samuelmorris
Pretty sure I've been on a couple where the TfL feed has been several days out of date.
Perhaps a farewell tour for the 700s with old logos?! Like C2C did when they ditched the blue trains!
Usually they use markers filled with acid that etches windows.I travel on the 700s about 4 times a week and something I've noticed is a lot of windows have been vandalised (specifically in the first class ends where I try to sit). Basically the culprit has created swirly patterns by scratching, presumably with a diamond etc, the window interiors.
Anyone else noticed this?
Also noticed this recently.I travel on the 700s about 4 times a week and something I've noticed is a lot of windows have been vandalised (specifically in the first class ends where I try to sit). Basically the culprit has created swirly patterns by scratching, presumably with a diamond etc, the window interiors.
How do I find out which routes/times the 700s are operating tomorrow? I need to bathe in some of that sweet sweet air conditioning on the way to work.
Realtime Trains shows trains I suspect as being 700s as just "Electric multiple unit", e.g. this one.
Any more detailed info available?
People don't seem to realise that HVAC issues are often going to be per coach.At least one coach always seems to have defective air con always surprised the passengers in it sit there on a half empty train
Given that there are regular complaints here about a/c on trains being set too hot or too cold, along with the reluctance of some passengers to lift themselves from a seat, then maybe the situation is not so bad. All they need to do is modify the PIS to display the relative temperatures of each car.
Combine that with the loading measurement - you could dial up the heat in overly packed coaches to make the passengers spread out!![]()
On a brand new train?- that is ridiculous.
It would be if that was a fact. I have never travelled in a class 700 with defective a/c, so treat the complaint as hyperbole.
Your hyperbole is worst to be honest.
You constantly dismiss other complaints as some kind of bias or haters. YOU may have travelled on one with perfect air con every time and zero faults but THEY may have travelled on one with faulty air con every time and faults each time.
Almost every single day I go north I hear about a failure of some kind on a 700. We are now at a tipping point that for sure but they are still breaking for some very stupid things that shouldn't happen. The last one I got given by my TOC was about a setup issue which, by their own admission hasn't been trained on or even known that it was possible. These trains look to have many software issues that are causing the faults. I do get the impression that they were rolled out knowing that the software can be updated so it was treated as unimportant as they can update it.
The last fault I heard from another Driver was a couple of days ago where they got halfway through their trip and the 4QC went tits up. But that is just hyperbole and never happened. Never happened, these are not the droids your looking for.
@ageofthetain. They are hit and miss. Personally I haven't had any faults or had any problems with air con, other than being told never to change the temperature. But then again, I'm up the pointy end.
It does seem that in the UK rail industry still have the 'good' old British Leyland attitude of using the customer as quality control.
Surprised nobody's said it yet, but wouldn't the open design of the unit make it difficult for one coach to become noticeably 'hot' if it's a/c failed? Surely the surrounding coaches would more or less support it?
