ladydsm
How often do locos have to be started in cold weather or can they be left for days like cars.
Most Diesel locos (particularly 66's...and I say particularly 66's as that is about as far as my knowledge extends to) are actually designed to be left running continuously, its only to appease loco residents .
That has been the case for years, with extra turns introduced when it was freezing to go round and keep locos/dmus running.put it this way, I know for a fact that some drivers are paid to go in on christmas day/boxing day to warm up the engines at canton - I expect this happens across the board
during very cold weather locos tend to be left running continuously to prevent them freezing. Pacers and Sprinters are started once an hour and then the timer shuts them back down again after approx 15mins.
It is when all the wheels are frozen and its a Cravens DMU !to think that the frozen contact patch about the size of a coin is enough to prevent a traction motor turning seems unbelievable to me
TDK said:Class 67's do not need to be started and take about 18 hours to cool right down, they also have anti-freeze. The only problems that occur are the air pipes freezing on the stock.
A secondman hanging on the fuel rails used to help
The 67 thunderbird at Newcstle sits in the siding next to platform 8 all day, until at night when it goes to sit in platform 12. I asked the driver why he did this, and he said it was to keep it a bit warmer.
If you are right, this would mean that they wouldn't need to do this. However the thing is that the thunderbird is in a better position in the siding as it can go north or south without reversing (via the High Level Bridge for the south), whereas in platform 12 it would have to reverse to go north.
