TT-ONR-NRN
It’s also being reinstated on the 165s.
Is it? I thought the only 165s being retained at Reading were for the Thames branches, which don't need first class.It’s also being reinstated on the 165s.
The thing is they said they were going to retain first on the North Downs Line according to people on here.
GWR said in a statement: “Initially, the fleet will support the introduction of refreshed trains on Heathrow Express services, but will be predominantly be used on routes between Reading and Gatwick, and Reading and Oxford, where the train’s tri-mode can be used to its fullest.
Given the 387s don't have it, and many (all?) Turbos had it removed I would think the chance of these 769s having first class is less than slim to none.
Do we know that first class won't be reinstated on the 387s once they are no longer working Paddington locals? It got restored to the 165s once they were off that work.
It was removed from the 165s but retained on the 166s iirc
The article linked further up this page suggests that the seats will only be recovered and not replaced, so they'll retain whatever interior layout they've already got I'd have thought. Unless GWR take on any of the units that were standard only (which is unlikely as I think Northern already operate most if not all of them) then they should have first class, although it may be declassified.
I am guessing that air cooling requires less power than conditioning? This could be an important factor when running on diesel.
Air cooling system and air conditioning are different. An air cooling system works by cooling the water vapour in the air and can work best with keeping the windows open. whist air conditioning acts by romoving the humidity from the train carriage but works best with no openable windows.
Northern have all except 319372 and 319373.It was removed from the 165s but retained on the 166s iirc
Is one of those with LNR? They have at least one, which seems far too often to end up on the WCML rather than being used on the Standard only Abbey Line where it would actually make sense.
I suspect so. I believe aircon was even an issue on 25kV on the Renatus 321, wasn't it? So much so that they refitted the opening windows?
Except that the Abbey Line is not Standard OnlyIs one of those with LNR? They have at least one, which seems far too often to end up on the WCML rather than being used on the Standard only Abbey Line where it would actually make sense.
Yeah, that is sadly not that rare.I sit corrected...they've changed that, then! In early LM days it was, carried over from being Class 313 operated previously.
Interestingly, some journeys have no walk up 1st fares...
http://www.brfares.com/#!fares?orig=GSN&dest=WFN for instance.
Probably late May/early JuneSo more orders but we’ve still not seen a prototype emerge from Brush as yet?
Any news of when we are likely to see a unit escape?
Any idea on what the delay is?Probably late May/early June
All the previous delays. And that was just a guess based on the August date for the first unit testing. It might make it's first appearance at rail live.Any idea on what the delay is?
I do think the GWR thing is rather bizarre. Why not simply take on some spare 25kV EMUs instead, and put the DMUs on the diesel routes? They are coming up spare all the time.
They are probably being added to LNorthwestern fleet as they were supposedly meant to be getting 8 additional units57301 dragged 319002 & 319008 to Wolverton today. Anyone know why?
From Long Marston: http://www.realtimetrains.co.uk/train/O95253/2018/05/04/advancedFrom?
Remember the DfT are funding the scheme in the absence of wiring between Oxenholme and Windermere, Bolton and Wigan and between Manchester and Stalybridge.
