Should the class 60 be fully restored to frontline service?
DownSouth
10 Dec 2011
From what I heard back in the early EWS days, words to the effect of "not using British traction" was touted about.
Fair enough. Remember that the new management at the time would have made that decision on two grounds:
1. their extensive experience with superior non-British locos.
2. not being pressured to subsidise poorly performing local industries as is common among government railways around the world.
455driver
10 May 2010
Engine failure was the reason given by EWS why IKB was withdrawn in the first place.
Oh it was definitely engine failure, a conrod went through the side of the block, knocked the engine room door off and dented the bodyside. Quite a spectacular engine failure.
CosherB
23 Feb 2007
Northwich
My point was, though, does MAN provide sufficient engine parts to enable such a failure to be fixed (ie in this case, a new engine block etc)? I'd say that 60081 would be a long way down the queue for reactivation though .....
Peter Mugridge
8 Apr 2010
Epsom
If you need to build a whole new engine block wouldn't that fall foul of the emissions regulations?
alexl92
12 Oct 2014
In 2013 (I think), Railways Illustrated reported that DBS had recently stated that all 100 could be reactivated if necessary. Not sure if thats entirely true though.
alexl92
12 Oct 2014
Ooops, sorry, thought I'd kept up with this thread but missed that.
CosherB
23 Feb 2007
Northwich
Why would supplying a short engine fall foul of emissions regs? Component reuse from the dead engine would mean cylinder heads, pistons etc be recovered and used in the replacement engine.
DownSouth
10 Dec 2011
If, as Peter quite reasonably speculates, the engine block is defined as being the 'part' which carries the engine's identity (a serial number stamped into the casing?) for the purposes of the regulations, it is the one 'part' which cannot simply be replaced like all the others.
Were the identity of the engine not attached to a major component (ideally the engine block) then the regulations would be completely toothless, the way would be open for companies to buy in brand new non-compliant engines which do not comply with the regulations - so long as they buy them as "replacement parts."
An almost identical effect was previously observed in California, where a now-closed loophole allowed taxes to be evaded and otherwise non-compliant cars imported by "replacing" every part of an older car except the VIN plate.
CosherB
23 Feb 2007
Northwich
Ok, fair enough. Clearly the world is going mad if it's fine and dandy to import decades old loco engines from America and fit them in even older 47s!
DownSouth
10 Dec 2011
Does that still happen? Of course not, that had to stop before the EPA/EU Tier 2 rules came in.
I thought they were new-build 645 engines (which are still being produced today) in the Class 57 locos anyway, not used ones.
CosherB
23 Feb 2007
Northwich
My understanding is that the 57 has a refurbished EMD engine, and reconditioned alterator and traction motors from Class 56s. Definately not new build in any way, shape or form!
455driver
10 May 2010
Not for DMU engines it wont, I have seen some 'overhauled' engines where every major component has been changed, block, pistons, heads, fuel pump etc, it was still classed as an 'overhauled' engine.
Domh245
6 Apr 2013
nowhere
I suppose that all you need to prove that it's the same engine is the ID plate (or equivalent).
455driver
10 May 2010
I thought the engines were older (1950s) than the 47s they went it? (1960s)
Elecman
31 Dec 2013
Lancashire
Simply stamp the new block with the old block number,re use all other parts from the old engine (possibly requiring 1 new piston?) hey presto a refurbed engine
SpacePhoenix
18 Mar 2014
Well surely if it wasn't in service the engine wouldn't have been running??
A diesel loco might have its engine running whilst waiting for it's train to be loaded
Oh yes and under quite a bit of power at the time, lets just say it didn't take the driver long to realise he would need assistance! :lol:
Must have make a hell of a bang when it went. Would it have only been a matter of seconds after it happen that the driver would have suddenly found the engine has lost power?
ac6000cw
10 May 2014
Cambridge, UK
No - the 57/0 use 12-645E3 engines (first introduced in the late 1960s) and the later 57/3 & 57/6 use the more powerful 12-645F3B dating from late 1970s onwards.
The 1950s EMD diesel engine was the 567 series. The engine 'series' numbers relate to the cylinder capacity in cubic inches.
(I've often wondered where the refurbished/remanufactured engines in the 57's came from originally, since there are very few US locomotives using the V12 645s. The V16 has always been the standard EMD freight locomotive engine, there were 8,000+ V16 645 powered locos built for the US market alone versus a relative handful of V12 powered ones).
It's interesting that one of the major US railroads is rebuilding 25-year old GE Dash-8 locos, upgrading the 7FDL16 diesel engines with electronic fuel injection and split cooling systems to take them from Tier 0 to Tier 2 emissions compliance (and reduce the fuel consumption presumably, so less CO2 as well).
I wonder if this sort of emissions-improvement engine rebuilding/modification is allowed under EU emissions rules ?
DownSouth
10 Dec 2011
A decent number of GP and export locos used V12 645 engines.
I would guess that retired GP locos would have been where they came from, as operators could effectively do one-for-two replacement with modern locos in the 3+MW power range with AC traction became available late in the 1990s.
While the EPA emissions standards for non-road engines are copied by the EU, what is not harmonised is the regulations which rule the implementation of the standards. For example, I understand that the EU has deferred implementation of Tier 4 for rail vehicles, while it is now in force for the US domestic market.
Allowing engines to be upgraded to Tier 2 as in the NS rebuild program is a good pragmatic move by the EPA, and I wouldn't be surprised if there were grants available to help facilitate it. The Dash 8 series locos all had "Tier 0" engines (i.e. predating the standards, Tier 1 compliance came with the Dash 9 series) so upgrading them to Tier 2 is still better than having them keep running in original form - the C40-8 locos are very reliable and should be good for another 20+ years so the upgrade should save a lot of emissions over their remaining life.
Interestingly, the same NS upgrade program also includes rebuilding the short hood into a full-width nose.
Not necessarily, it depends on which emissions you are trying to control.
In the case of non-road diesel engines, the main effect of Tier 2 is to control the release of particulates. This is done using filters which have a negative effect on performance and therefore on fuel economy.
CosherB
23 Feb 2007
Northwich
WNXX reporting today that 15 Class 66s from DBS are being stored at Toton. Doubt we'll be seeing many/any more refurbished 60s for DBS use for a while..... :(
Kevin_Brum12
14 Jan 2015
Likely those stored 60's will become Christmas trees to keep the fleet going and will the first will be razor blades by New Years Day.
RichmondCommu
23 Feb 2010
Richmond, London
Well yes but it would still be in service.
This news will have dozens of teenage boys crying into their sleeps :)
SpacePhoenix
18 Mar 2014
Realistically with the news that some class 66s are going into store will we be looking at some class 60s being scrapped?
