Voyager 2093
I agree 153s before 142s, highly unlikely if you ask me.
153s are very useful for extra peak time capacity when attached to 150/2s, 155s, 156s and 158s
The vast majority of New Street-Rugeley services (except the few formed of a three car LM 170) are formed of a 2 car 170 and a 153 to give the necessary 3 carriages. I imagine they would be able to use the corridor connection when in multiple with the corridor fitted London Midland 172s in the future, but the 153s will be going elsewhere at that point.
I reckon that the Pacer units will be thoroughly run into the ground and will be with us for many years to come, particularly plaguing the Northern franchise. The routes the Pacers operate on are not likely to see much investment in new or replacement trains. So I reckon the 153s will be gone first. If I had to choose the first Pacer class to go, I'd say it would be the Welsh 143s.
What couplings are the 172s going to be fitted with?
Nonetheless, the 153s still add useful extra capacity to 170 services, even if they do have the inconvenience of the lack of a corridor connection on the Turbos. Not quite as good for ticket checks as when used with other Sprinter classes (where the conductor can of course walk from one end of the train to the other), but still useful.
I think permanently reforming the 153s as two car trains (going back to their original 155 spec) would require a degree of joined up thinking amongst several TOCS, if it was done wholesale, so am dubious about such an occurence
The 172s are fitted with the standard BSI couplers, so will be able to work in multiple with the Sprinter classes and 170s.
Take what you hear with a pinch of salt... 314's are very reliable units, not much can go wrong with them and they are very fast off the mark. You can make up for time with the 314s... if Scotrail puts Junipers on the line they should expect delays and alot more train failures, as proven they can't handle a little bit of snow.. or in the Summer the heat goes for them. The only thing needing done to a 314 is a refurbI have heard that the Cl314 is going to remain in service until 2019!
