dannypye9999
- Joined
- 28 Jun 2013
- Messages
- 392
Out of interest is there any other country using the same trams as they use on supertram. I'm always interested in different tram networks using the same make of trams as here.
I believe the design itself is unique but Duewag supplied trams to a wide range of cities over the decades until taken over by Siemens.Out of interest is there any other country using the same trams as they use on supertram. I'm always interested in different tram networks using the same make of trams as here.
I do think that rather than being replaced, the Duewags should be refurbished, new undercarriage equipment, shot blasted exteriors, new seats inside - high backed secular seating, get them in to Travel South Yorkshire livery and tidy up the scuffed interior walls. Update the systems so that newer designs of components can be sourced. Repair the corrosion and paint with anti-corrosion paint.
If they didn't have any life left in them, they wouldn't have just spent hundreds of pounds repairing 105 at Brodie's, which required a new front nose cone to be developed I believe.
The Supertrams need replacement. But as alluded to in other posts, this requires funding which currently isn’t available.It may be possible to refurbish them but it’s the long term costs associated with keeping them and maintaining them. The cost of new trams will likely be significantly more than any refurbishment would cost, but the costs associated with maintenance and general running costs will be lower so over time it will balance out as you’ll still need a new fleet sometime soon.
Good point, unless it’s on both lines.Freezing temperatures have cause a rail to break so no trams can run between Cathedral and Malin Bridge/Middlewood.
x.com
x.com
Not sure where the break is but surely they can run a partial service on both sides of the work?
Cathedral to Malin Bridge is mostly on-street running. It would not be possible to have a tram operating on the wrong side of the road, quite dangerous actually.Freezing temperatures have cause a rail to break so no trams can run between Cathedral and Malin Bridge/Middlewood.
x.com
x.com
Interesting, would it be possible to explain to an interested layman please?Cathedral to Malin Bridge is mostly on-street running. It would not be possible to have a tram operating on the wrong side of the road, quite dangerous actually.
Put simply, road traffic would be coming in the opposite direction, against the direction of travel, which could cause collisions. The roads would have to be closed effectively to all other traffic.Interesting, would it be possible to explain to an interested layman please?
I assume it’s not signalled for wrong lin running plus junctions.
Sounds good to mePut simply, road traffic would be coming in the opposite direction, against the direction of travel, which could cause collisions. The roads would have to be closed effectively to all other traffic.
The description they've now posted of bus diversions around the repair work suggests that the break is on the "towards-town" side of West Street, so it would theoretically be possible for them to send a few trams out to Middlewood/Malin Bridge and run a shuttle service between there and Shalesmoor (or even University, like they did in previous rail replacement closures, with single-line working up Netherthorpe Road), but that would involve stabling units out at the termini overnight and they wouldn't be able to bring them back to the depot if anything went wrong.Not sure where the break is but surely they can run a partial service on both sides of the work?
During planned engineering Trams have been 'stored' overnight in the past in the Brook Hill roundabout 'tunnel' and Middlewood to run shuttles from the Shalesmoor stop(crossover). They could and have run from University on the wrong road to the Xover at Shalesmoor. There is no place for bustitutes at Univresity, but there are buses every 5 minutes from Cathedral to University(51,52, 95 and 120).The description they've now posted of bus diversions around the repair work suggests that the break is on the "towards-town" side of West Street, so it would theoretically be possible for them to send a few trams out to Middlewood/Malin Bridge and run a shuttle service between there and Shalesmoor (or even University, like they did in previous rail replacement closures, with single-line working up Netherthorpe Road), but that would involve stabling units out at the termini overnight and they wouldn't be able to bring them back to the depot if anything went wrong.
How many trams are used to operate the Halfway shuttle, please, and where are they stabled overnight?The Blue and Purple route still impacted by the broken rail on Park Grange Road. Trams running Malin Bridge to Sheffield Station and Gleadless Townend to Halfway with a bus running Fitzalan Square to Gleadless Townend.
Apparrently, there are two that are stuck at the Halfway end. They tend to be stabled at Halfway terminus overnight.How many trams are used to operate the Halfway shuttle, and where are they stabled overnight?
Just showing a direct service might make people think it avoids the city centre, which is where most of them will be going.I was in Sheffield on Friday and the yellow Meadowhall service i was on terminated at Cathedral then formed a Halfway service. Wouldn't it have made more sense to just advertise them Meadowhall to Halfway rather than forcing passengers off the trams into the -10*C freezing cold at Ponds Forge then back onto the same tram?
I agree as painful as it is to say. It either needs to be improved or give up.Better off a shutting the system and use buses. The whole network is run down, looks tatty, and no prospect of any real money getting spent.
It really is a shambolic and extremely run down system. There's no TLC to any of its assets, mostly the stops. When something goes wrong it's never a speedy fix. Sad really when it's compared to Manchester for example, from a passenger perspective. I used to work for the trams in Sheffield as a conductor in 2003. There was pride in the network, everything was tidy and well maintained.I agree as painful as it is to say. It either needs to be improved or give up.
Hasn't ridership continually gone down even before COVID. Although I don't think they are the only tram system with struggles around passenger growth.
I remember the machines. they were complicated & fiddly to use & vandalised very quickly. also with no conductor late evening's wasn't pleasant as anti social behaviour could be a problem.When Supertram first started it was driver only operation, it was only when they discovered people were riding for free that conductors were employed. The ticketing to start with involved two machines, buy the ticket from one then validate it in the other, it took ages and I nearly missed the first tram from Meadowhall on the opening day!
Any recent news on the planned Magna tram stop? There’s no sign of any activity on the ground.
Some of their newer staff are very rude. The information screens have started to fail regularly. On my last visit to Sheffield, there was nothing displaying on the PIS and after a 20 minute wait, I gathered one wasn't going to turn up and took the bus. II agree as painful as it is to say. It either needs to be improved or give up.
