As railway enthusiasts we don't seem very good on here about getting behind possible new reinstatements. What's the likely BCR for this proposal - is it really totally hopeless? Is there anyone able to give indicative BCRs - without charging 60k, or anything for them?
Maybe then we can target a top 10 or 20 say and make sure they are sped through before tackling the next 10 or 20? I think ATOC did this with Connecting Communities' in 2009?
What I've found after many years on this forum is a reopening proposal is usually smothered by post 4 for reasons which usually sound something like:
a] It's a line which has been built upon and/or would cost too much to re-lay and/or has no wider benefit to the immediate area. I'm thinking Skipton-Colne here, a project I used to support fully until many users on this forum persuaded me to change my mind because the money was simply too great for a scheme which would generate too little resulting benefit.
b) It's an enthusiast-focused scheme which has more to do with looking far into the past than thinking of the future. That's your Carmarthen-Aberystwyth.
c) It's small-fry compared to far 'sexier', far 'bolder' projects. That'll be anything local that could be steamrollered by HS2.
What this forum tends to do is look with cold, calculating reality on reopening schemes. One quick look at Google Maps on another tab is all that's needed to
prove that a suggestion has to be dismissed because a single housing development lies between Point A and Point B. It's not always a bad thing, it stops threads becoming fantasy wishlists and crayola festivals. It is always good, I suppose, to be grounded and realistic.
THAT SAID, you sound as I often do when faced with a barrage of 'Well actually..." responses to suggestions and ideas. Sometimes the merest hint of a proposal is too readily given the wet blanket treatment. Sometimes it can be better to explore the possible rather than to dismiss the right to dream...
