You don't really know what you're talking about, do you?I was in Germany recently and saw a lots of Loco haulled trains, mainly double deck stock worked push pull by a loco. With double deck stock it is probaby difficult or imposible to make a motor coach as there is nowhere to put control equipment as the lower deck floor is only just above rail level and the celling of the upper deck at the loading guage limit. The only space where equipment can be put is in the single deck section above the bogies and this is probably used for AC equipment.
The Germans use lots of loco-hauled double-deck stock primarily because the locomotives are available, either because they outlasted the stock they were originally hauling or because they became surplus thanks to shifts in the needs of freight locomotives. If they want to switch to double-deck EMUs, there is no shortage of manufacturers which would be happy to supply them.
Loco-hauled double-deck rolling stock is quite plentiful in North America, primarily because many of the areas using it for commuter rail are mixed-traffic lines also used by double-stack container trains (which do not cooperate happily with electrification) and the commuter rail systems in the north-east of the USA use them ahead of EMUs to cater for the fact that some lines rely on diesel haulage.
What's the alternative though? There's currently no capacity to accomodate everyone who wants to travel on an off-peak ticket at rush hour, and won't be for many years to come (if ever).
People elsewhere cope with "peak" restrictions, I don't know why this is such an ordeal for those in northern England.
How often do you travel on the S&C? If Northern are unable to provide two class 158's they always tend to try and ensure that a class 153 is attached to a class 158, especially in the summer months. The Northern Dales had a decent summer this year and even with two class 158's the trains were often full and standing.
Foscl say that sometimes 'block' bookings are turned down because of insufficient stock, usually during the summer.
However, when you look at the yards of locos, and see a sizeable proportion of a class that you're travelling behind, you can't help but imagine the wastage - although of course, ordering new locomotives from Alstom is giving business to another french company in a time when the french economy needs all the help it can get
I did not say it was impossible to have a double deck EMU. With 1.5KV DC it would be possible to pack the control equipment in the roof over the bogies and under seats stairs etc. Construction of such a unit would not be easy as a compact equipment design would be required and equipment distributed in several locations with interconnecting wiring. Before the advent of modern low maintance electronics this would probably not have been possible, or at least very difficult.
However the Germans have the problem of requiring a massive heavy transformer which would either take up passenger space or require some other arrangment such as a single deck tranformer car (like the French double deck TGV). The compromises required to do this probably make loco hauled push pull operation an attractive alternative.
I don't follow this. It is not impossible to have double deck EMU's because I have been on them in three countries across two continents. Is there an issue specific to Germany?
I think he's saying that the 25KV AC OHLE supply may be an issue.
TGV Duplex is really a top and tail job with power cars that are single height, and the Dutch double deck EMU uses 1.5KV DC, so doesn't need a big heavy transformer.
That said, nothing is impossible, as I'm sure there are RER double deck EMUs that operate dual voltage at both 1.5KV DC and 25KV AC
What OHLE supply do they use on the Cote D'Azur? There are plenty of double deck EMU's running down there, which in turn replaced the loco hauled single deck push pull stock.
I am not aware of any European countries that are actually still buying LHCS and loco's. MU's are winning, and I feel excluding sleepers and railtours, I feel that they will be gone in this country within my lifetime definitely, and probably almost extinct on the continent too.
DB Fernverkehr ordered 27 new Bombardier Traxx class 146.2 locos in January 2011 to work with 137 new Bombardier Twindexx Vario coaches on Intercity services. These should have entered service in December 2013. DB also ordered an additional 32 class 146 locos in August 2012 for delivery during 2014, to replace older electric locos working with existing push-pull coaching stock.I am not aware of any European countries that are actually still buying LHCS and loco's. MU's are winning, and I feel excluding sleepers and railtours, I feel that they will be gone in this country within my lifetime definitely, and probably almost extinct on the continent too.
Deutsche Bahn have already ordered double-deck electric multiple units on Bombardiers Twindexx platform, which should be seeing delivery about now:I did not say it was impossible to have a double deck EMU. With 1.5KV DC it would be possible to pack the control equipment in the roof over the bogies and under seats stairs etc. Construction of such a unit would not be easy as a compact equipment design would be required and equipment distributed in several locations with interconnecting wiring. Before the advent of modern low maintance electronics this would probably not have been possible, or at least very difficult.
Just to return to this, there is an issue in Germany with AC stock: The line frequency is 16 2/3Hz * (i.e. 1/3 of the nominal industrial 50Hz supply). this means that the transformer required to convert the 15kV line voltage down to a medium voltage supply for traction (c. 1kV) needs very high inductance and a heavy iron core. A 50Hz transformer is much lighter and smaller which was a consequential benefit of choosing the higher frequency across Europe for all new schemes. Austria, Switerland, Sweden and Norway also have low frequency ac electrified railways. It is the price that those countries paid for early adoption of ac powered traction.
So if Bombardier (and others) have produced designs that don't commit large amounts of potential passenger space to power supply equipment, they must have adopted some newer technology in the voltage trasformation kit.
* The three alpine countries (Germany, Austria and Switzerland) have now moved the frequency to 16.7Hz which gives a benefit with the LF conversion equipment.
