Class 319's into storage/withdrawals tracker
Class455
19 May 2016
Thought it would be best to create a thread for this rather than clog up other Thameslink related threads about the 319's heading to storage. This thread is also to keep track of all Class 319's in storage along with units that have been scrapped.
The Class 319's are now all withdrawn from passenger service and they are either in storage in the following locations or no longer exist:
Stored at Long Marston
319362
319363
319371
319382 (was converted to HydroFLEX 799201)
319376
Stored at Crewe South Yard
319441 (ntu by ROG/Orion Logistics)
Stored at Eastleigh Works
319011*(ntu by ROG/Orion Logistics)
319377 (ntu by ROG/Orion Logistics)
319380 (ntu by ROG/Orion Logistics)
In use with the Ministry of Defence (expected to be scrapped)
319220
Scrapped
319001* (converted to Hydrogen FLEX demonstrator, renumbered 799001)
319004
319005
319012
319013
319214
319215
319216
319217
319218
319219
319361
319363
319364
319365
319366
319367
319368
319370
319372
319374
319375
319376
319377
319378
319379
319380
319381
319383
319384
319385
319386
319426 (was due to be 769426)
319429
319433
319451
319453
319454
319455
319457
319460
Units still in Thameslink service
None
Units still in Northern service
None
Units still in London Northwestern Railway service
None
I will update this list as more locations of storage are changed or more units are scrapped.
Last Updated: 13/05/2024
NSE
3 Mar 2010
I doubt they'll stay there too long. They're perfectly decent EMU's capable of high capacity loading during rush hours.
Unless LM's maintenance engineers are incompetent, I think they are proving to be nothing of the sort. It's 321s that I would expect to be in a lot more demand once a load become available when East Anglia's new EMUs come along.
sk688
11 Sep 2016
Dublin
I doubt they'll stay there too long. [/B]They're perfectly decent EMU's capable of high capacity loading during rush hours.
Hardly so. They are horrible inside, worn after 30 years Abuse on thameslink, unreliable ( as shown by the LM units), uncomfortable and noisy.
The scrapyard should be the next place for them ( or Northern to solve capacity issues)
Supercoss
5 Jun 2016
After the Translator coaches (Tightlock one end/drawhook & buffers the other) arrived at Cricklewood and spllt, the 319s actually driven under own power into the Translator coach before other end Translator attached with loco on other end. Pan down. key out and away. Whilst shoebeams remain the actual collector shoes removed from each driving trailer.
Future moves expected to be done with adaptor coupling fitted loco only without the Translator coaches i'm told
47802
6 Mar 2010
Other than those used on Northern I don't see much future for them other than the flex project for which they have an advantage over the AC only units, given the large numbers of AC units that will become available in the next few years, many of which are newer or better refurbished.
I agree, and I suggest that's why Porterbrook are pushing the Flex concept. Without it there's little chance of anyone else signing up for the 60 or so units that aren't going to Northern.
SpacePhoenix
18 Mar 2014
If they were given a really good overhaul and refurb to the level that SWTs did with their 455s & 456s could many more years of service potentially be squeezed out of them?
Darandio
24 Feb 2007
The Northern stock issue in a nutshell.
Worn, abused, unreliable, uncomfortable, noisy........but more than good enough for those in the north.
ChrisHogan
15 Jan 2016
I can't understand why the DfT isn't forcing LM to take some more of them. There is frequent shortforming out of Euston and about 5 8-car trains in the peaks that have passengers standing more than the contractual 20 minutes.
As well as that, if Bromsgrove does get wired for December 2017 then LM's successor won't have the units for the extension as far as I can see. Further 319s would allow a 319 > 350 > 323 cascade within either franchise.
MatthewRead
21 Nov 2014
West london
No there not they are much cleaner and comfortable than the Electrostars:)
MML
25 Oct 2015
Could the Class 319 Flex be used on the London Bridge - Uckfield service ?
Might help to release Class 170 elsewhere where 3rd rail is not available for part of the journey.
D365
29 Jun 2012
Sure we've had this discussion before, and I believe the answer was that Mk3-derived stock is not cleared through a particular tunnel.
gimmea50anyday
8 Jan 2013
Back Cab
Wouldnt the 20m length of the individual coaches of a 319 make a difference when compared to 23m HST or LHCS?
Im not local so Im not aware of the route gague limitations
Marklund
18 Nov 2010
If the dimensions on Wikipedia are to believed, the 319 is shorter than the class 150, and very, very slightly wider.
If the class 950 TRU can go down there, (can it?) then the 319 would be too, I'd guess.
bnsf734
15 Oct 2007
Nuneaton
According to my 2014 Rail Guide written by Colin Marsden Class 150 and 319 are the same width and almost the same length:-
Class 150
width 2.82m 9ft 3in
length 19.74m 64ft 9.75in
Class 319
width 2.82m 9ft 3in
length 19.83m 65ft .75in (Driving cars)
length 19.92m 65ft 4.25in (intermediate cars)
physics34
1 Dec 2013
the 319 restrictions through oxted tunnel are due to the shape of a mk3 coach.
Class 150
width 2.82m 9ft 3in
Class 319
width 2.82m 9ft 3in
Surprised the 319 is longer, even if only fractionally so - I thought it was the same body.
Class377/5
19 Jun 2010
Possibly down to the different cab ends on the later Mk3-derived EMUs?
Yes. The 319 cab isn't flat so adds to the overall length. It's this that's means 319s won't fit down Merseyrail's tunnels either.
A0
19 Jan 2008
I suspect LM don't want them, probably in part due the problems they've had with the few they've already taken.
I'd expect Northern to be asked to part with their 323s to go to the West Mids - I have a feeling some of the West Mids platforms aren't long enough for 8 car units, so 319s wouldn't be the answer, whereas more 323s would be.
And didn't I read somewhere that Mk3 EMUs aren't cleared north of Rugby towards Birmingham now? So further 319s would be very limited in terms of what they can / can't do.
And I expect LM have got their eyes on the 350/4s which are coming available - thereby giving them a standard 323, 350 EMU fleet.
If LM were to take all the 350s as they become available, the initial batch would replace the 319s nicely, while the rest (i.e. the East Anglia and HConn ones) would be a nice growth build. I would expect to see this in proposals for the new franchise, and would be less likely to see new stock, though it wouldn't totally surprise me to see something that is a bit more of an outlier, like new 125mph Desiro Citys with a higher spec interior for the Trent Valley services.
northwichcat
23 Jan 2009
Northwich
The 17 x 323s will leave Northern on 1st January 2019. Porterbrook hope the winning LM bidder will take them on but there's no guarantee that'll happen. I get the impression Porterbrook blocked Northern bidders from securing them on a long term lease in the hope of getting them to lease upgraded 319s instead but Arriva decided 331s would be a better proposition.
