Not at this stage
No problem, thanks anyway.
Aren't they extra units to provide cover while others are sent away for belated accessibility mods?
They are, I was just wondering if Philip knew what the unit numbers were.
Not at this stage
Will they be able to change modes on to go? For instance, leaving Guildford, first stop North Camp the 3rd rail runs out at Aldershot South junction, somewhat short of North Camp. It'd be a shame if they had to run on diesel all the way from Guildford.
hang on how many 769s to GWR?
will they keep the DC/AC equipment then to use both systems plus have diesel engines?
that will require many mode changes on the north downs
Not Dorking. No 3rd rail at Deepdene! Will be a change of mode at Reigate.
No, they are going to be tri-mode, for exactly that reason.
That said, do 769s retain the ability to run on third rail, or is that stripped out in favour of diesel? If they can be used on third rail, then the North Downs would be ideal for them...
Why is it assumed that the 769s will definitely be operating on third rail? The DC supply may not necessarily have the capacity to support additional services.
I fully anticipate that some at NR will say this. But we shall see what the actual electrical headroom is and in which hours they say they have issues.
The move from Reading station to Reading depot is currently planned to be made on 25kv, to try and further reduce the diesel noise for local residents, which is still an issue.
“The reason the engine is so efficient is not just because it’s modern. It runs at maximum efficiency all the time, whereas the engine in a diesel hydraulic DMU cycles through the rpm range when it’s running. This engine just runs at a near constant speed, in its maximum efficiency range, feeding the existing 750V line. We are effectively tricking the tracking system into thinking it is still a DC unit. It is effectively replacing the DC operation with diesel, but we could still retain the shoegear and have a tri-mode ‘319’ if it was needed."
Simpler would just be to switchover in a platform raising and lowering the shoe...
The third rail shoe on BR EMUs, where fitted, is fixed and cannot be retracted. This might be one of the secondary issues precluding the 769 from being a real "tri-mode".
The dual voltage Electrostars have retractable shoes. However the shoes on the 319 (and the 700) are non-retractable, and the AC routes they operate on need to have clearances maintained so the shoes don't hit anything, and this would have to be true on the GWR 769 routes unless they plan to fit retractable shoes. I imagine the 769s elsewhere would have their shoes removed, and that the GWR ones will have to have circuit breakers to isolate them when on AC or diesel (if whatever is done on the 319 can't be re-used)For what reason though? If the concern is the shoes becoming live away from the third rail then provided they are able to put proper isolation between the genset output and the third rail shoes, and a means of switching between the two properly then that is surely 'fixed'. If the concern is shoes hitting the ballast then it should be as simple as a gauge clearing it (presumably just lowering ballast shoulders?) and the question becomes who pays?
The underpass is not currently electrified at all, as built.Is the underpass line wired with a suitable AC/DC overlap and signalling for that move then?
It would make it the only tri-mode operation in the country!
If so they could run straight into the main line platforms if needed (but have to stop on the way to switch electric modes).
Wait, wasn't the North Downs engineered for 92s and 373s?
Surely the service over it has not increased so much as to make a 1000kW EMU excessive?
Depends on your definition of the North Downs. Tonbridge - Redhill was electrified in the early 90s as a Chunnel freight diversion with adequate power supply for 92s.
'Tri-mode' is nothing but marketing rubbish from Porterbrook. Are the 319s retaining 3rd rail shoes bi-mode? No they are dual voltage EMUs - so a 769 which can operate off both overheads and third rail would be a dual-voltage bi-mode, not a tri-mode.
Helen Simpson, the designer of the 769 conversion, is quoted in this article from Rail as saying:
Based on this, I'm hypothesising that the following changeover sequence could take place whilst the unit is under way:
- train is on 3rd rail power
- driver starts diesel engine
- driver (or train management electronics) confirms that the diesel is running and there's 750V available from the genset
- driver puts the train in "coast"
- driver opens a circuit breaker to disconnect the shoegear from the main bus
- driver closes another circuit breaker to connect the diesel genset to the bus
- driver engages power again, now on diesel
The circuit breaker changeovers could be very quick so as not to affect the traction electronics. After all, the electronics has to cope with a brief loss of power in neutral sections when operating on AC, so a brief interruption in the DC supply should be comparable.
