F Great Eastern
quite a mixture of everything tonight, but interesting to see some of the wheel changing process and technology that is used to sense wheel problems.
S02E01 now on CH5
Shame the station staff where made to look like fools by management not being able to make up their minds on train calling patterns.
The station manager was also made to look risk averse with his "I'm not putting my name to opening the station" line which senior management then overruled. Though the real problem there is caused by Paddington, like so many other stations, having a ridiculous tiled floor. Concrete or tarmac, or knobbly tiles (the kind you get at swimming pools), wouldn't look as nice but would not be slippery.
Again, proof that as usual during service recovery, decision making and communication is a total farce.
That is a pretty accurate summary of how it is most of the time for us.Is it really as bad as that, it seemed like utter chaos sometimes with things changing back-and-forth and platform staff not always being kept in the loop as it were?
Getting information is really bad. I remember waiting around 20 minutes for someone to pick up the phone at Swindon Control Room to tell us what was going on, because it was so busy with others trying to find outIs it really as bad as that, it seemed like utter chaos sometimes with things changing back-and-forth and platform staff not always being kept in the loop as it were?
Having said that I'm sure the editors of the series gather vast amounts of footage where nothing much happens, and edit it down so the programmes focus on the more "interesting" bits, which tend to be where something goes wrong. I also find it hard to believe that when person A with a camera pointing at them phones person B, so often there just happens to be a camera pointing at person B too, so I can't help thinking there must be some "re-enactment" in that sort of situation.
Episode 2, about half way in there was a bridge bash. The Mom got in the lorry and said that the lorry was “three metre ten” then the camera showed a photo of the bridge sign which said 3.8m. Did that confuse anyone else? The lorry driver apparently got a ticket, so was the sticker in the cab wrong or did the Mom get it wrong?
I'm with Mojo on this one.The impression that I got was that the lorry was 3.10m, the bridge was 3.8m, and so there was no way that the lorry was going to fit under the bridge. (IIRC).
3.10m = 3m and 10 cm. 3.8m - 3m and 80cm. So if the lorry was 3.10m, then it should have had a good 70cm clearance!
I noticed the discrepancy too, but I thought I'd mis-heard. The sign on the bridge shows 3.8m / 12'-9", and the MOM definitely does say that the sign in the cab says "three metres ten". Perhaps whoever put the sign in the cab got their metric and imperial units mixed up, but even 3m 10" would have been wrong!Anyone got a screenshot? I'm pretty sure the subtitle said 3.08m and the editor didn't linger on the actual sign long enough for me to see it properly to compare...
Here's a screenshot from the programme, the sign definitely shows 3.8m (12' 9" which, as stated, is actually 3.88m but rounded down to 3.8m), If the lorry is 3.10m (as quoted by the MOM), then I really don't see how they can justify giving the driver a ticket.If the driver was paying attention, and the sign in the cab said 3.10m. it's likely that the bridge height was misinterpreted as 3.08m. Either way, a ticket for driving without due care was probably the right course of action.
Aye, you're right enough. I'm getting muddled up now! If it clearly says 3.10m in the cab then it suggests that the sign in the cab was incorrect, in which case it would be unfair to penalise the driver.Here's a screenshot from the programme, the sign definitely shows 3.8m (12' 9" which, as stated, is actually 3.88m but rounded down to 3.8m), If the lorry is 3.10m (as quoted by the MOM), then I really don't see how they can justify giving the driver a ticket.
So either the height information in the lorry is wrong, or the sign is wrong.
I guess the MOM role doesn't require primary school-level Maths?
But however, the confusion with the existing signage would be to underestimate the height of the bridge and thus road vehicle operators would not use it if that were the case.If it says 3.10m in the cab, and 3.8m on the bridge, there is potential for some confusion if the driver is used to dealing with heights in feet and inches. 3'8" is clearly lower than 3'10", for example.
From previous discussions on here I think the driver is responsible for knowing the height of the trailer and behaving accordingly. If so it was right to give the driver a ticket even if the rationale as stated on the programme was wrong. Presumably if the ticket was incorrect the driver would have successfully appealed, and like on those police chase programmes there would have been an update broadcast to say so. Otherwise the programme is effectively blaming the the driver (or possibly the company, who were identifiable from the footage) for something that wasn't their fault.It looked to me however as if the tractor/cab of the lorry passed under the bridge fine, it was just the trailer.
I'm presuming the sign in the cab would have been only applicable to the height of the tractor, and not the trailer which was higher.
