Fairly low I'd think, particularly as cash payers tend towards being older people who in TfGM/Merseytravel land will be using passes mostly.
What about teenagers? There could be a large number of them without a suitable debit card.
More like 4000, if they are what I believe them to be.Someone said the TVMs can hold 1500 blank tickets,
but not in West Yorkshire or South Yorkshire.Fairly low I'd think, particularly as cash payers tend towards being older people who in TfGM/Merseytravel land will be using passes mostly.
I have a Merseytravel pass, but if the ticket office is closed, the TVMs are useless if I wish to travel "out of area" - they only sell tickets "from this station", not from "any station" (e.g. the Merseytravel boundary station. )
altough in theory the paid for PTTs are meant to cover the cost of the ticket , how many are issued at 5 or 10 p ?It would appear to be a Permit to Travel. The fact that it is issued for free is neither here nor there, given that most Permits to Travel are issued for £0.05.
This is a rather good idea to me.
OK the savvy who know their fares will feed it with the change portion of their fare meaning they can pay on board / at destination in whole pounds + the PTT
Back when SWT had a few PTT machines at the minor stations on the Fareham - Southampton line they had a regularly updated poster next to the machine showing the exact fares to all the local stations on the line, which helped at least for direct local journeys.At the time permit to travel machines were widespread, you would only know the fare if you had made the same journey recently or if you had phoned an 0845 number to find out the fare. Given fare inconsistencies it would have been sensible to insert less than what you expected the fare to be.
This can't come in soon enough up here
I notice you do not say where.
Where Northern operate
But there are inadequate ticket issuing facilities in Greater Manchester. Shouldn't they address that first?Greater Manchester
Quite! It is difficult for me to envisage Northern complying with best practice in this area (ie, providing adequate facilities in Penalty Fare areas). I'll believe it when I see it....Though that requires ticket offices for a large swathe of the day and TVM facilities that work and are of sufficient number in relation to passenger numbers. Interesting to work out that formula...
Problem is, it wasn't clear what "come in soon enough"; if it's adequate ticket issuing facilities, I agree with you but I think people were concerned that you may have meant Penalty Fares specifically.
The problem with the latter, is that the former is required first (and a load of other aspects of good practice which some TOCs do not adhere to!)
I wish! Sadly DfT has approved various schemes which do not fully comply with best practicesAnd as you know full well approval for a Penalty Fares area will not come about until said improvements to retail facilities have been completed.
Selling any fare could be seen as an "alternative to prosecution"; if a customer has done something to warrant prosecution, the TOC is not obliged to prosecute and can simply sell a fare.This is an area I know next to nothing about, so please correct me, but are penalty fares not in effect just an alternative to prosecution?
Penalty Fare is a charge that Chiltern Railways is allowed
to make under the Regulations and Rules. It is not a fine, and
anyone who is charged one is not being accused of avoiding,
or attempting to avoid, paying their fare.
‘Fare dodging’ is a completely different matter: it is a criminal
offence and we treat it as such by prosecuting offenders.
They can do that whether or not they have a PF scheme.I mean if a TOC doesn't have a penalty fare scheme, could they not just prosecute everyone and anyone found travelling without a valid ticket?
"Travelling without a ticket" is a bit too simplistic but if a passenger is committing an offence under the Byelaws or Regulation of Railways Act they can be prosecuted.(I'm fully aware that no TOC would ever actually do this, but at the end of the day travelling without a valid ticket is an offence, so it would surely be possible?)
Normally a Penalty Fare is an alternative to a normal fare, when a customer makes a mistake under certain circumstances.
I suggest you read Chiltern's PF leaflet, particularly the part that clarifies:-
Perhaps I should have said "acceptable practice" then.Ah so weasel words eh! "Best" practice is by definition above and beyond the standard required.
I believe Northern are likely to attempt to charge Penalty Fares in circumstances which should be "questioned", however the DfT cannot be trusted to effectively "question" these practices, and cannot be trusted to "consider" whether to allow such a scheme. It is the DfT who are actively encouraging inappropriate schemes (EMT long-distance services north of Bedford is an other example of a clearly inappropriate scheme, but the sort that the DfT enjoys inflicting on passengers).When considering a penalty fares scheme, we will first consider whether penalty fares are
appropriate, given the type of train service provided and the other ways in which that operator
could protect its revenue. A penalty fares scheme is most suited to urban or suburban train
services where most stations have ticket facilities, and where busy trains and short intervals
between stations make it impossible to check every passenger’s ticket between every stop. We
may question the need for a penalty fares scheme to cover long-distance services, where a
conductor is able to check every passenger, or rural services operated as ‘paytrains’, where
most stations are unstaffed and it is normal practice to buy tickets on board the train.
In deciding which trains should be penalty fares trains, an operator should take account of the geography of the train service, the ticket facilities available at the stations which will be served and
whether the area covered can be easily explained to passengers.
...serves a port or airport and is used by a large number of foreign visitors and people who do
not often travel by train, making it undesirable to charge penalty fares to passengers from
this station
And they will almost certainly not be taking up this recommendation:we expect operators to provide enough ticket windows, ticket machines
and staff at staffed stations to meet the queuing standards set out in the Ticketing and
Settlement Agreement and their Passenger’s Charter under normal circumstances. This
standard is normally five minutes at peak times and three minutes at other times.
Weasel words indeed; these should not merely be "recommendations" and the DfT or ORR should absolutely hold TOCs to account and ensure they are acting in a way that is totally appropriate.We do not recommend that large numbers of unstaffed stations are included in a penalty fares scheme.
