BRX
- Joined
- 20 Oct 2008
- Messages
- 3,638
Can HSTs be retrofitted to stop them spraying poo everywhere? I suspect that their exemption from this requirement may be expiring??
Yes they can, and some will be.
I have been told that Scotrail did a questionnaire about what train they would like to work through to Inverness and so forth. And the public said they liked the VTEC HST to Inverness than 170's as they would be more quieter and less compacted as they are 9 coaches not 3 or 4 coaches. Virgin took this into account as there would be less coaches to Inverness as it would only be a 5 coach Bi-mode set. I hope they continue to use them after 2020 even though it will only be plug door.I hope so, but I wouldn't get my hopes up too much.
Are bi-modes cleared for all routes operated by VTEC or are there some routes where they aren't?
If they are cleared then the company may be prepared to use a sub-optimal path if the concerns are just performance related, but it's possible that option may not be available to them.
Route knowledge, stabling and maintenance, rolling stock utilisation and staffing issues (crew base in London) come to mind.ou seem hung up on issues about the route it runs on. What would be the practical problems caused by it being the only XC train running between York and London?
Of course there may be some that I am not aware of, and which would trump the rolling stock benefits.
And what are the benefits again?
Couple it up to a DRS 68 at Perth or Edinburgh.........which is what a LHCS with an electric loco could have done at much much lesser cost...
There not known as Daft for nothing.
With regards to electrifying to Perth, NR needs to get on and complete what its supposed to electrifying first (i.e. EGIP) before even thinking about further routes.
Neither of you have clearly ever used the Chieftain - it's one of VTEC's most profitable trains
Nottingham-Cardiffs are basically the same as they were 20 years ago but with a misleading sheen of Intercity on the advertising
leads to the question of whether it makes sense to have Inverness-London as part of the EC franchise. Perhaps it would be more sensible to hand it over to Crosscountry, for example.
I'm don't want the HC to be run with a Voyager any more than I want it to terminate at Edinburgh, neither of which things I proposed. It was a purely hypothetical musing in response to tbtc's post commenting that the requirements for the Highland section of its run were different to all of the rest of the EC network.
I simply argue that the ideal train for the HC would be similar to the ideal train for many of XC's long distance routes. In a scenario where XC procured a batch of such trains, I think there would be a case for considering moving the service into that franchise.
I could equally say that aside from spending a little more than half of its time on their core route, nothing else about it fits into the EC model.
When the HC was introduced, prior to electrification of the ECML, HSTs were in charge of services on that line and it obviously made sense to extend some of those north of Edinburgh. Times have changed, and the ECML is a primarily electric operation, leaving the north-of Edinburgh services as the odd-ones out. I don't see any compelling reason why those services should necessarily continue to be run by the same operator as the principle London-Edinburgh ones. The ECML already has multiple operators, several of which also operate intercity services into KX. There's no more logic in Inverness services being operated by the main EC franchise than there is in those currently run by Grand Central or Hull Trains for example.
So you're against connections to cities which don't fit the catchment of the brand itself? So, in theory, you would be completely axing Inverness, Aberdeen, Hull, Skipton, Lincoln, Harrogate, Bradford, Sunderland, Glasgow - from VTEC services under your own analogy?
XC would need a London crew base for one service a day
If you *really* wanted to transfer the service to another operator it would make more sense of it to be either VTWC and run down the WCML (fits into the London to... and they operate Voyagers) or Scotrail (since it is, effectively Inverness to Edinburgh and Edinburgh to London) though this would have made more sense before CS was hived off as a new franchise.
And rename it The Clansman!
Leeds-London is a core GR route so it fits into their operation. Leeds-London isn't a XC route so we're adding another 'odd' route into their operation.No need – IIRC the Chieftain duty works a morning service from Neville Hill to Kings Cross (can’t remember whether it’s Harrogate or Hull or Lincoln) then north from Kings Cross to Inverness during the daytime – the following day it works south from Inverness to Kings Cross in time to work a tea time service that finishes at Neville Hill (again, could be Harrogate or Hull or Lincoln, doesn’t really matter which one – the point is that it’s a duty that starts in Leeds and finishes in Inverness, then starts in Inverness and finishes in Leeds).
There are many reasons against giving the Chieftain to XC but a London crew base isn’t one of them.
Because it's such a long route that there's not much room for later/earlier services.Interesting that there's never been any serious suggestion of increased provision on the Inverness to London corridor, given how apparently profitable the Chieftain is.
An extra service as far as Stirling, sure, but no further.
That would require an Edinburgh-Inverness forward working in the morning. Not necessarily a show-stopper but it does step on Scotrail's toes, so to speak.It would be feasible and useful to have an Inverness-London leaving around midday (allowing connections from disparate parts of the highlands, whether by train or other modes) and getting to London mid evening. A mirror service to the nothbound chieftain, if you like.
I'm probably going to get shot down for this, but we're in "what-if" land at the moment anyway - how about Scotrail running the Chieftain, and perhaps the Aberdeen - Kings Cross services?
They will have HSTs, so crews will be trained. A couple of longer sets will be required, but I can't see that being an issue. That would allow whoever happens to be in charge of the East Coast franchise to concentrate on Edinburgh - London and the various other places inbetween.
There's some logic to it, the main sticking point is that rail services in England are specified by the DfT and those in Scotland by Transport Scotland.I'm probably going to get shot down for this, but we're in "what-if" land at the moment anyway - how about Scotrail running the Chieftain, and perhaps the Aberdeen - Kings Cross services?
2. Because the Chieftain is a 'proper' train at a business-friendly time, it is the train of choice for business traffic to both Edinburgh and Glasgow.
1. I believe that once the wires reach Stirling, there are plans for WC services.
One VTWC Stirling to Euston via Birmingham per day is something that I might well use to Brum, or even Liverpool or Manchester, so long as it doesn't start out at silly o'clock.Eh?
Although I recognise no-one is proposing axing the service, part of the reason the Chieftain is so popular is that it runs through 3 major cities en route, one of which is a Scotrail catchment which sees passengers aim specifically for the Chieftain to take advantage of its premium service. Although lots of passengers head through to London, let's be honest, how many passengers would use a WCML service which:
1) Would not be much quicker than ECML services
2) Doesn't pass through hubs which bare any sort of significance as Edinburgh, Newcastle and York - There are just as much York and Newcastle passengers from North of Edinburgh than there is London going by the reservations onboard. Preston and Crewe are your best bets on the West Coast - anything else would just be a time waster.
The only untapped at transport link which I reckon might be of some benefit would be Birmingham, which currently has an awful direct connection from North of Edinburgh, mainly due to the route being so long and the TOC's fares being the most expensive.
Just curious about the idea of WC services as I've not heard of the suggestions before - presuming you're speaking in the context of cross-border services?
I'd love to know how many people are actually on that thing at 0526. It's like the VTEC direct Sunderland train which goes at a similar time, you can't help but think that they're only doing it so that they can say that they'll get you there before anything you can achieve by using the competition.
Doing the HC in July from Edinburgh to Inverness, having got a 91 up from London
Better not be the ex EMT set or I'll go berserk!
Isn't the Chieftain always covered by a Scottish crew north of Edinburgh? Fair enough they work for VTEC rather than Scotrail, but I've never been served by anyone other than a person with a Scottish accent. Often the same man's on the trolley to the extent that I thought they're based in Inverness and just do a there and back to Waverley each day?The issue of the Highland Chieftain being served using only East Coast crews has only arisen since Privatisation prior to that ut was coovered by Scottish based crews in Scotland.
Now there is no reason why it couldn't be the same today if Scotrail were paid an appropriate sum of money by East Coast and the training given to the appropriate crews to operate HSTs. However East Coast have decided its cheaper / easier to have lodging turns than hire Scotrail crew.
NXEA and GN had a similar arrangement to cover NXEA Cambridge to Kings Lynn services but this fell through many years ago.
Pretty sure it's just the Edinburgh-based crews that work it, with an overnight out at Inverness.
