Speculation: BR Class 442 - Northern Franchise
jon0844
1 Feb 2009
It's the doors that are the problem. Plus arguably that most of the time the trains are near empty, yet can still run as 10 cars even at midnight!
northwichcat
23 Jan 2009
Northwich
Running 10 cars when 5 cars are sufficient is a diagramming issue which may not be solved by new stock. I don't know if the service you refer to may be 10 car because if it was 5 car there would need to be a separate ECS?
Narrow end doors for limited stop services are something I don't get. If the service has no intermediate calls then it means everyone's going to alight at the final station and it will take time to get everyone off, unless the train is more than half empty. Also, express service are more likely to have passengers with luggage whether they're an Airport service or not.
And the fact that the current refurb is a cheap, shoddy job that hasn't even cleaned the ground-in filth off the ceiling panels and grilles, and makes them look dingy and old inside, as well as a livery that looks like something out of the 1980s or early 1990s.
In modern Southern livery with GatEx branding added, and with a heavy interior refurb like the fGW HST (I know the seats and lighting are rather Marmite, but those can be fixed while still leaving no panel uncleaned/unpainted), they could be superb.
Neil
Chris125
12 Nov 2009
A whole new traction package. OK not going beyond the third rail, but everything else is being spent, and it is very likely the traction package will outlive the body shells.
It's not a comparable situation - as well as being a much larger fleet the SWT 455s had already benefited from a comprehensive overhaul including a major refurb of the interior, and the reduced maintenance required by the new traction package helped the business case for the new Desiro fleet. Without that the investment may not have been justified, as there are no such plans for the Southern 455 fleet.
Chris
samuelmorris
18 Jul 2013
Brentwood, Essex
But a lot of new stock is not tried and tested with loads of new problems. While currently used on totally inappropriate services, I agree that with a decent refurb they can be made to look every bit as good as other Intercity services given modern refits.
Agreed, but not in every case - where follow-on orders are possible (there are lots of new stock orders up at the moment or imminently being tendered that could be followed from in this case I suppose) is kind of what I was hinting at there.
SpacePhoenix
18 Mar 2014
You need to weigh up the cost of a major overhaul of the 442s:
  • Replacement of the traction motors
  • Possible complete rewire
  • Possible replacement of the break system
  • Strengthening of the motor car
  • Installation of a pan well and pan
  • Installation of a transformer
  • Possible need to build a new motor car to deal with AC
against a new build of 444s (but with cabs that meet the current crash regs). A new build of 444s could also potentially have follow on orders from other TOCs:
  • TPE (would an AC version of a 444 be a better choice then the 350s they currently use?
  • LM (Any of their routes have express working with few stops)?)
  • Any Scottish routes post electrification?
cjmillsnun
13 Feb 2011
The reasons for end doors are simple.
1. There is normally a door from the vestibule into the interior of the coach. This means that passengers who are not boarding/alighting are less likely to get a cold blast when the doors are open.
2. Narrow end doors = more space in the coach itself. This normally means a more comfortable interior and also more seats.
1/3 and 2/3 doors are generally wider to allow for short but very regular stops.
Yagainst a new build of 444s (but with cabs that meet the current crash regs). A new build of 444s could also potentially have follow on orders from other TOCs:
A 5 or 6-car x 23m Class 444-a-like would fit the LM Crewe services quite well, I reckon.
Siemens won't build any more old-generation Desiros, though, it would have to be a Desiro City derivative.
Neil
SpacePhoenix
18 Mar 2014
Neil
I can't see what would stop them, if the designs were done in CAD then all they need to do is update them for the new design of cabs, manufacturer the jigs (probably using CAM) and then start production. It would be down to if any TOC would pay them enough to justify it
Fincra5
6 Jun 2009
I'm currently sat on a 168 from High Wycombe.. Can't help but feel Chiltern need more coaches. Probably been mentioned already but couldn't 442s be Chilternised. Remove the 3rd rail gubbins to pair them with a 67/68 loco. Boom 5 car trains without the need for DVTs. The odd trailer car could also be slotted in to make the 442 6 or 7 cars.
Chris125
12 Nov 2009
The whole design is out of date, it really wouldn't make any sense.
t_star2001uk
23 Aug 2011
If only it were that easy. To add to your above list there would also be...
1. AAR multiple working cables and the associated conversion from blue star.
2. Reinstate the ETS cables that were allegedly removed/ isolated.
3. Train all of the drivers at Marylebone, Birmingham and Stourbridge.
CosherB
23 Feb 2007
Northwich
also, the Chiltern DVTs are now fitted with diesel engines to provide overnight hotel power.
Class377/5
19 Jun 2010
Siemens have said no more Desiro UK models. That includes the 350, 450, 444 and 185. Now what's on offer is Desiro City. Let's not forget the 23m 380 is based on the Desiro City platform. Personally Id think they would suit TPE.
cjmillsnun
13 Feb 2011
Slight correction.
1. AAR multiple working cables and the associated conversion from SR 27 wire
2. No allegedly about it.
ETS jumper clearly there on pic above, plugged into dummy receptacle.
ETS cable not there. Dummy receptacle still there.
3. Re-wire coaches to standard Mk3 They are anything but (this being why the ETS never worked)
4. Train drivers.
t_star2001uk
23 Aug 2011
Slight correction.
4. Train drivers.
I stand corrected......
SpacePhoenix
18 Mar 2014
Looking at a pic of the inside of a 380 around by the doors, do you think a vestibule door could be squeezed in where the glass panels are between the door area and the seating area?
I've not had any luck trying to find a floor/seating plan of a 380 (the only sort of seating plan that I can find is for the plane variety) to see that is at the ends of each coach between the doors and the end of the coach
Class377/5
19 Jun 2010
While I'm not 100% sure on the 380s but guessing you mean reduce the door width?
Olaf
29 Mar 2014
Conversion to ac would be ideal for TPE on Liverpool/Manchester-Scotland and Liverpool-Newcastle possibly extended to Edinburgh post electrification where IC standard is required on such long journeys not being provided by stop-gap 350/4s.
With the current winging over the 319 cascade, I don't think even Genghis Khan would be brave enough to propose that.
Nobody can say without stripping out a couple of coaches to check on corrosion.
I think the coaches were stripped down when they were deployed to the Gatwick Express services. There is some background on the related threads.
And to play devil's advocate. How much is being spent on Porterbrook's (SWT's) 455s?
The cost savings make the project self-financing within a relatively few years.
Is there any proposal were the units would remain in service sufficiently long enough to recoup the capital investment costs?
northwichcat
23 Jan 2009
Northwich
Rumour DRS have been asked to provide costings for use of 68s on Liverpool-Newcastle services for the next franchise. Hopefully if true it's for enough sets to provide a half-hourly service meaning the 6tph can happen and still allow adequate capacity on other services using 185s.
cjmillsnun
13 Feb 2011
Note I was playing devil's advocate. I agree that unless Angel Trains follows Porterbrook into retractioning their 458s, and doing the 442s as part of that programme, there is just no way it can be financially viable.
The Ham
6 Jul 2012
One of the main reasons for offering only the Desiro City is that it is cheaper (by about 1/3) than the original Desiro trains to maintain. This could be enough to scuppere any major rebuild of older units, especially if there was the need to convert them to something else (I.e. from 3rd rail to OHLE) for which they were never originally designed.
al.currie93
27 Jun 2013
Defintely not gonna complain, but if true, DRS would seem to be taking on quite a lot of passenger services from the franchised TOCs, which could actually be considered as a stealth-nationalisation :P
47802
6 Mar 2010
Personally I think that might just be a contingency if Network Rail don't get Liverpool - Manchester electrification going by May, and even if its for the new franchise that may just be a contingency to deal with the loss of the remaining 170's until Blackpool electrification is complete, I guess it could be proposed as a longer term solution by the short listed bidders pending TPX electrification.
glbotu
8 Apr 2012
Oxford
68s? What will they be hauling? The current 185 services terminate in platform 5 at Newcastle, which is a pretty short platform, I haven't seen anything longer than 4 cars in there. Surely any LHCS will also struggle with dwell times in the busier sections of the route.
northwichcat
23 Jan 2009
Northwich
I've no idea. Maybe it's a DfT cutback to squeeze 3 carriages worth of passengers on to a loco. ;) More seriously the loco is the expensive part of a loco-hauled formation so acquiring the costs for the loco is probably the most important part.
Based on current timings: http://www.realtimetrains.co.uk/train/Y62779/2015/01/30 Victoria, Leeds and York shouldn't have any issues. Durham may be an issue but it appears in the working timetable the train leaves Durham later than in the public timetable as it is.
sprinterguy
4 Mar 2010
Macclesfield
TPE services generally use platform 9. It can (just) accommodate 5 x 23 metre carriages.
Platform 5 is half of one face of the southernmost "regional" island platform.
