Stations Where Passengers Have to Cross the Track
SamS
25 Oct 2013
York
Poppleton - not sure if it still counts though, you now have to cross over the level crossing as they closed the foot crossing.
Taunton
1 Aug 2013
Gomshall on the North Downs line again. I felt the visibility there was not that good.
And probably numerous locations in the States and Canada too.
I was dismayed at one on the San Francisco-San Jose commuter line where all rush hour passengers for the platform on the far side from the entrance have to cross the tracks on foot, meanwhile nonstop services were run in the opposite direction at full speed, nothing more than a tinkling bell for the passengers plus a huge amount of loco whistling on charging through, with people crossing just in front or waiting feet from the passing train.
Matlock Bath - last time I looked there was a very short 10mph speed restriction for the width of the crossing. This is the access to the Heights of Abraham cable car.
Newark Castle used to have a crossing at the east end, meaning passengers alighting from a train arriving from Nottingham would block that train's departure towards Lincoln. Changed a few years ago so this platform is accessed from the road level crossing.
lincolnshire
12 Jun 2011
Thorne South is another one.
Not any more, it had a temporary footbridge put in after a near miss before the Hatfield Colliery Landslip the other year and while the landslip was on head a monster footbtidge and ramps permantly fitted while the rail replacement was running and so reopened after the landslip with footbridge and ramps. Bet they wished they had still been using the origional station as it did have a subway between platforms origionally
No that would not count as you use the road, same as at Howden you can only cross when the barriers are up.
Crowle is another one where there is only a foot crossing between platforms since approx 1979 when the level crossing and bridge across the canal was closed and removerd and replace by the flyover nearby across the canal and railway. Its down to have a monster footbridge and ramps built sometime which will look and eyesore or a blot on the landscape.
Merseysider
Fares Advisor
22 Jan 2014
Drigg station, on the Cumbrian Coast. There may be more along that route, I can't remember too well.
Parallel
9 Dec 2013
Dyffryn Ardudwy and probably some others on the Cambrian Coast.
bb21
Emeritus Moderator
4 Feb 2010
Given the number of Yorkshire forum members, surprised that no one mentioned South Milford. (Unless I'm wrong, of course.)
D6975
26 Nov 2009
Bristol
Topsham on the Exmouth branch used to be bridge-less. Not been there for a while, is it still across a level crossing to the other side?
northwichcat
23 Jan 2009
Northwich
Nearly everywhere in rural Europe!
One station between Munich and Salzburg (can't remember which) had trains stopping on a platform-less middle track with passengers having to walk across a line to get between the train and the platform.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Salhouse, the only access to the station is on the down platform (platform two), to reach platform one, you have to cross the two lines using the barrow crossing provided.
Further to this, I believe Littleport is in a similar situation?
TP
fenview
17 May 2011
TP
Certainly Littleport the last time I used it.
Buttsy
20 May 2011
Hanborough
Horton-in-Ribblesdale is another.
South Milford you're directed to walk under the railway on the road rather than cross the line (even though you are allowed cross the line). Nearby Sherburn-in-Elmet requires crossing of the line and is protected by remnants of the old level crossing, which comes down about 5 mins before the train is due - not helpful if you've come from the village for a southbound train.
Ascott-under-Wychwood, Eastrington and Nunthrope are via the road level crossing.
Buttsy
20 May 2011
Hanborough
Habrough is via road level crossing.
Knaresborough is by the former road crossing.
Seamer by singal locked gates
Tackley
Normanton used to be light controlled, but I think there's a bridge there now.
all of the stations on the Marston Vale line
Never noticed the crossing at Bletchley ;)
nowananorack
15 Aug 2007
Colden Common
Harlech, on the Cambrian, though there is a footbridge between the platforms towards the Porthmadog end. I don't know what state its in.
Though there is a footbridge, most access the Ffestiniog Railway at Blaenau Ffestiniog accross the end of the ATW from Llandudno.
Tanygrisiau, on the FR, Beddgelert & Rhyd Ddu, on the WHR, are all island platforms.
Pont Croesor, on the WHR, the Caernarfon bound platform is accross the tracks.
At WHR's Dinas, access to the Porthmadog bound trains is accross the tracks
elucidate
24 Sep 2013
I know that one of the stations that fall on the line between Cambridge and Cheshunt has such a crossing ... I think it's Sawbridgeworth.
EDIT: My bad, it was actually a station on my way to Lincoln last year. I think it was Swinderby.
