the last Stoke service is supposed to be at least 2 minutes later but the one in the timetable has a bad path between Piccadilly and Stockport (behind a service timed for a 75mph DMU.) As a consequence of that it means it departs Stockport at 21:57, so from Stockport onwards it's no later than a 21:49 service from Piccadilly with a good path and I can't see any Piccadilly arrivals at around 21:35 where an official connection can't be made.
Putting forward an argument that the franchise requirement for the last service is too early is fair enough, provided you and others that would use a later service made that point when the franchise was being consulted on.
158871 is currently down to work the 17:42 Man Airport to Barrow; firstly where is the booked 185 and secondly how long must it be since a Northern 158 last worked through the Piccadilly corridor?
Don't think a Northern one has since 2004/05 when they moved the FNW sets to Neville Hill.
I would think it highly likely that Northern 158s have been working through Piccadilly on a regular basis for many years but not in public service. That route is used by empty stock moves between Victoria and Newton Heath just about every night/early morning even if only by one train to allow drivers to retain their route knowledge. With the opening of the Ordsall Chord it now only needs the one reversal at Ashburys. Of course 158s are a tiny minority among the stock needing to make such moves but nevertheless the scope has long been there. Kudos to anyone who has ever managed to photograph one of these workings!
Philip said: ↑
What makes you think it is *still* booked for a 185??
Which stock is running the Liverpool to Wilmslow and Crewe services
319s or 323s?
I believe that it advertised as Deansgate from Crewe up to Wilmslow and Manchester Piccadilly from Liverpool to Newton
Should be booked 2 x 185’s the service in question.
Just as confusing Blackburn no longer has any trains to Manchester listed on the departure boards just Southport and Rochdale. People are assuming the Rochdale trains depart to the east and Southport to the west. To get to Southport you are usually quicker getting on the Rochdale train and changing to get to Rochdale you are usually quicker getting on the Southport train.Or someone travelling from Rainhill to Manchester Airport.
The 7.13 from Crewe this morning was showing as 'Liverpool Lime Street via Manchester Airport' on the screens
t could be thought that 'Liverpool via Manchester' would be more appropriate, but I suppose that 'via Manchester Airport' needs to be stipulated in order to distinguish from 'via Stockport'.
I notice the Piccadilly to Chester service that skips Navigation Road for some reason but calls at all other stations from Stockport, passed Navigation Road 4 minutes early last night - plenty of time to stop!
Did they get back to you on this?All the trains on the Clitheroe/Blackburn to Rochdale services, which used to be 3 or 4 carriages in the peaks are running as 2 carriages today, with nothing showing on journey check to suggest these are short formed. Have posed the question on Twitter without response, but guess they might be busy today. To be clear the number of trains over the peaks has not changed, just the timing smoothed to provide a more consistently spaced 1/2 hour service.
It might be that a freight is held up somewhere further back if the train stops there. There will be a reason for it not stopping there, they won't miss it for the sake of it.
Also, Northern seem to be have put on peak extras for this morning on the Bolton line, such as 2T04
Love this one.Just as confusing Blackburn no longer has any trains to Manchester listed on the departure boards just Southport and Rochdale. People are assuming the Rochdale trains depart to the east and Southport to the west. To get to Southport you are usually quicker getting on the Rochdale train and changing to get to Rochdale you are usually quicker getting on the Southport train.
From RTT I doubt that Northern has any 185s today. I believe that the 0841 Airport to Barrow (1C51) is intended to be formed from 2x185, with the rear portion detached at Preston. However, this service was terminated at Preston, 57 late, with the unusual declared reason:Today it is showing as a single 156! I'm guessing once everything settles down it'll return to the normal traction fare?
http://www.realtimetrains.co.uk/train/Y22835/2018/05/22/advancedThis service was cancelled between Preston and Barrow-in-Furness due to the planned train being replaced with a slower train (MS).
Perhaps a more important reason is that it is scheduled through Mickle Trafford Junction only 4 minutes ahead of the ATW 2314 Piccadilly to Chester. The time needed for a stop at Navigation Road would cause a conflict.My guess is Northern requested a path for an 22:52 Stockport-Altrincham and it got pushed back to 22:56 Stockport-Altrincham due to an off-pattern northbound Cleethorpes service meaning it gets to Navigation Road 4 minutes before the Fiddlers Ferry P Stn Flhh to Redcar High Level freight train goes through Navigation Road, instead of 8 minutes and Network Rail thought that was too close to allow it to stop and it was too late to re-time the freight train (which spends half an hour waiting at Edgley Junction anyway, so getting there 10 minutes later wouldn't be an issue for it!)
The new Mid Cheshire line timetable is less resilient to delays, because the hourly Northern services in opposite directions are scheduled to cross close to the Navigation Road single line. For example, this afternoon the 1502 Chester to Piccadilly was 4 minutes late at Altrincham, so the on-time 1541 Piccadilly to Chester was allowed through the single line before it. This made the eastbound service 8 late at Stockport. Consequently the 1534 Buxton to Piccadilly, which was on time at Davenport, had to wait for a platform at Stockport, and ended up 13 late at Levenshulme.Similar to that the 09:41 Manchester to Chester suffered a slight delay yesterday as a 142 had finished up on a diagram which had a Buxton service as its' next working, so a swap was done to put the 142 on the 09:41 to Chester instead.
Maybe because skipping Ashley would cause a 2 hour gap in the service from Manchester, whereas Navigation Road users have the Metrolink option? And/or an issue with traincrew working hours?If that's the case why skip Navigation Road rather than Ashley or just hold the train at Mouldsworth for a few minutes like has been done with the 15:41 Manchester to Chester on Saturdays?
