ScotRail HST Introduction - Updates & Discussion
Railperf
30 Oct 2017
Which route?
The full monty. So Edinburgh to Aberdeen and back. Edinburgh to Inverness return, Glasgow to Inverness and return, and Glasgow to Aberdeen and return. Looks like i will be chopping and changing at Perth quite a bit to get the best itinerary in order to cover the 3 major routes. Plus a blast from Edinburgh to Glasgow and back aboard the 385's.
chuff chuff
25 Sep 2018
I've managed a few 0-100 runs your looking at 2 1/4 miles and two 1/2 miles or other way round,did post it on lner azuma thread.
Railperf
30 Oct 2017
Pretty much the case - only sustained Notch 5 we need is leaving Inverness & Carrbridge. Even then, line speed is still easily achievable fairly quickly. It's night & day compared to a 170/158...
That's no surprise. a 158/170 can't even match an 8 coach HST, and a 6-car is light years ahead. So your Scotrail 4-coach versions are going to accelerate faster than Class 385 EMU's - well almost!
jingsmonty
21 Oct 2014
Inverness
which stations were those from?
do you suffer much trouble with wheels slipping?
Not really - same as any train, early morning mist can induce wheelslip, as can light drizzly rain. I've not driven an HST during the autumn, though..
Whenever I've had wheelslip, I've found out that you can gain reasonable acceleration in notch 3 or 4 (stiil better than a DMU flat out) until more speed is built up. Again, though, I've no experience with an HST during leaf fall season!
There's a 'bothy rumour' doing the rounds just now about Scotrail power cars being retrofitted with sanding equipment - how true this is, I don't know....
jingsmonty
21 Oct 2014
Inverness
As a 'real world' comparison between a 4 coach HST & a 170 or 158, when leaving Inverness & climbing up to Culloden viaduct & Moy loop, you'll be on full power in a DMU the whole way (about 16/17 mins), doing about 55 mph (170) or 50ish (158) up to Culloden, maybe briefly touching 70 on Culloden viaduct, then down to 50/55 climbing to Moy.
An HST will easily do 80 mph (line speed) to Culloden viaduct (notching back on the way UP the hill) & 75 mph from Culloden to Moy (line speed), with notching back required here too.
It's quite a machine...!
Railperf
30 Oct 2017
In terms of station to station performance - how much of a potential improvement is this over the other traction? Have you had a chance to assess this?
Railperf
30 Oct 2017
Carnoustie heading south would be another good one for it.You really need to pick your day for it if you're going for it.
probably i will have to book an advance ticket - so i will have to take whatever weather comes on the day!!Lol.
jingsmonty
21 Oct 2014
Inverness
It's a bit hit & miss just now, mainly due to the horrendous station dwell times with the 'classic' slam door stock. The 'SP' differential speeds on the HML don't help either.
The potential is definetly there, but some in-depth review of line speeds & the refurbished sets will be needed to fully realise it
Railperf
30 Oct 2017
Checked the WTT, and not many HSTs stop at Carnoustie. So Arbroath looking the best bet for a decent 0-100.
BRX
20 Oct 2008
The performance required of an HST & the fact that the HST engines are 'high revving' engines, as far as rail use goes (although 1500 rpm isn't particularly high, it's higher than most) - I think a standard loco engine tops out at around 850/950 rpm? I may be wrong...
Are they higher revving than a DMU engine though? (A very quick google suggests around 2000rpm for a class 158 engine)
I can see that in frontline use an HST is going to be going between high revs and idle quite a bit, the high revs being used to get moving with the maximum acceleration, but isn't the same true of a DMU especially on a line like the HML? My subjective passenger experience of 170s and 158s on the HML is that the engines are frequently being hammered at full tilt to make it up gradients etc.
ScotTrains
13 Nov 2014
Railperf
30 Oct 2017
Yes...just checking the sectional appendix and on average the sprinter limits are 10mph above HST permitted speeds!
jingsmonty
21 Oct 2014
Inverness
I"m not sure about the max revs of DMU engines, but I can certainly attest to fact that they spend far, far longer at full throttle than an HST on the HML!
An HST only needs notch 5 (normally) to reach line speed, an intermediate notch is usually enough to hold line speed, once you reach it (evrn on a rising gradient). Wheras a DMU is pretty much on full power from, for example, Blair Atholl to Drumochter summit.
I've heard of a Scotrail HST running on one power car maintaining line speed on this part of the HML, which, if true, is truly impressive
hwl
5 Feb 2012
An HST only needs notch 5 (normally) to reach line speed, an intermediate notch is usually enough to hold line speed, once you reach it (evrn on a rising gradient). Whereas a DMU is pretty much on full power from, for example, Blair Atholl to Drumochter summit.
Notch 5 is set at 1500rpm, 350rpm below the max for the engine - any more power and the traction motors will melt trying to use it!
Typical underfloor DMU engines are 2.1-2.4L per cylinder but the MTU HST engine is 4.77l/cylinder
As regards circa 900rpm max you are thinking of older low speed engines such as EMD's 710 2 stroke engine (11.63L/ cylinder) most modern locomotive engines are medium speed designs with lower displacements e.g. CATs C175 in the 68s 5.3l/cylinder (max 1800rpm) or the MTU 4000s.
The original Valenta engines were very ahead of their time.
hexagon789
2 Sep 2016
1500rpm for an HST
1900rpm for a 170
2100rpm for a 158 (all ScotRail's ones being 350hp examples)
hexagon789
2 Sep 2016
Cheers - every day's a schoolday! I was thinking of the sort of power units fitted to older locos, such as Class 47s
I think 47s are 750rpm IIRC. Generally older Diesel-Electric locos tend to have slower-speed engines, multiple units and modern locos are typically higher-speed from what I gather.
Railperf
30 Oct 2017
There are 10 Scotrail diagrams showing in the 125 group website. Are all of these active.? How many refurbed and classic sets do Scotrail now have?
hexagon789
2 Sep 2016
Not sure about diagrams, it seems to vary a lot. I believe there are 10 Classic (to be increased to 13) and 3 Refurbed sets. Only two of the latter in passenger service.
mcmad
11 Mar 2015
I thought only the original refurb set was in use with the other 2 being used for training?
Highlandspring
14 Oct 2017
HA25 and HA26 have both been out in passenger traffic at the same time. HA24 is yet to see revenue service though.
Class83
8 Jun 2012
Given the final plan is for 27 sets, are there not more classic sets available until the refurbs are complete to free up 170s and 158s? It would surely be possible to send 5 sets to Scotland then as one refurb is complete send a Classic set south?
jingsmonty
21 Oct 2014
Inverness
I've heard there's a shortage of TGS vehicles, not sure if that's accurate or not?
Although refurbished sets don't use TGS coaches, the Classic sets do
