Altfish
Don't like trams then. Hey ho!You're right. I was thinking of the inadequate heavy rail network. The Metrolink would barely meet the needs of Camberwick Green.
Picc-Vic link would have been great...and we'd still be waiting for it now. We're still waiting for proper funding for Piccadilly improvements, Oxford Road improvements, electrification projects, etc. Pacers are due to go in 2 or 3 years - wow! progress!Trams are fine, when they're not used as a low speed, low capacity substitute for what were (and should be) electrified heavy rail commuter lines, and when they don't foul up the railway infrastructure of the entire region by preventing longer-distance train services using lines. Manchester really should have had the Picc-Vic Link, or something quite like it, and a proper commuter rail network.
I have posted before that Picc-Vic was lost when Manchester politicians got the idea that Manchester wanted a "modern monorail" instead.Trams are fine, when they're not used as a low speed, low capacity substitute for what were (and should be) electrified heavy rail commuter lines, and when they don't foul up the railway infrastructure of the entire region by preventing longer-distance train services using lines. Manchester really should have had the Picc-Vic Link, or something quite like it, and a proper commuter rail network.
"...foul up the railway infrastructure of the entire region..." can you elaborate on that, please. One of the great benefits of Metrolink was that it freed up multiple paths into Oxford Road from Deansgate.
By the time they realised that monorails are only of use in Disneyland, all the available cash from central government had been scooped up by Liverpool, Newcastle and, I think, Sheffield, so Manchester had to look at trams instead.
Without research, I would have difficulty tieing down precise dates.I remember reading about a monorail plan for Manchester when I was young but my recollection is that if was from the 1960s, before Picc-Vic. So it would be interesting to know the date of the monorail plan referred to by furnessvale.
You really don't like trams do you.While at the same time causing CLC services to Chester to have to take a magical mystery tour via Stockport, adding further to congestion there. Rather than learning from.this schoolboy error, TfGM, who seem to want to turn most of the northwest into dormitory suburbs without any idea about the transport infrastructure that would be needed to do that, now propose repeating it on the New Mills Central and Atherton lines, and by the sounds of things on the CLC Warrington route too.
I appreciate the financial and ideological constraints that Metrolink arose from. However, this should not be an excuse to pretend that it is actually desirable to replace whole swathes of the heavy rail network with it, regardless of the impact on longer distance services.
New Mills Central was certainly selected as a full metro line using one of the two available lines, leaving the other line as a single line to be shared by Sheffield services and freight.You really don't like trams do you.
You've just been complaining that they don't want to do anything with Warrington - at least be consistent.
Must say the Connection to Stockport from the mid-Cheshire line has suited me and many others well, I'll be using it this morning to catch a Wolverhampton train from Stockport.
You obviously know a lot about TfGM as even the most outlandish proposals for Tram-Train don't include New Mills and Atherton. Marple and Glossop are the only ones I've heard.
Edinburgh has demonstrated that guided busway can be converted to tramline.You're being very harsh, I have to say. Getting Leigh back on the railway map should have been trams, far cheaper in the long run than traditional heavy rail, and far better than the misguided guided busway, or whatever unfortunate events has befallen the good people of southern Wigan.
Edinburgh has proven a lot about trams in general, and not all of it good!Edinburgh has demonstrated that guided busway can be converted to tramline.
To be fair, most of the problems were management rather than engineering/technical.Edinburgh has proven a lot about trams in general, and not all of it good!
If you go to Karlsruhe in Germany there are tram-trains running on routes of over 100km, mostly former train services which have had an increase in frequency and through service to the city centre, resulting in big increases in useage.It is only in this country that we decided to replace heavy rail with trams, because we had a government reluctant to invest properly in public transport.
That was the original proposal in about 1990. Tram-train, with shared running as you suggest, has been the preferred option since 2004 to my knowledge (I've been involved in at least three feasibility studies since then). I'm not aware of any suggestion of running trams or tram-trains as far out as New Mills.The proposal for Metrolinkifying Rose Hill Marple involved reducing the line to New Mills Central to 1 track in the vicinity of Romilley, mostly it seems because TfGM's planners can't wrap their heads around the less disruptive option of trams running on heavy rail on the short shared stretch.
Tram-train would avoid any of these situations that you don't like ... and yet you don't seem to be in favour of tram-train. So do you have a better solution?I suspect the Germans implemented tram-train as a resoonse to a specific need in a relatively small city, rather than to avoid giving an urban area of 2.8 million people a proper commuter rail service.
I have seen somewhere a proposal involving singling the heavy rail line, and a single tram line, between Romilley andbthe junction for Rose Hill. There is precedent for such an arse-witted idea between Navigation Rd and Stockport, and on that stretch of the Oldham line where Metrolink negotiates a chicane to allow the occasional train in and out of a waste depot. TfL seem to hate heavy rail so much that they cannot abide the notion of their lovely trams coming into contact with it.
Northern stoppers towards Liverpool do get looped at Glazebrook and this happened to me yesterday. If fact two successive trains were looped to allow late-running EMR trains to pass. The guard said this is not uncommon. I agree that getting Trafford Park freights out of Oxford Road/Piccadilly would be a great benefit but am struggling to see how it can be done as the CLC is basically "full". Maybe a swing bridge over/tunnel under the Ship Canal to join the Weaste branch to Eccles!It's unusual for a passenger train to be "looped" as even with the best signalling it would have a wait of 5min or so. I understand a late-running CLC train could be looped at Glazebrook or (westbound) can take the slow line at South Parkway so the following fast can overtake. But it's still a critical route with a lot of potential for late trains to delay others.
It may be more likely to happen in the nearly two years since the post you quoted.Northern stoppers towards Liverpool do get looped at Glazebrook and this happened to me yesterday. If fact two successive trains were looped to allow late-running EMR trains to pass. The guard said this is not uncommon. I agree that getting Trafford Park freights out of Oxford Road/Piccadilly would be a great benefit but am struggling to see how it can be done as the CLC is basically "full". Maybe a swing bridge over/tunnel under the Ship Canal to join the Weaste branch to Eccles!
But then you'd have two late trains...I would imagine if Network Rail looped an on time stopper for a late running express they would also be liable for a claim from the TOC for the bill.
As others have said, it’s pretty common for the stopper to be looked at Glazebrook, on occasions for both the Norwich and the following semi-fast to pass. It’s entirely within the signalman’s control - sometimes Control will intervene and ask for things to be done a certain way, but rarely in a case like this in my experience. There’ll sometimes be a specific regulating policy, e.g. recess the stopper if it’ll be delayed by fewer than x minutes. The delay minutes (“the bill”) will be attributed to whatever the root cause of the delay to the express was.In my experience it seems the decision to loop trains, especially late running passenger trains where you have multiple operators (or even sometimes just a single one), is out of the signallers control - unless they are specifically asked by the a TOC for regulation. In the case of the CLC and the Glazebrook loop, the majority of the trains are usually late anyway so it wouldn't make much difference, so it doesn't seem they bother often. I would imagine if Network Rail looped an on time stopper for a late running express they would also be liable for a claim from the TOC for the bill. The wonders of the modern railway system.
A couple of times in many years of Liverpool<->Manchester commuting I saw CLC stoppers looped at Hunts Cross to allow an eastbound express to pass. On one weird occasion the stopper was on the main line while the express went through the loop. And only slightly off topic: Yesterday I was on a Crewe - Lime Street stopper looped at Earlestown for a Trans-Pennine express to pass.As others have said, it’s pretty common for the stopper to be looked at Glazebrook, on occasions for both the Norwich and the following semi-fast to pass. It’s entirely within the signalman’s control - sometimes Control will intervene and ask for things to be done a certain way, but rarely in a case like this in my experience. There’ll sometimes be a specific regulating policy, e.g. recess the stopper if it’ll be delayed by fewer than x minutes. The delay minutes (“the bill”) will be attributed to whatever the root cause of the delay to the express was.
I’ve never seen the stopper regulated at Hunts Cross (it’s usually put away on the slow lines between Wavertree Jn and Allerton, although once it ran fast line whilst we were put around it slow line - it doesn’t really make much difference time-wise). I guess it’s pretty difficult to do it at Hunts Cross without interfering with Merseyrail - presumably that’s why the fast was put over the electric line in your example, so that it wasn’t blocked for so long?A couple of times in many years of Liverpool<->Manchester commuting I saw CLC stoppers looped at Hunts Cross to allow an eastbound express to pass. On one weird occasion the stopper was on the main line while the express went through the loop. And only slightly off topic: Yesterday I was on a Crewe - Lime Street stopper looped at Earlestown for a Trans-Pennine express to pass.
