jrleighton
- Joined
- 23 Jul 2011
- Messages
- 10
There'll be plenty of DMUs around in the future with all the electrification and EMU production and cascading going on. No need to remove those 159s from the West of England route.OK, here's the solution. 442s to run Waterloo - Salisbury - Exeter. This releases SWT's 158s and 159s to First Great Western. FGW release a few 150s for Romsey services and Lymington.
If it's not possible to electrify third rail to Salisbury and Exeter (and I've read elsewhere that there's an issue around getting electrical power to the route) then a group of the new revamped Class 73s are brought in to haul the 442's. Preferably the third rail goes to Salisbury and the electro-diesel takes over there; otherwise the loco would have to take over at Basingstoke. If there isn't capacity there for locos to attach and detach then extend the third rail for a mile or so west of Worting Junction and do the changeover there.
There are 24 class 442 units so with 20 or 21 in service at any time there are enough for the weekday service. Off-peak trains all go up to 5 coaches and peak time trains go to 10
Minimal adaptations required (it says here, anyway). The main problem is Salisbury depot - even if there are no capacity issues everyone needs to be retrained.
I don't believe this "rumour" but it would be less impractical than many others.
However, there is a problem with capacity all across the network, so it makes no sense to chuck otherwise OK vehicles. Plus new stock means higher fares - so want to minimise that too, and sweat what assets are available without too much new investment.
So what's new?
Move 442s to Anglia London-Norwich route replacing Mk3s and Class 90 with DVT. 10 vehicle trains instead of 8 vehicle - a big bonus. No conversion needed - get a brand new panto motor car for each 442 set.
Those spare 442 motor vehicles? Well, the West of England route runs 9 car trains into Waterloo in the peak - SWML capacity is at a premium, so use them to run 10 car trains by putting some to use to make 4 car 158s - which would also mean that trains might be able to at least partly power themselves on the Waterloo-Basingstoke section using 3rd rail juice, helping with all those carbon emissions. Take a few of the SWT 158s and make them 4 car from 2 car with a couple of 442 motors in between the driving vehicles, and bung that hybrid on the Waterloo end of a train at Salisbury for the peak services. West of Salisbury would still be 3 or 6 car 159s. With a bit of jiggling of 158 / 159 stock around the network, easy. Plus, if the 442 motors fail, then there are still a lot of engines to keep the whole thing powered along. Plus the whole thing might be able to run at 100mph line speed into Waterloo, improving capacity ever so slightly instead of the 158/9 existing top speed of 90mph.
Cheap and relatively easy. And more importantly, it improves capacity where it's needed.
