Or is it always a driver looking out for a waving passenger?
Correct me if I'm wrong if it's a soft toot then it means the driver will stop for you however if the train is not scheduled to call there then the driver will sound a louder sustained tone.The instruction is to make ones intent to join the train clear to the driver. Which usually means stand on the platform and stick your arm out like you're hailing a bus. Most drivers will (I believe) toot the horn to acknowledge that they've seen you.
As above there are some plans to introduce a push button system as a trial but for now the traditional methods hold sway.
Some lines in Switzerland have had this system for some years, one is on a narrow gauge line in the Jura region if I recall correctly. Pressing the button switches on a suitable signal at the lineside for the driver to see. It also means that the system works in the dark.
Do any request stops have anything like a button to press on the platform to make the train stop at the station? Or is it always a driver looking out for a waving passenger?
Trainspotters?if I see anybody whatsoever on the platform I stop.
Like any other signal failure then.The problem I can see why this system is in case of a failure the driver will wrongly think .....
Easy enough to design a signal so that it fails in the 'stop' position. Old-style semaphores make this easy of course, but it can be done with coloured lights too.The problem I can see why this system is in case of a failure the driver will wrongly think that nobody is waiting and proceed at a higher speed that wouldn’t allow them to stop by the time they realise someone is waiting.
Yep even spotters. I let the guard have it out with them then. They shouldn’t be in the platform unless they intend to board
colour lights signals do fail safeEasy enough to design a signal so that it fails in the 'stop' position. Old-style semaphores make this easy of course, but it can be done with coloured lights too.
I imagine it’s more difficult at request stops that are either side of a passing loop on a single line, passengers could be waiting for a train going the other direction. This seems to be quite common on the Cambrian Coast, and I imagine Perranwell before it lost its request stop status.Yep even spotters. I let the guard have it out with them then. They shouldn’t be in the platform unless they intend to board
The barrow crossing at Haverfordwest station has "cross only when light shows" indications, and they look like they still work. However, you have to walk past a 'passengers must not cross the line' sign to get to the barrow crossing. Are there even any passenger trains booked to use the far platform at Haverfordwest (perhaps to maintain crew knowledge) or is it only the oil trains that run through there now?Easiest way to do it would be light on - don't stop, light off - stop. A bit like those "cross only when light shows" indications on foot crossings (not sure there's any of those left now).
But for a request stop with a few trains a day, what happens when there are two trains close to each other? Example: Kildonan is a request stop with a single platform. The up and down trains stop within 30 minutes of each other. That's easily enough time for someone to turn up a bit early wanting a train to go one way instead of the other. Then one gets to Braystones with a 15 minute gap between up and down trains. What happens then? Does one still get a talking to from the guard even though you're just standing on the platform waiting for the other service?
Thank you for that interesting reply; I didn't realise there was anything that terminated at Haverfordwest.There are a couple booked uses of the 2nd platform at Haverfordwest, 04:50 Carmarthen to Milford Haven (Monday to Saturdays), 0535 Cardiff Central to Milford Haven on Monday - Fridays.
On Sundays it is 0933 Newport (South Wales) to Milford Haven & 1837 Swansea to Haverfordwest.
The Rules Of The Plan / Timetable Planning Rules document I downloaded form the network rail website states that Clarbeston Road to Milford Haven is TCB but timed as AB (I assume TCB is Track Curcuit Block and AB is Absolute Block). Not sure if that effects RTT updates. The Waterston and Robeston refinery branches (neither are still working refineries) are worked under the control of a person in charge (the signaller at Clarbeston Road).However if they actually go via platform 2 probably depends on an oil train coming the other way. IIRC that part of the network is manual signalling so won't update on RTT if a service goes via platform 1 instead of P2.
Hey, I’m just being safe rather than sorry. Then I know I haven’t left anyone behind and it’s booked into the timetable anyway. A talking to off the guard doesn’t have to be a “telling off” either. Could just be offering informationBut for a request stop with a few trains a day, what happens when there are two trains close to each other? Example: Kildonan is a request stop with a single platform. The up and down trains stop within 30 minutes of each other. That's easily enough time for someone to turn up a bit early wanting a train to go one way instead of the other. Then one gets to Braystones with a 15 minute gap between up and down trains. What happens then? Does one still get a talking to from the guard even though you're just standing on the platform waiting for the other service?
