Poole To Eastleigh
Techlance
22 Feb 2012
Bournemouth
Hi i was wondering if there is such a thing as like a Day rover i know you can get 3 day rover used in a 7 day period.
I have a 16-25 Railcard and would like to go to Eastleigh but also stop off at southampton and leave the station to pop to Ikea.
Thanks in advance
sonic2009
19 Jan 2010
Crewe
You could buy a normal STD ticket for Poole - Eastleigh.
I.e a Off Peak day return - the restriction code for this flow from Poole - Eastleigh is UQ http://brfares.com/#faredetail?orig=POO&dest=ESL&rlc= &rte=0&ldn=0&tkt=CDR
This would allow Break of Journey, this means you can go to Ikea and then catch a train to Eastleigh later on if you wish.
The only time when it is not allowed would be that if the restriction applied to the ticket did not allow it, even if the ticket did say you weren't allowed to break your journey except to change trains, you are still permitted to use station facilities
But on this ticket you are fine to do what you have described you wished to do.
Sent from my GT-I9000 using Tapatalk
Techlance
22 Feb 2012
Bournemouth
Excellent Thank You
I get so confused when Break of journey is allowed etc.
wintonian
15 Jan 2010
Hampshire
Break of journey is allowed on all buy on the day tickets down here, although there are a handful of longer distance (mainly around north Wales I think) super off-peaks where it's not.
Ivo
8 Jan 2010
Bath (or Southend)
As a *general* rule of thumb, if you do a search for a ticket you desire and find an "8A" restriction (used commonly by ATW), or is an Advance, BoJ is not permitted. If you do not find said restriction, and said ticket is not an Advance, it is permitted. This is by no means a concrete rule though.
bb21
Emeritus Moderator
4 Feb 2010
8A is a legacy from the old Saver fare and was commonly used in areas outside Network SouthEast, hence they can be found in many places and not necessarily restricted to one area.
wintonian
15 Jan 2010
Hampshire
and It's becoming a rarity. :(
island
30 Dec 2010
Still exists on a very few odd journeys in the NSE area, anywhere on the Dartford loop to Gatwick should be 8A.
