Southeastern problems post timetable change
PGAT
13 Apr 2022
Selhurst
I don't think drivers sign Platforms 10-15? During times of disruption they always terminate at Platform 8
WizCastro197
12 May 2022
Reigate
When there are Hastings diverts, via Redhill and Croydon, do they change driver at either of these stations (Redhill, E.Croydon), as they terminate normally on Platform 10 I think. (I may well be incorrect).
ScotGG
3 Apr 2013
Tresspasser at Hither Green in the peak.
Yep. Seems to be something or other every day.
A slimmed down timetable and enforced changes now do seem to be causing issues with recovery and management from issues.
Horizon22
Jobs & Careers
8 Sep 2019
Which is odd because a slimmed down timetable tends to make service recovery easier generally as there is more capacity and less knock on impacts. That or the timetable was adjusted in a haphazard way but, given that it coincided with a national timetable change, I doubt it was.
Peregrine 4903
18 Aug 2019
The timetable isn't slimmed down in the peaks. I don't get why people don't understand that. And it's the same as May off peak in terms of service levels.
uglymonkey
10 Aug 2018
They have retimed my connection at London Bridge so my usual train misses it by 2 minutes! Meaning I have to get up 1/2 hour early for an earlier one ! Thanks !!!
williamn
22 May 2008
Travelled Wadhurst to London Bridge the other day. Train was due to attach to 4 carriages at Tunbridge Wells but there were problems with this and opening the doors, rectifying it seemed to include turning the train 'off and on' with us being pitched into pitch black with no warning in the tunnel. A member of staff said that attaching trains at Tunbridge Wells was historically an issue due to several carriages being in a tunnel, and that it had only been re-introduced with the new timetable.
We were delay by 20 mins and the train was terminated at Tombridge. The empty stock sat there for a further 20 mins delaying the service behind, which was in turn delayed by 20 mins and diverted into Cannon Street. I was over 40 mins late on an hour-long journey in the end.
theageofthetra
27 May 2012
Beckenham
It's due to the curvature of the platforms. It's why attachments were stopped there a few years back. Similarly at Cannon St. Idiotic it's been reintroduced
43066
24 Nov 2019
It has been for much of the day, though. The peak trains for some have also been slowed eg the ex Sevenoaks Ch+ stoppers all go via Lewisham rather than direct from HGR - LBG.
Overall it’s a significantly less comprehensive all day timetable on the Dartford lines, in particular, as noted above. I don’t agree with the comments suggesting it is fundamentally flawed, or attributing the infrastructure delays to it, but the criticisms are valid.
Not a Trespasser unfortunately.
Sorry to hear. ‘Tis the season :(
ComUtoR
13 Dec 2013
Not as bad as that but along those lines. Tis the season for sure.
Lots of people out there need help and some do silly things. Hopefully the person involved gets the support they need.
Peregrine 4903
18 Aug 2019
May timetable there were 4tph off peak on Bexleyheath line, 6tph off peak on Charlton line and 4tph off peak on Sidcup line which is the same as current timetable. In fact there are now 6tph between Dartford and Gravesend compared to the 4tph in May. Where is the cut?
43066
24 Nov 2019
Were those Hansard extracts upthread incorrect?
87015
3 Mar 2006
GEML/WCML/SR
With the same gaps, or are you being deliberately obtuse behind paper stats rather than reality? What was Dec 19?
WizCastro197
12 May 2022
Reigate
I assume delay repay has been filed?
Horizon22
Jobs & Careers
8 Sep 2019
That's what Southeastern said it was online - it's also what Southeastern MD said it was on Twitter - https://twitter.com/SteveWhiteRail/status/1618348205011521537
Dan, this is the second time that crowd control has been required at London Bridge recently. The last occasion was when a points failure caused disruption. Tonight’s disruption was due to an emergency call stopping all trains due to a trespasser. A review will be held tomorrow.
Anyway after the Hither Green incident, the "review" being referred to is severe overcrowding at London Bridge with risks of a crush. The amended timetable - no doubt somewhat dictated by the DfT - can't be helping and there's a few too many reports of overcrowding / delays / issues to just be plain bad luck but also I think you need to ask questions about how the platforms were able to get that busy without the station operator (Network Rail in this instance) implementing some more stringent crowd control. You should let people congegrate on the concourse and restrict access elsewhere, especially to platforms. That's crowd control 101
fusionblue
10 May 2012
Big problems tonight at London Bridge. Police having to be called due to dangerous crowding.
Many issues at play that are not the fault of south eastern but cutting services is adding to it.
The new timetable exacerbates other issues which have long existed. Those issues will continue to exist, but will now have a worse impact. Police rarely had to close London Bridge and we didn't see the sites of tonight.
The design at London Bridge for all the Southeastern platforms - particularly with train placements and stop markers - mean people bunch up and stop walking as soon as they reach the top of the escalator. The 8 car markers mean everyone bunch around the front doors (down end) and block the escalator, and the 10 car do the same at the up end. Meanwhile there is a LOT of unused "air space" above the escalators that potentially could have been platform space.
The original intended design for passenger flows was that people stayed downstairs until their train was on screen (and downstairs would remove the current train early to avoid rushing), but in reality people just go down one escalator and straight back up the other making the downstairs area largely pointless as a "waiting room".
They've had 4 years to notice this behaviour, so this shouldnt be a recent development.
24 Nov 2019
@ComUtoR is in a position to know better than the reports, to be fair.
Virtually no “real people” who use the new London Bridge, versus the old version, think the new one is any worse !!!
Albeit the platforms are too narrow, during overcrowding scenarios, at the new version of the station.
tomuk
15 May 2010
I'm not sure if its available on Youtube but there was a fly on the wall documentary on British Rail in the London Bridge area in the early 80s. One incident included footage from the old ramps off of the high level platforms the crush was much worse then anything seen on Twitter in the last couple of days including one friendly passenger assaulting the platform bert who was trying to close a platform gate to control the crowd.
PGAT
13 Apr 2022
Selhurst
Found this on the London subreddit and I think it sums up the situation nicely.
ComUtoR
13 Dec 2013
What happened to nobody is using the railway, everyone is working from home.,.
uglymonkey
10 Aug 2018
They seem to delight in timetabling 2 trains to arrive exactly at the same time to the second on opposing platforms (say 5 & 6) and disgourge 2 full train loads to walk down the stairs and the escalator ( if its working) someone's going to fall one day and we will all go down in a pile like dominos.
The platforms are to narrow especially beside the escalators. It's also made narrower by the posters and handrails, making people stand further towards the edge. I've seen people " brushed" by trains as they come in.
Cletus
11 Dec 2010
Dover
BBC article about London Bridge
Huge crowds of commuters have been stuck at London Bridge station waiting to board trains.
Photos showed hundreds of people queuing to get up to the escalators to platforms.
Passengers reported people being "kettled," having panic attacks and needing assistance to get out by station staff.
The managing director of Southeastern Railway said that the disruption was due to a trespasser.
Commuter Jimmy Court, who was travelling from Cannon Street to Hayes, Kent said: "You can see it looks like it was in the thousands.
"It was quite concerning and dangerous. Staff seemed to not know what to do and more and more people seemed to be joining the crowd from the new connecting services.
"There was no way out and the staff closed the escalators to the platforms.
"At least a couple of people had to be managed towards the exit [and] let through to the barriers with panic attacks.
"Most of the mess seems to be because of the December changes to the timetable that makes a huge number of Canon Street passengers change at London Bridge as the direct trains were removed."
Posting on Twitter, Southeastern managing director Steve Wight said: "This is the second time that crowd control has been required at London Bridge recently. The last occasion was when a points failure caused disruption.
"Tonight's disruption was due to an emergency call stopping all trains due to a trespasser. A review will be held tomorrow."
A spokesperson for Southeastern added: "The trespasser has now been apprehended, power has been restored to all lines by Network Rail and normal services have resumed. We are sorry for any inconvenience caused to our customers due to this incident."
The Deputy Leader of Greenwich Council has written an urgent letter to Southeastern about the conditions at London Bridge.
Network Rail has been approached for comment.
Horizon22
Jobs & Careers
8 Sep 2019
Better than the MD?
Indeed and the government amended timetables because nobody uses the railway any more… One issue I imagine can’t help in a disruptive scenario is more changing at London Bridge for the terminal you need. I personally have no issue with the interchange and have done it loads, but it does inevitably increase footfall.
43066
24 Nov 2019
Almost certainly Old, Dirty and Late (a phrase that also applies to some train drivers I know ;)).
Better than the MD?
Possibly…
As I alluded to above something I’ve felt since it opened is that the Thameslink platforms, in particular, are rather too narrow. Unfortunately that was an inevitable result of squeezing more platforms into the footprint of the original station.
5&6 are not opposing platforms.
The only islands where trains can arrive at the same time in opposing platforms under normal service are 4&5 (Thameslink) and 2&3, and then only in the PM peak.
With 90 second dwell times and 2-3 minute headways, Id love to hear how it’s possible to timetable trains not to be there concurrently.
Most of the platforms are the same width. And there’s the same number as before the rebuild (15; previously there were 16 lines with 15 platforms). The issue is that to improve accessibility (through the provision of escalators to all the platforms and lifts to the through platforms) means that the middle of each platform is taken up with that, leaving less space to wait. However that’s why the station has canopies to the end of each platform, and the escalators face ‘outwards’ at the top, to nudge passengers away from that part of the platform.
ScotGG
3 Apr 2013
On the Greenwich line for example the slimmed down timetable now sees near enough half hour gaps between trains even in the peak so people build up on London Bridge platforms. This causes congestion and slow boarding for other services as people jostle and try to get through crowds.
Add in people being forced to change in addition to longer service gaps and problems arise. Similar seems to be happening at Lewisham - where thousands of new homes and residents are adding to the mix.
Yes it has. Before Dec 2022 Greenwich line had 4 SE trains per hour in the peak. It now has 2. They're timed to depart at exactly the same time as 2 TL trains which compounds the problem.
Go look at the timetable pre Dec 2022 and look at the existing. It *is* slimmed down.
And of course its far less trains generally compared to the pre 2020 timetable. The level of crowding seen even on days with no external issues shows the Dec timetable should have been working back towards pre covid levels and not further reductions.
