gchst
314, 43, 143, 144, 142
the class 43s (hsts) will not be withdrawn for about another 10-15 years apparantly
The class 313s and 508s will be next to go due to their age, although they're still perfectly adequate trains..
They'll be withdrawn in about 2020 from the GWML when that line is electrified and the IEPs are introduced. Even then, they'd still have at least 10 years of life left.
Most of the remaining class 90s are concentrated on London-Norwich services, which will probably go over to EMU operation due to the EU's disability access regulation which means the 90s and Mk3s will have to go by 2020.
to the EU's disability access regulation which means the 90s and Mk3s will have to go by 2020. .
An HST is faster off the mark than a 67 as there are two engines, 67's take there time to reach speed, even with load 4 up the hill to Corrour they take there time to reach 40mphIf you mean WSMR then I doubt they would have ever got paths if they used HSTs, a 67 would thrash it from a standing start and up to speed.
Nothing to do with the EU, the UK RVAR is far more stringent then the UIC regs.
Does there not need to be a current isolation when the HOBC is operating then? I would have thought that there would be, especially if the MFS wagons were to be topped-up on site....A 92 hauled the HOBC up and down the WCML in a test a while back without breaking into a sweat.
DBS have all the 92s unless Im mistaken.
Freightliner have the 86s dont they ?? DBS have all the 92s unless Im mistaken.
On the class 92 front, DBS have a lot of them with Europorte 2, part of Eurotunnel, for use in the Channel Tunnel. Of note, GBRf have 3 at the moment...
the 3 allocated to gbrf are europorte 92s and are in the gbrf pool to enable driver training to take place between dollands moor and wembley for europorte. Believe that later this year they are going to start a service to dirft.
dirft???
Daventry International RailFreight Terminal.
Thanks for clearing that up. I guess dependant on the noves required within the worksite / T3, and the direction the train would be exiting from, a 66 at either end would be needed, which may very well make the hauling to site of the HOBC by Class 92 a bit pointless. But the point you make about them being capable of hauling heavier freight trains along the WCML is ably illustrated.It moved it from Willesden up to Northampton and back, when its moved into the actual work site it has to be done by a 66, so two engines are needed in that scenario.
Wikipedia suggests that the class 315's may be replaced from 2012 as they will be "life expired". I cant see that happening as 32 years is hardly past it in my eyes, 42 maybe. These are decent hard working trains which despite being a little uncomfortable are ideally suited to their current role and should have a bit more life left in them.
This idea may be as a result of the main Liverpool St.-Shenfield route being included in Crossrail, but what of the Liverpool St.-Chingford/Enfield Town/Cheshunt/Southminster and Romford-Upminster lines that the 315 monopolise also?
Firstly, a controversial point: Romford to Upminster should never have been cut off from the Ockendon route. I know that there is a slight problem called the District Line in the way, but there must be some way of pulling it off without great expense or a flat junction.
Anyway, I do agree with them maybe being life-expired come Crossrail, but in practice they will probably be sent to some other OHLE-using TOC instead, probably by the name of Northern Rail. I could get into a lot of trouble with people I know in person for saying this, but I would actually recommend that some go to c2c and they operate the Rainham route, thus freeing up some 357s for an improved Southend service, maybe even on the Victoria route (thus displacing some 321s to, if I had my way, nearby Pig's Bay ). As for the WAGN lines, however, I'm not so sure. I honestly can't see them being withdrawn any time soon. The routes you mention are so short that they are suitable for them, especially the Chingford route.
And lastly, just to clarify, the Southminster route does see a lot of 321s. Unlike during FGE days. I suppose that, were they to increase the Victoria route to a 15 frequency (thus maintaining 4tph at Wickford and Billericay), a 315 could run the Crouch Valley Line on its own. If run efficiently, one unit could just about do it (I would suggest a quick turn around at Southminster though, say three minutes).
I agree that I can't see any major class withdrawals occuring in the near future.
With that in mind, the five I'd put money on being withdrawn in the next decade or so is:
60-Unfortunately
91-But only if IEP actually happens
143-Though they may just cascade to Northern
153-(First of the Sprinter classes to go, but not any time soon)
313
