We still appear to be awaiting the origin of the rumour... :roll:
Probably a fairy from the dark side of Mars.
Done, and done. Here's hoping it doesn't have to push out the Southeastern train at platform 1 in order to fit in!Only if you do a peak hour extension to Ashford International![]()
Duracell or Energizer?Accelerate up to 108mph through ore and then coast all the way to Ashford. Fill the guards compartments with batteries to help with keeping speed up, and install some third rail from Ashford to Appledore to charge up the batteries.
The first 319 was completed in summer 1987 I believe, the first 442 was completed in November 1987 so the two classes are almost exactly the same age.
Utter bollocks. The 442s are going to be scrapped in the near future, without a doubt.
They won't even need to be melted down, as they're more than capable of doing it by themselves.
You mean like all that rolling stock that was previously being used in the Midlands and North that has found it's way onto the GEML...?
O L Leigh
One serious point - if the 442s will have a life expired traction system, would it not be cheaper to fit a new AC traction system to 442s then to order brand new AC EMUs?
You could always use them on the Merseyrail 3rd rail if they had to move North.
Or would there be a slight structure gauge problem?
Rebuilding older stock is far trickier than building new ones, and you would still end up with 25 year old bodies, with a 20 year life span?
Yes, but if you happen to own the asset, then pumping more money in, with a positive NPV, might be much better than a sell-off for scrap. The questions are
1) the accuracy of the estimate of the required investment,
2) how to get a 20-year commitment with a 10-year TOC contract
The answer is that the required investment must yield an acceptable NPV within the TOC life. But then, new stock is even more uncertain.
Buy a standard Bombardier/Siemens EMU and you can cascade it easily. Rebuild the 442s and in 10 years time you might find yourself once more stuck with unwanted stock...
Owners of new stock can unexpectedly find themselves with expensive assets in storage and depreciating - Classes 460 and 180 for example.
Assuming the 442s are written down to a negligible scrap value when they come off lease, you would only need to recoup the rebuild and finance/operating costs in the next lease period for the exercise to be worthwhile. I doubt the owners would aim for a 20 year life extension - probably 10 years is it, but if they do go on longer, that's more profit. I would think that all of the proposed retraction exercises on Mk3-based EMUs are based on payback somewhere around 10 years - they are already up to 30 years old.
There would be gauging problems. 442s have 23m cars, 507/8s have 20m
Both those examples had faily limited numbers of units with a fairly spercific role. If the 442's were replaced by the TOC with dual voltage units, but otherwise with a similar specification (i.e. 5 coaches, end doors, etc.) then there would likely be a lot of places that would be intrested in having them.
That sounds like a perfect description of a class 444. How long would it take Siemens to build new jigs if a TOC ordered a new build of 444s but with the new style cab needed to meet current crash regs?
If the North don't want them, put them on the Lymington shuttle?
Haha, yes! Best solution to the Lymington "problem" I've heard![]()
If any TOC takes them on after they get moved off the Gatwick Express, they'll have to replace the traction motors at the very minimum. How much of the underframe equipment will need to be replaced for working with new traction motors?
I seem to remember reading that the tunnels on the Wirral loop are certainly able to handle a class 66 which is a little short of 22mtrs. If the Northern line tunnels are more generous could a few be used on Southport to Hunts Cross or beyond trains?
