SWT Leaving Clapham jct without guard onboard.
GingerRH
21 Apr 2015
So this evening a train departed Clapham Junction towards Wimbledon and the guard was left on the platform at Clapham. Passengers were stuck onboard at Earlsfield as the driver couldn't open the doors. Train continues to Wimbledon where it was later cancelled awaiting the Gaurd on a following train.
How did the train manage to depart without the Gaurd onboard? Surely he/she must have closed and locked all doors and then stepped back onto the platform?
Anyone have any more info or ideas as to how this happened?
Skimble19
12 Dec 2009
Why couldn't the driver open the doors? Do the cabs on SWT units not have door open buttons? Or was it because the driver wouldn't have been able to dispatch the train when he/she needed to close them that was actually the issue?
Bigfoot
2 Dec 2013
On swt the driver has nothing to do with the opening and closing of doors in service. Only when required to prep the train for service will they use a door panel.
Alistair G.
16 Jun 2013
Leicester
Very strange case!. Surely the driver should only depart when he got the "2 bells" from the guard, and this is usually only given after all passengers have got on or off the train, all doors are closed and have been "locked" and the guard will then buzz the driver to say all ready to depart. Until the driver gets that he shouldn't be moving (unless D.O.O of course but this isn't relevant here).
Would love to know more on this story if anyone hears anything else
MartinB1
10 Jun 2015
This can happen on a SWT 455. If the guard operates the doors from a door panel in a drivers cab, and gives the ready to start signal whilst standing on the platform. If a guard has his door panel switched on, the train can move with his cab door still open. The guard in this case must have completed the station duties, got the doors closed and reached up into the cab to press the ready to start before stepping onto the train himself.
SPADTrap
15 Oct 2012
Sounds like something you'd never hear the end of! Ribbing material for years!
SouthStand
8 Aug 2010
Why were the passengers stuck onboard at Earlsfield? Couldn't the driver exit his cab within the train to unlock the doors?
whoosh
3 Sep 2008
There might be a Door Key Switch which the guard will use to operate the door controls. If there is, then I expect other door controls won't work, so the driver would've been unable to open the doors from his cab. I expect drivers carry a Door Key for when they shut or open doors on Empty Coaching Stock and for testing doors when prepping trains in sidings, but having his own key wouldn't have helped as inserting it would've meant two keys switched in which wouldn't've worked and probably tripped a circuit breaker for the doors.
tsr
15 Nov 2011
Between the parallel lines
I am not familiar with SWT 455s as I only have anything to do with Southern ones, but if their door controls are similar, the driver would have to exit their cab, walk down to the intermediate cab with the door key active (or presumably a panel on SWT's ones), release the doors from there and then walk back to the cab for further relevant communications. There may have been too much confusion to do this, or maybe SWT's drivers are forbidden from releasing the doors even in these circumstances. The area with the key switch should be accessible using the keys a driver carries, AFAIK.
That's assuming this was a 455. I have absolutely no idea about other traction SWT uses.
As a further point, I am very unsure about why you would give 2 on the bell whilst standing on the platform. There's not really any point as the train should be safe to depart with you on board. I can understand giving 2 on the bell whilst the local door is still just slamming shut with the guard already onboard, but 455s are pretty quick off the mark and there wouldn't seem to be any time saving from giving 2 whilst still on the platform! Seems taking a bit too much of a risk to me. As I say, though, I don't work or have anything to do with SWT 455s or dispatching them, so even if this is what happened, I could have missed something.
Antman
3 May 2013
My thoughts exactly??????
I know I'm stating the obvious but shouldn't the guard be on the train and not the platform when giving the signal?
TheEdge
29 Nov 2012
Norwich
My thoughts exactly��
I was thinking that. I know this it is quite easy to lock yourself out of a 153 like this and it's not unknown for a driver to get interlock and depart on autopilot. But not to give the RTS on the platform. :|
Presumably it would not be permitted for the driver to open, close and dispatch himself - as soon as he released them the train would have to be terminated. So I guess on realising the problem he contacted his Control who identified the best place for this to occur and the train to be terminated to the benefit of the majority of passengers on board?
Slightly surprised it didn't have to be terminated at Earlsfield anyway, but then I suppose up until then it was no worse than any DOO train.
How could he give the signal when off the train?
455 cab doors (same as 507s and 508s) don't have an interlock on the staff door if the key is in (possibly even if it isn't on 507s and 508s), if I'm reading rightly. So the guard could be standing on the platform while pushing the signal button.
29 Aug 2010
Any good guard worth his 10 cents knows where the external egress or door cock is which (hopefully) activates a door interlock kicking the brakes in. Not suggesting I've had to ever do it of course, and the clown driving the 158 now drives Australian trains. Allegedly ;)
scott118
24 Feb 2015
East Anglia
I think we know where the 'cock' is/are....:lol:
HarleyDavidson
23 Aug 2014
It could have been that the guard closed the doors, gave the driver the bell, but for some reason or another (s)he didn't move straight away, so the guard may have thought that they didn't have the signal, so being conscientious (made what's now a goof!) stepped out onto the platform to double check, only for the driver to then take power and go PDQ, leaving the guard on the platform!
They won't be the first & they won't be the last, it used to happen every so often at Surbiton and the guard would have to be taxied to either Esher or Hinchley Wood!
The reason the driver won't open the doors is two fold.
1. There was an "incident" where a driver activated the doors (with all the best intentions & it was proven there was no malice), which could have been very nasty indeed, so there was an instruction issued that drivers must NOT operate the doors of the train whilst in service, which is fair enough.
2. If it's rush hour the platforms are going to be packed, the DKS will be 99.9% of the time active in the centre cabs & most definitely not the leading one, possibly the rearmost should both the DKS be defective in the centre cabs (unlikely). Now bear in mind that drivers have now been instructed NOT to activate the doors from the previous incident and you can see the problem.
The driver's damned if they do activate them to allow passengers off, they're damned if they don't, the driver may risk a serious charge sheet if they do.
So what do you do? Me, ring control on GSM-R or ring a DM on your mobile (from the safety of the platform) and get authority to open the doors & detrain the whole lot and take the train ECS.
Goldfish62
14 Feb 2010
Some drivers will open the doors of ECS stock they bring into Waterloo to save passengers standing on the platform until the guard arrives - sometimes up to 5 minutes later.
HarleyDavidson
23 Aug 2014
But that's not in passenger service is it! :roll:
And if you've been working together earlier, you can ask them whether they want you to release the doors on arrival. That way you have permission to do it!
Clip
28 Jun 2010
Can SWT trains move with a door open then? Im guessing in your scenario that he wouldve left the door open if he got on to the platform?
Goldfish62
14 Feb 2010
Correct, it's not in passenger service. Your point is..??:roll:
Merseyrail 507s and 508s can if it's the staff door. I think it's suggested upthread that 455s can if it's the staff door *and* the key is in in that cab.
HarleyDavidson
23 Aug 2014
Did you not read what I said earlier. A driver isn't allowed to release the doors! it doesn't matter if it's ECS or In Service!
Not without permission!
Yes, a local crew door can be open whilst in motion as it's on local control, but it's severely frowned upon and loads of paperwork!
455driver
10 May 2010
As I used to work 455s (I do miss them :cry:), and as everyone seems to have made their minds up exactly what happened can you tell me step by step please.
I am aware of 2 ways this can happen, one is the guards fault, giving 2 on the buzzer while stood on the platform/ stepping onto the train and then slipping off.
And the other is where the driver gets brake release when the passenger doors close and instinctively sets off (without getting 2) with the guard on the platform and the local cab door wide open. Yes this happened to me once when I was a guard but I managed to dive in the local door, he coffee the driver bought me was lovely! ;)
These are 2 scenarios I can think of, I am sure there will be others!
either way somebody will be getting the wee wee ripped out of them for a while! :lol:
SpacePhoenix
18 Mar 2014
On more modern stock, can the driver get a brake release while the guard has their "local door" open (the door they're operating the guard panel at)?
Olaf
29 Mar 2014
Would this lead to the dismissal of the crew involved?
There will be a meeting with the manager (there won't be tea or biscuits) but, unless they were already on a warning, then almost certainly not.
LAX54
15 Jan 2008
Can recall...more than once when I worked at Barnham, the fast Bton to Ports would arrive, and then have to wait for ages.....as the Guard was in a taxi en route from Worthing along the A27, they tended to 'ding ding' with door ajar, looking out, jolt of the unit, lost blance ended up on the platform, Driver blissfully unaware......all speed to the next stop...Barnham :lol:
